Date/Time: Wed, 29 May 2024 06:20:44 +0000
Ratio
View Count: 566
[2017-03-31 14:28:50] |
User606150 - Posts: 6 |
Is it possible to produce a chart of the ratio of two moving averages of futures contracts. For example the ratio of (moving average of YM)/(moving average of ES) . Thanks in advance. H. Hampton. |
[2017-03-31 17:42:29] |
Yes this can be done. You need to add the Moving Average study to each of those charts and enable this option on the Moving Average studies: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DisplayAsMainPriceGraph Once that is done, then use the Ratio (Single Line) study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s85 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
