Date/Time: Mon, 06 May 2024 06:34:17 +0000
How to create shaded extended horizontal zone lines
View Count: 1992
[2017-03-30 02:17:25] |
This can be done with the Extending Rectangle drawing tool: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle In the Drawing Tool configuration: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Configuration you will want to enable: Options >> Double Extend Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-10 16:27:42] |
Ackin - Posts: 1865 |
User839892) Can it be any candle or must it be an H / L swing? |
