Date/Time: Wed, 15 May 2024 22:16:09 +0000
Deactivate on market close
View Count: 552
[2017-03-25 16:03:24] |
User612903 - Posts: 51 |
Hi, Is there a way to "disable" Sierra to receive quotes when the market is closed. For example this what I get for the US market on M1 INTC. I'd like to not receive thos empty quotes so my custom study does not trigger. Thank you for your help, Regards |
usmarket.JPG / V - Attached On 2017-03-25 16:02:22 UTC - Size: 30.08 KB - 223 views |
[2017-03-25 20:29:22] |
You need to adjust the Session Times to filter out the times you do not want to see in the chart: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
