Date/Time: Thu, 09 May 2024 01:50:03 +0000
switching symbols
View Count: 754
[2017-03-24 18:34:19] |
User57210 - Posts: 121 |
Hi, Long time experienced user here. Something seems to be glitching. version 1527, CTS FIX feed. I have several charts linked (link symbol) to a quoteboard. When I click a new symbol in the quoteboard to update the charts, it appears that everything loads fine just as normal. But then, about 5 seconds later, there is a glitch that prevents me from doing anything in SC for a few moments. It is connected with the historical daily bar data load. That chart recalculates again. In the message log, at the point of that timing after the initial good load, it APPEARS that it could be due to a new "unsubscribed from market depth data for [old symbol that i switched from] is popping up there, and then the daily data is recalculating back-adjustements and loading again. Let me know if you'd like to see this log. Date Time Of Last Edit: 2017-03-24 18:34:53
[2017-03-25 01:14:02] |
Yes provide the most recent 100 lines of the Message Log at the time this happens.
[2017-03-29 12:26:21] |
CL.20170500.CME_NY [CBV] 5 Min #9 | Reloading chart. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Intraday data file for symbol CL.20170300.CME_NY for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Intraday data file for symbol CL.20170400.CME_NY for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Intraday data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 0. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking Daily data file for symbol CLK17 for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Price data for daily data file CLK17.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4856 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Symbols used for continuous contract chart: | 2017-03-29 08:21:56 CLH17 | 2017-03-29 08:21:56 CLJ17 | 2017-03-29 08:21:56 CLK17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Checking for volume based rollover dates. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 5 Min #9 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Reloading chart. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Intraday data file for symbol CL.20170200.CME_NY for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Intraday data file for symbol CL.20170300.CME_NY for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Intraday data file for symbol CL.20170400.CME_NY for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Intraday data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 0. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking Daily data file for symbol CLK17 for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Price data for daily data file CLK17.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4856 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Symbols used for continuous contract chart: | 2017-03-29 08:21:56 CLG17 | 2017-03-29 08:21:56 CLH17 | 2017-03-29 08:21:56 CLJ17 | 2017-03-29 08:21:56 CLK17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Checking for volume based rollover dates. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 30 Min #11 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Reloading chart. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Symbols used for continuous contract chart: | 2017-03-29 08:21:56 CLQ15 | 2017-03-29 08:21:56 CLU15 | 2017-03-29 08:21:56 CLV15 | 2017-03-29 08:21:56 CLX15 | 2017-03-29 08:21:56 CLZ15 | 2017-03-29 08:21:56 CLF16 | 2017-03-29 08:21:56 CLG16 | 2017-03-29 08:21:56 CLH16 | 2017-03-29 08:21:56 CLJ16 | 2017-03-29 08:21:56 CLK16 | 2017-03-29 08:21:56 CLM16 | 2017-03-29 08:21:56 CLN16 | 2017-03-29 08:21:56 CLQ16 | 2017-03-29 08:21:56 CLU16 | 2017-03-29 08:21:56 CLV16 | 2017-03-29 08:21:56 CLX16 | 2017-03-29 08:21:56 CLZ16 | 2017-03-29 08:21:56 CLF17 | 2017-03-29 08:21:56 CLG17 | 2017-03-29 08:21:56 CLH17 | 2017-03-29 08:21:56 CLJ17 | 2017-03-29 08:21:56 CL.20170500.CME_NY | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Checking for volume based rollover dates. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:21:56 CL.20170500.CME_NY [CBV] 120 Min #12 | Reloading chart. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Intraday data file for symbol CL.20170200.CME_NY for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Intraday data file for symbol CL.20170300.CME_NY for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Intraday data file for symbol CL.20170400.CME_NY for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Intraday data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 0. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking Daily data file for symbol CLK17 for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Price data for daily data file CLK17.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4856 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Symbols used for continuous contract chart: | 2017-03-29 08:21:57 CLG17 | 2017-03-29 08:21:57 CLH17 | 2017-03-29 08:21:57 CLJ17 | 2017-03-29 08:21:57 CLK17 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Checking for volume based rollover dates. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 120 Min #12 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Reloading chart. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Intraday data file for symbol CL.20170300.CME_NY for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Intraday data file for symbol CL.20170400.CME_NY for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Intraday data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 0. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking Daily data file for symbol CLK17 for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Price data for daily data file CLK17.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4856 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Symbols used for continuous contract chart: | 2017-03-29 08:21:57 CLH17 | 2017-03-29 08:21:57 CLJ17 | 2017-03-29 08:21:57 CLK17 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Checking for volume based rollover dates. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:21:57 CL.20170500.CME_NY [CBV] 5 Min #13 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:21:57 Unsubscribed from market depth data for ES.20170600.CME_Eq | 2017-03-29 08:21:59 CL.20170500.CME_NY [CBV] Daily #10 | Reloading chart. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Symbols used for continuous contract chart: | 2017-03-29 08:22:06 CLQ15 | 2017-03-29 08:22:06 CLU15 | 2017-03-29 08:22:06 CLV15 | 2017-03-29 08:22:06 CLX15 | 2017-03-29 08:22:06 CLZ15 | 2017-03-29 08:22:06 CLF16 | 2017-03-29 08:22:06 CLG16 | 2017-03-29 08:22:06 CLH16 | 2017-03-29 08:22:06 CLJ16 | 2017-03-29 08:22:06 CLK16 | 2017-03-29 08:22:06 CLM16 | 2017-03-29 08:22:06 CLN16 | 2017-03-29 08:22:06 CLQ16 | 2017-03-29 08:22:06 CLU16 | 2017-03-29 08:22:06 CLV16 | 2017-03-29 08:22:06 CLX16 | 2017-03-29 08:22:06 CLZ16 | 2017-03-29 08:22:06 CLF17 | 2017-03-29 08:22:06 CLG17 | 2017-03-29 08:22:06 CLH17 | 2017-03-29 08:22:06 CLJ17 | 2017-03-29 08:22:06 CL.20170500.CME_NY | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Checking for volume based rollover dates. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:06 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:06 HD Request # 37 | Downloading Historical Daily chart data for CL.20170500.CME_NY. Starting date: 2017-03-28. Service: cts | 2017-03-29 08:22:07 HD Request # 37 | Requesting historical Daily data for CLK17 starting at 2017-03-27 | 2017-03-29 08:22:07 HTTP connection to ds01.ddfplus.com:80 (628) | Creating socket. | 2017-03-29 08:22:07 HD Request # 37 | Receiving historical Daily data for CL.20170500.CME_NY starting at 2017-03-28 | 2017-03-29 08:22:07 HD Request # 37 | Writing historical Daily data to the file CL.20170500.CME_NY.dly | 2017-03-29 08:22:07 HD Request # 37 | Received 3 records from 2017-03-28 00:00:00 to 2017-03-29 00:00:00 (2.0 days) and wrote 2 records for CL.20170500.CME_NY | 2017-03-29 08:22:07 HD Request # 37 | Daily download COMPLETE for CL.20170500.CME_NY. Completion time: 0s. Unique request ID: 35 | 2017-03-29 08:22:07 Removed historical data download ID 35 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Reloading chart. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Symbols used for continuous contract chart: | 2017-03-29 08:22:07 CLQ15 | 2017-03-29 08:22:07 CLU15 | 2017-03-29 08:22:07 CLV15 | 2017-03-29 08:22:07 CLX15 | 2017-03-29 08:22:07 CLZ15 | 2017-03-29 08:22:07 CLF16 | 2017-03-29 08:22:07 CLG16 | 2017-03-29 08:22:07 CLH16 | 2017-03-29 08:22:07 CLJ16 | 2017-03-29 08:22:07 CLK16 | 2017-03-29 08:22:07 CLM16 | 2017-03-29 08:22:07 CLN16 | 2017-03-29 08:22:07 CLQ16 | 2017-03-29 08:22:07 CLU16 | 2017-03-29 08:22:07 CLV16 | 2017-03-29 08:22:07 CLX16 | 2017-03-29 08:22:07 CLZ16 | 2017-03-29 08:22:07 CLF17 | 2017-03-29 08:22:07 CLG17 | 2017-03-29 08:22:07 CLH17 | 2017-03-29 08:22:07 CLJ17 | 2017-03-29 08:22:07 CL.20170500.CME_NY | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Checking for volume based rollover dates. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #10 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:07 CL.20170500.CME_NY [CBV] Daily #21 | Reloading chart. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20111000.CME_NY to next contract occurs at 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20111100.CME_NY to next contract occurs at 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20111200.CME_NY to next contract occurs at 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120100.CME_NY to next contract occurs at 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120200.CME_NY to next contract occurs at 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120300.CME_NY to next contract occurs at 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120400.CME_NY to next contract occurs at 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120500.CME_NY to next contract occurs at 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120600.CME_NY to next contract occurs at 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120700.CME_NY to next contract occurs at 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120800.CME_NY to next contract occurs at 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20120900.CME_NY to next contract occurs at 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20121000.CME_NY to next contract occurs at 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20121100.CME_NY to next contract occurs at 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20121200.CME_NY to next contract occurs at 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130100.CME_NY to next contract occurs at 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130200.CME_NY to next contract occurs at 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130300.CME_NY to next contract occurs at 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130400.CME_NY to next contract occurs at 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130500.CME_NY to next contract occurs at 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130600.CME_NY to next contract occurs at 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130700.CME_NY to next contract occurs at 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130800.CME_NY to next contract occurs at 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20130900.CME_NY to next contract occurs at 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20131000.CME_NY to next contract occurs at 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20131100.CME_NY to next contract occurs at 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20131200.CME_NY to next contract occurs at 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140100.CME_NY to next contract occurs at 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140200.CME_NY to next contract occurs at 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140300.CME_NY to next contract occurs at 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140400.CME_NY to next contract occurs at 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140500.CME_NY to next contract occurs at 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140600.CME_NY to next contract occurs at 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150700.CME_NY to next contract occurs at 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV11 for the date range from 2011-08-18 to 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX11 for the date range from 2011-09-16 to 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ11 for the date range from 2011-10-18 to 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF12 for the date range from 2011-11-18 to 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG12 for the date range from 2011-12-16 to 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH12 for the date range from 2012-01-18 to 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ12 for the date range from 2012-02-17 to 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLK12 for the date range from 2012-03-16 to 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLM12 for the date range from 2012-04-18 to 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLN12 for the date range from 2012-05-18 to 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLQ12 for the date range from 2012-06-18 to 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLU12 for the date range from 2012-07-18 to 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV12 for the date range from 2012-08-17 to 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX12 for the date range from 2012-09-18 to 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ12 for the date range from 2012-10-18 to 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF13 for the date range from 2012-11-16 to 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG13 for the date range from 2012-12-18 to 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH13 for the date range from 2013-01-18 to 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ13 for the date range from 2013-02-18 to 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLK13 for the date range from 2013-03-18 to 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLM13 for the date range from 2013-04-18 to 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLN13 for the date range from 2013-05-17 to 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLQ13 for the date range from 2013-06-18 to 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLU13 for the date range from 2013-07-18 to 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV13 for the date range from 2013-08-16 to 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX13 for the date range from 2013-09-18 to 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ13 for the date range from 2013-10-18 to 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF14 for the date range from 2013-11-18 to 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG14 for the date range from 2013-12-18 to 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH14 for the date range from 2014-01-17 to 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ14 for the date range from 2014-02-18 to 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLK14 for the date range from 2014-03-18 to 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLM14 for the date range from 2014-04-18 to 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLN14 for the date range from 2014-05-16 to 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLQ14 for the date range from 2014-06-18 to 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLU14 for the date range from 2014-07-18 to 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV14 for the date range from 2014-08-18 to 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX14 for the date range from 2014-09-18 to 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ14 for the date range from 2014-10-17 to 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF15 for the date range from 2014-11-18 to 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG15 for the date range from 2014-12-18 to 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH15 for the date range from 2015-01-16 to 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ15 for the date range from 2015-02-18 to 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLK15 for the date range from 2015-03-18 to 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLM15 for the date range from 2015-04-17 to 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLN15 for the date range from 2015-05-18 to 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLN15.dly. Date: 2015-05-18, Price: 6024. Date: 2015-06-17, Price: 5992 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLM15.dly. Date: 2015-04-17, Price: 5732. Date: 2015-05-15, Price: 5969 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLK15.dly. Date: 2015-03-18, Price: 4665. Date: 2015-04-16, Price: 5671 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ15.dly. Date: 2015-02-18, Price: 5282. Date: 2015-03-17, Price: 4346 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH15.dly. Date: 2015-01-16, Price: 4913. Date: 2015-02-17, Price: 5353 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG15.dly. Date: 2014-12-18, Price: 5436. Date: 2015-01-15, Price: 4625 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF15.dly. Date: 2014-11-18, Price: 7464. Date: 2014-12-17, Price: 5647 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ14.dly. Date: 2014-10-17, Price: 8206. Date: 2014-11-17, Price: 7564 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX14.dly. Date: 2014-09-18, Price: 9198. Date: 2014-10-16, Price: 8270 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV14.dly. Date: 2014-08-18, Price: 9375. Date: 2014-09-17, Price: 9442 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLU14.dly. Date: 2014-07-18, Price: 10195. Date: 2014-08-15, Price: 9735 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLQ14.dly. Date: 2014-06-18, Price: 10559. Date: 2014-07-17, Price: 10319 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLN14.dly. Date: 2014-05-16, Price: 10158. Date: 2014-06-17, Price: 10636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLM14.dly. Date: 2014-04-18, Price: 10365. Date: 2014-05-15, Price: 10150 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLK14.dly. Date: 2014-03-18, Price: 9888. Date: 2014-04-17, Price: 10430 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ14.dly. Date: 2014-02-18, Price: 10210. Date: 2014-03-17, Price: 9808 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH14.dly. Date: 2014-01-17, Price: 9459. Date: 2014-02-17, Price: 10243 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG14.dly. Date: 2013-12-18, Price: 9806. Date: 2014-01-16, Price: 9396 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF14.dly. Date: 2013-11-18, Price: 9368. Date: 2013-12-17, Price: 9722 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ13.dly. Date: 2013-10-18, Price: 10111. Date: 2013-11-15, Price: 9384 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX13.dly. Date: 2013-09-18, Price: 10728. Date: 2013-10-17, Price: 10067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV13.dly. Date: 2013-08-16, Price: 10729. Date: 2013-09-17, Price: 10542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLU13.dly. Date: 2013-07-18, Price: 10781. Date: 2013-08-15, Price: 10733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLQ13.dly. Date: 2013-06-18, Price: 9867. Date: 2013-07-17, Price: 10648 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLN13.dly. Date: 2013-05-17, Price: 9629. Date: 2013-06-17, Price: 9777 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLM13.dly. Date: 2013-04-18, Price: 8800. Date: 2013-05-16, Price: 9516 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLK13.dly. Date: 2013-03-18, Price: 9411. Date: 2013-04-17, Price: 8668 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ13.dly. Date: 2013-02-18, Price: 9710. Date: 2013-03-15, Price: 9345 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH13.dly. Date: 2013-01-18, Price: 9604. Date: 2013-02-15, Price: 9586 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG13.dly. Date: 2012-12-18, Price: 8840. Date: 2013-01-17, Price: 9549 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF13.dly. Date: 2012-11-16, Price: 8692. Date: 2012-12-17, Price: 8720 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ12.dly. Date: 2012-10-18, Price: 9253. Date: 2012-11-15, Price: 8545 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX12.dly. Date: 2012-09-18, Price: 9562. Date: 2012-10-17, Price: 9212 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV12.dly. Date: 2012-08-17, Price: 9632. Date: 2012-09-17, Price: 9662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLU12.dly. Date: 2012-07-18, Price: 9017. Date: 2012-08-16, Price: 9560 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLQ12.dly. Date: 2012-06-18, Price: 8360. Date: 2012-07-17, Price: 8922 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLN12.dly. Date: 2012-05-18, Price: 9180. Date: 2012-06-15, Price: 8403 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLM12.dly. Date: 2012-04-18, Price: 10312. Date: 2012-05-17, Price: 9256 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLK12.dly. Date: 2012-03-16, Price: 10758. Date: 2012-04-17, Price: 10420 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLJ12.dly. Date: 2012-02-17, Price: 10360. Date: 2012-03-15, Price: 10511 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLH12.dly. Date: 2012-01-18, Price: 10076. Date: 2012-02-16, Price: 10231 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLG12.dly. Date: 2011-12-16, Price: 9375. Date: 2012-01-17, Price: 10071 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLF12.dly. Date: 2011-11-18, Price: 9767. Date: 2011-12-15, Price: 9387 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLZ11.dly. Date: 2011-10-18, Price: 8853. Date: 2011-11-17, Price: 9882 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLX11.dly. Date: 2011-09-16, Price: 8818. Date: 2011-10-17, Price: 8638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Price data for daily data file CLV11.dly. Date: 2011-08-18, Price: 8251. Date: 2011-09-15, Price: 8940 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Symbols used for continuous contract chart: | 2017-03-29 08:22:08 CLV11 | 2017-03-29 08:22:08 CLX11 | 2017-03-29 08:22:08 CLZ11 | 2017-03-29 08:22:08 CLF12 | 2017-03-29 08:22:08 CLG12 | 2017-03-29 08:22:08 CLH12 | 2017-03-29 08:22:08 CLJ12 | 2017-03-29 08:22:08 CLK12 | 2017-03-29 08:22:08 CLM12 | 2017-03-29 08:22:08 CLN12 | 2017-03-29 08:22:08 CLQ12 | 2017-03-29 08:22:08 CLU12 | 2017-03-29 08:22:08 CLV12 | 2017-03-29 08:22:08 CLX12 | 2017-03-29 08:22:08 CLZ12 | 2017-03-29 08:22:08 CLF13 | 2017-03-29 08:22:08 CLG13 | 2017-03-29 08:22:08 CLH13 | 2017-03-29 08:22:08 CLJ13 | 2017-03-29 08:22:08 CLK13 | 2017-03-29 08:22:08 CLM13 | 2017-03-29 08:22:08 CLN13 | 2017-03-29 08:22:08 CLQ13 | 2017-03-29 08:22:08 CLU13 | 2017-03-29 08:22:08 CLV13 | 2017-03-29 08:22:08 CLX13 | 2017-03-29 08:22:08 CLZ13 | 2017-03-29 08:22:08 CLF14 | 2017-03-29 08:22:08 CLG14 | 2017-03-29 08:22:08 CLH14 | 2017-03-29 08:22:08 CLJ14 | 2017-03-29 08:22:08 CLK14 | 2017-03-29 08:22:08 CLM14 | 2017-03-29 08:22:08 CLN14 | 2017-03-29 08:22:08 CLQ14 | 2017-03-29 08:22:08 CLU14 | 2017-03-29 08:22:08 CLV14 | 2017-03-29 08:22:08 CLX14 | 2017-03-29 08:22:08 CLZ14 | 2017-03-29 08:22:08 CLF15 | 2017-03-29 08:22:08 CLG15 | 2017-03-29 08:22:08 CLH15 | 2017-03-29 08:22:08 CLJ15 | 2017-03-29 08:22:08 CLK15 | 2017-03-29 08:22:08 CLM15 | 2017-03-29 08:22:08 CLN15 | 2017-03-29 08:22:08 CLQ15 | 2017-03-29 08:22:08 CLU15 | 2017-03-29 08:22:08 CLV15 | 2017-03-29 08:22:08 CLX15 | 2017-03-29 08:22:08 CLZ15 | 2017-03-29 08:22:08 CLF16 | 2017-03-29 08:22:08 CLG16 | 2017-03-29 08:22:08 CLH16 | 2017-03-29 08:22:08 CLJ16 | 2017-03-29 08:22:08 CLK16 | 2017-03-29 08:22:08 CLM16 | 2017-03-29 08:22:08 CLN16 | 2017-03-29 08:22:08 CLQ16 | 2017-03-29 08:22:08 CLU16 | 2017-03-29 08:22:08 CLV16 | 2017-03-29 08:22:08 CLX16 | 2017-03-29 08:22:08 CLZ16 | 2017-03-29 08:22:08 CLF17 | 2017-03-29 08:22:08 CLG17 | 2017-03-29 08:22:08 CLH17 | 2017-03-29 08:22:08 CLJ17 | 2017-03-29 08:22:08 CL.20170500.CME_NY | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Checking for volume based rollover dates. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20111000.CME_NY to CL.20111100.CME_NY occurs at 2011-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20111100.CME_NY to CL.20111200.CME_NY occurs at 2011-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20111200.CME_NY to CL.20120100.CME_NY occurs at 2011-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120100.CME_NY to CL.20120200.CME_NY occurs at 2011-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120200.CME_NY to CL.20120300.CME_NY occurs at 2012-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120300.CME_NY to CL.20120400.CME_NY occurs at 2012-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120400.CME_NY to CL.20120500.CME_NY occurs at 2012-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120500.CME_NY to CL.20120600.CME_NY occurs at 2012-04-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120600.CME_NY to CL.20120700.CME_NY occurs at 2012-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120700.CME_NY to CL.20120800.CME_NY occurs at 2012-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120800.CME_NY to CL.20120900.CME_NY occurs at 2012-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20120900.CME_NY to CL.20121000.CME_NY occurs at 2012-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20121000.CME_NY to CL.20121100.CME_NY occurs at 2012-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20121100.CME_NY to CL.20121200.CME_NY occurs at 2012-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20121200.CME_NY to CL.20130100.CME_NY occurs at 2012-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130100.CME_NY to CL.20130200.CME_NY occurs at 2012-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130200.CME_NY to CL.20130300.CME_NY occurs at 2013-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130300.CME_NY to CL.20130400.CME_NY occurs at 2013-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130400.CME_NY to CL.20130500.CME_NY occurs at 2013-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130500.CME_NY to CL.20130600.CME_NY occurs at 2013-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130600.CME_NY to CL.20130700.CME_NY occurs at 2013-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130700.CME_NY to CL.20130800.CME_NY occurs at 2013-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130800.CME_NY to CL.20130900.CME_NY occurs at 2013-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20130900.CME_NY to CL.20131000.CME_NY occurs at 2013-08-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20131000.CME_NY to CL.20131100.CME_NY occurs at 2013-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20131100.CME_NY to CL.20131200.CME_NY occurs at 2013-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20131200.CME_NY to CL.20140100.CME_NY occurs at 2013-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140100.CME_NY to CL.20140200.CME_NY occurs at 2013-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140200.CME_NY to CL.20140300.CME_NY occurs at 2014-01-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140300.CME_NY to CL.20140400.CME_NY occurs at 2014-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140400.CME_NY to CL.20140500.CME_NY occurs at 2014-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140500.CME_NY to CL.20140600.CME_NY occurs at 2014-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140600.CME_NY to CL.20140700.CME_NY occurs at 2014-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150600.CME_NY to CL.20150700.CME_NY occurs at 2015-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150700.CME_NY to CL.20150800.CME_NY occurs at 2015-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111000.CME_NY Open price on 2011-09-19 is 8775. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111100.CME_NY Open price on 2011-09-19 is 8780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111000.CME_NY price difference to CL.20111100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111100.CME_NY Open price on 2011-10-18 is 8620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111200.CME_NY Open price on 2011-10-18 is 8630. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111100.CME_NY price difference to CL.20111200.CME_NY is 10. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111200.CME_NY Open price on 2011-11-17 is 10176. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120100.CME_NY Open price on 2011-11-17 is 10174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20111200.CME_NY price difference to CL.20120100.CME_NY is -2. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120100.CME_NY Open price on 2011-12-19 is 9376. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120200.CME_NY Open price on 2011-12-19 is 9377. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120100.CME_NY price difference to CL.20120200.CME_NY is 1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120200.CME_NY Open price on 2012-01-19 is 10114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120300.CME_NY Open price on 2012-01-19 is 10135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120200.CME_NY price difference to CL.20120300.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120300.CME_NY Open price on 2012-02-17 is 10235. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120400.CME_NY Open price on 2012-02-17 is 10264. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120300.CME_NY price difference to CL.20120400.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120400.CME_NY Open price on 2012-03-19 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120500.CME_NY Open price on 2012-03-19 is 10778. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120400.CME_NY price difference to CL.20120500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120500.CME_NY Open price on 2012-04-19 is 10273. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120600.CME_NY Open price on 2012-04-19 is 10321. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120500.CME_NY price difference to CL.20120600.CME_NY is 48. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120600.CME_NY Open price on 2012-05-21 is 9127. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120700.CME_NY Open price on 2012-05-21 is 9171. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120600.CME_NY price difference to CL.20120700.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120700.CME_NY Open price on 2012-06-19 is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120800.CME_NY Open price on 2012-06-19 is 8344. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120700.CME_NY price difference to CL.20120800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120800.CME_NY Open price on 2012-07-19 is 9008. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120900.CME_NY Open price on 2012-07-19 is 9035. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120800.CME_NY price difference to CL.20120900.CME_NY is 27. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120900.CME_NY Open price on 2012-08-20 is 9636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121000.CME_NY Open price on 2012-08-20 is 9664. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20120900.CME_NY price difference to CL.20121000.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121000.CME_NY Open price on 2012-09-19 is 9549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121100.CME_NY Open price on 2012-09-19 is 9583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121000.CME_NY price difference to CL.20121100.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121100.CME_NY Open price on 2012-10-19 is 9204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121200.CME_NY Open price on 2012-10-19 is 9248. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121100.CME_NY price difference to CL.20121200.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121200.CME_NY Open price on 2012-11-15 is 8636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130100.CME_NY Open price on 2012-11-15 is 8677. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20121200.CME_NY price difference to CL.20130100.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130100.CME_NY Open price on 2012-12-18 is 8745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130200.CME_NY Open price on 2012-12-18 is 8794. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130100.CME_NY price difference to CL.20130200.CME_NY is 49. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130200.CME_NY Open price on 2013-01-18 is 9519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130300.CME_NY Open price on 2013-01-18 is 9565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130200.CME_NY price difference to CL.20130300.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130300.CME_NY Open price on 2013-02-19 is 9597. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130400.CME_NY Open price on 2013-02-19 is 9639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130300.CME_NY price difference to CL.20130400.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130400.CME_NY Open price on 2013-03-18 is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130500.CME_NY Open price on 2013-03-18 is 9362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130400.CME_NY price difference to CL.20130500.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130500.CME_NY Open price on 2013-04-18 is 8639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130600.CME_NY Open price on 2013-04-18 is 8660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130500.CME_NY price difference to CL.20130600.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130600.CME_NY Open price on 2013-05-20 is 9593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130700.CME_NY Open price on 2013-05-20 is 9625. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130600.CME_NY price difference to CL.20130700.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130700.CME_NY Open price on 2013-06-18 is 9793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130800.CME_NY Open price on 2013-06-18 is 9816. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130700.CME_NY price difference to CL.20130800.CME_NY is 23. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130800.CME_NY Open price on 2013-07-18 is 10656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130900.CME_NY Open price on 2013-07-18 is 10635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130800.CME_NY price difference to CL.20130900.CME_NY is -21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130900.CME_NY Open price on 2013-08-16 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131000.CME_NY Open price on 2013-08-16 is 10701. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20130900.CME_NY price difference to CL.20131000.CME_NY is -17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131000.CME_NY Open price on 2013-09-18 is 10553. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131100.CME_NY Open price on 2013-09-18 is 10477. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131000.CME_NY price difference to CL.20131100.CME_NY is -76. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131100.CME_NY Open price on 2013-10-18 is 10072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131200.CME_NY Open price on 2013-10-18 is 10100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131100.CME_NY price difference to CL.20131200.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131200.CME_NY Open price on 2013-11-19 is 9300. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140100.CME_NY Open price on 2013-11-19 is 9364. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20131200.CME_NY price difference to CL.20140100.CME_NY is 64. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140100.CME_NY Open price on 2013-12-17 is 9730. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140200.CME_NY Open price on 2013-12-17 is 9754. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140100.CME_NY price difference to CL.20140200.CME_NY is 24. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140200.CME_NY Open price on 2014-01-17 is 9417. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140300.CME_NY Open price on 2014-01-17 is 9429. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140200.CME_NY price difference to CL.20140300.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140300.CME_NY Open price on 2014-02-18 is 10032. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140400.CME_NY Open price on 2014-02-18 is 10012. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140300.CME_NY price difference to CL.20140400.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140400.CME_NY Open price on 2014-03-18 is 9797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140500.CME_NY Open price on 2014-03-18 is 9746. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140400.CME_NY price difference to CL.20140500.CME_NY is -51. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140500.CME_NY Open price on 2014-04-21 is 10454. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140600.CME_NY Open price on 2014-04-21 is 10370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140500.CME_NY price difference to CL.20140600.CME_NY is -84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140600.CME_NY Open price on 2014-05-19 is 10213. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140700.CME_NY Open price on 2014-05-19 is 10168. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140600.CME_NY price difference to CL.20140700.CME_NY is -45. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140700.CME_NY Open price on 2014-06-18 is 10660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140800.CME_NY Open price on 2014-06-18 is 10606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -54. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140800.CME_NY Open price on 2014-07-18 is 10372. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140900.CME_NY Open price on 2014-07-18 is 10277. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -95. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140900.CME_NY Open price on 2014-08-18 is 9710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141000.CME_NY Open price on 2014-08-18 is 9514. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141000.CME_NY Open price on 2014-09-19 is 9297. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141100.CME_NY Open price on 2014-09-19 is 9196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -101. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141100.CME_NY Open price on 2014-10-17 is 8318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141200.CME_NY Open price on 2014-10-17 is 8240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -78. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141200.CME_NY Open price on 2014-11-18 is 7549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150100.CME_NY Open price on 2014-11-18 is 7554. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150100.CME_NY Open price on 2014-12-18 is 5583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150200.CME_NY Open price on 2014-12-18 is 5617. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150200.CME_NY Open price on 2015-01-16 is 4635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150300.CME_NY Open price on 2015-01-16 is 4673. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150300.CME_NY Open price on 2015-02-18 is 5324. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150400.CME_NY Open price on 2015-02-18 is 5405. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150400.CME_NY Open price on 2015-03-18 is 4251. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150500.CME_NY Open price on 2015-03-18 is 4450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150500.CME_NY Open price on 2015-04-17 is 5656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150600.CME_NY Open price on 2015-04-17 is 5797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 141. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150600.CME_NY Open price on 2015-05-18 is 5985. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150700.CME_NY Open price on 2015-05-18 is 6062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150600.CME_NY price difference to CL.20150700.CME_NY is 77. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150700.CME_NY Open price on 2015-06-19 is 6050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150800.CME_NY Open price on 2015-06-19 is 6088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150700.CME_NY price difference to CL.20150800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20111000.CME_NY is 2260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20111100.CME_NY is 2255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20111200.CME_NY is 2245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120100.CME_NY is 2247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120200.CME_NY is 2246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120300.CME_NY is 2225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120400.CME_NY is 2196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120500.CME_NY is 2136. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120600.CME_NY is 2088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120700.CME_NY is 2044. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120800.CME_NY is 2006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20120900.CME_NY is 1979. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20121000.CME_NY is 1951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20121100.CME_NY is 1917. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20121200.CME_NY is 1873. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130100.CME_NY is 1832. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130200.CME_NY is 1783. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130300.CME_NY is 1737. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130400.CME_NY is 1695. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130500.CME_NY is 1659. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130600.CME_NY is 1638. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130700.CME_NY is 1606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130800.CME_NY is 1583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20130900.CME_NY is 1604. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20131000.CME_NY is 1621. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20131100.CME_NY is 1697. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20131200.CME_NY is 1669. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140100.CME_NY is 1605. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140200.CME_NY is 1581. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140300.CME_NY is 1569. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140400.CME_NY is 1589. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140500.CME_NY is 1640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140600.CME_NY is 1724. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140700.CME_NY is 1769. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140800.CME_NY is 1823. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20140900.CME_NY is 1918. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20141000.CME_NY is 2114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20141100.CME_NY is 2215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20141200.CME_NY is 2293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150100.CME_NY is 2288. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150200.CME_NY is 2254. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150300.CME_NY is 2216. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150400.CME_NY is 2135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150500.CME_NY is 1936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150600.CME_NY is 1795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150700.CME_NY is 1718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #21 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Reloading chart. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20030700.CME_NY to next contract occurs at 2003-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20030800.CME_NY to next contract occurs at 2003-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20030900.CME_NY to next contract occurs at 2003-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20031000.CME_NY to next contract occurs at 2003-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20031100.CME_NY to next contract occurs at 2003-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20031200.CME_NY to next contract occurs at 2003-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040100.CME_NY to next contract occurs at 2003-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040200.CME_NY to next contract occurs at 2004-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040300.CME_NY to next contract occurs at 2004-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040400.CME_NY to next contract occurs at 2004-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040500.CME_NY to next contract occurs at 2004-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040600.CME_NY to next contract occurs at 2004-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040700.CME_NY to next contract occurs at 2004-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040800.CME_NY to next contract occurs at 2004-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20040900.CME_NY to next contract occurs at 2004-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20041000.CME_NY to next contract occurs at 2004-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20041100.CME_NY to next contract occurs at 2004-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20041200.CME_NY to next contract occurs at 2004-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050100.CME_NY to next contract occurs at 2004-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050200.CME_NY to next contract occurs at 2005-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050300.CME_NY to next contract occurs at 2005-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050400.CME_NY to next contract occurs at 2005-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050500.CME_NY to next contract occurs at 2005-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050600.CME_NY to next contract occurs at 2005-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050700.CME_NY to next contract occurs at 2005-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050800.CME_NY to next contract occurs at 2005-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20050900.CME_NY to next contract occurs at 2005-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20051000.CME_NY to next contract occurs at 2005-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20051100.CME_NY to next contract occurs at 2005-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20051200.CME_NY to next contract occurs at 2005-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060100.CME_NY to next contract occurs at 2005-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060200.CME_NY to next contract occurs at 2006-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060300.CME_NY to next contract occurs at 2006-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060400.CME_NY to next contract occurs at 2006-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060500.CME_NY to next contract occurs at 2006-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060600.CME_NY to next contract occurs at 2006-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060700.CME_NY to next contract occurs at 2006-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060800.CME_NY to next contract occurs at 2006-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20060900.CME_NY to next contract occurs at 2006-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20061000.CME_NY to next contract occurs at 2006-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20061100.CME_NY to next contract occurs at 2006-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20061200.CME_NY to next contract occurs at 2006-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070100.CME_NY to next contract occurs at 2006-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070200.CME_NY to next contract occurs at 2007-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070300.CME_NY to next contract occurs at 2007-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070400.CME_NY to next contract occurs at 2007-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070500.CME_NY to next contract occurs at 2007-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070600.CME_NY to next contract occurs at 2007-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070700.CME_NY to next contract occurs at 2007-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070800.CME_NY to next contract occurs at 2007-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20070900.CME_NY to next contract occurs at 2007-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20071000.CME_NY to next contract occurs at 2007-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20071100.CME_NY to next contract occurs at 2007-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20071200.CME_NY to next contract occurs at 2007-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080100.CME_NY to next contract occurs at 2007-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080200.CME_NY to next contract occurs at 2008-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080300.CME_NY to next contract occurs at 2008-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080400.CME_NY to next contract occurs at 2008-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080500.CME_NY to next contract occurs at 2008-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080600.CME_NY to next contract occurs at 2008-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080700.CME_NY to next contract occurs at 2008-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080800.CME_NY to next contract occurs at 2008-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20080900.CME_NY to next contract occurs at 2008-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20081000.CME_NY to next contract occurs at 2008-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20081100.CME_NY to next contract occurs at 2008-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20081200.CME_NY to next contract occurs at 2008-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090100.CME_NY to next contract occurs at 2008-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090200.CME_NY to next contract occurs at 2009-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090300.CME_NY to next contract occurs at 2009-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090400.CME_NY to next contract occurs at 2009-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090500.CME_NY to next contract occurs at 2009-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090600.CME_NY to next contract occurs at 2009-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090700.CME_NY to next contract occurs at 2009-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090800.CME_NY to next contract occurs at 2009-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20090900.CME_NY to next contract occurs at 2009-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20091000.CME_NY to next contract occurs at 2009-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20091100.CME_NY to next contract occurs at 2009-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20091200.CME_NY to next contract occurs at 2009-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100100.CME_NY to next contract occurs at 2009-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100200.CME_NY to next contract occurs at 2010-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100300.CME_NY to next contract occurs at 2010-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100400.CME_NY to next contract occurs at 2010-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100500.CME_NY to next contract occurs at 2010-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100600.CME_NY to next contract occurs at 2010-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100700.CME_NY to next contract occurs at 2010-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100800.CME_NY to next contract occurs at 2010-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20100900.CME_NY to next contract occurs at 2010-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20101000.CME_NY to next contract occurs at 2010-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20101100.CME_NY to next contract occurs at 2010-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20101200.CME_NY to next contract occurs at 2010-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110100.CME_NY to next contract occurs at 2010-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110200.CME_NY to next contract occurs at 2011-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110300.CME_NY to next contract occurs at 2011-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110400.CME_NY to next contract occurs at 2011-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110500.CME_NY to next contract occurs at 2011-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110600.CME_NY to next contract occurs at 2011-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110700.CME_NY to next contract occurs at 2011-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110800.CME_NY to next contract occurs at 2011-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20110900.CME_NY to next contract occurs at 2011-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20111000.CME_NY to next contract occurs at 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20111100.CME_NY to next contract occurs at 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20111200.CME_NY to next contract occurs at 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120100.CME_NY to next contract occurs at 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120200.CME_NY to next contract occurs at 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120300.CME_NY to next contract occurs at 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120400.CME_NY to next contract occurs at 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120500.CME_NY to next contract occurs at 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120600.CME_NY to next contract occurs at 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120700.CME_NY to next contract occurs at 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120800.CME_NY to next contract occurs at 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20120900.CME_NY to next contract occurs at 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20121000.CME_NY to next contract occurs at 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20121100.CME_NY to next contract occurs at 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20121200.CME_NY to next contract occurs at 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130100.CME_NY to next contract occurs at 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130200.CME_NY to next contract occurs at 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130300.CME_NY to next contract occurs at 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130400.CME_NY to next contract occurs at 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130500.CME_NY to next contract occurs at 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130600.CME_NY to next contract occurs at 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130700.CME_NY to next contract occurs at 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130800.CME_NY to next contract occurs at 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20130900.CME_NY to next contract occurs at 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20131000.CME_NY to next contract occurs at 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20131100.CME_NY to next contract occurs at 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20131200.CME_NY to next contract occurs at 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140100.CME_NY to next contract occurs at 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140200.CME_NY to next contract occurs at 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140300.CME_NY to next contract occurs at 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140400.CME_NY to next contract occurs at 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140500.CME_NY to next contract occurs at 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140600.CME_NY to next contract occurs at 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150700.CME_NY to next contract occurs at 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN03 for the date range from 2003-05-16 to 2003-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ03 for the date range from 2003-06-18 to 2003-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU03 for the date range from 2003-07-18 to 2003-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV03 for the date range from 2003-08-18 to 2003-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX03 for the date range from 2003-09-18 to 2003-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ03 for the date range from 2003-10-17 to 2003-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF04 for the date range from 2003-11-18 to 2003-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG04 for the date range from 2003-12-18 to 2004-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH04 for the date range from 2004-01-16 to 2004-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ04 for the date range from 2004-02-18 to 2004-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK04 for the date range from 2004-03-18 to 2004-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM04 for the date range from 2004-04-16 to 2004-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN04 for the date range from 2004-05-18 to 2004-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ04 for the date range from 2004-06-18 to 2004-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU04 for the date range from 2004-07-16 to 2004-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV04 for the date range from 2004-08-18 to 2004-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX04 for the date range from 2004-09-17 to 2004-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ04 for the date range from 2004-10-18 to 2004-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF05 for the date range from 2004-11-18 to 2004-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG05 for the date range from 2004-12-17 to 2005-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH05 for the date range from 2005-01-18 to 2005-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ05 for the date range from 2005-02-18 to 2005-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK05 for the date range from 2005-03-18 to 2005-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM05 for the date range from 2005-04-18 to 2005-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN05 for the date range from 2005-05-18 to 2005-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ05 for the date range from 2005-06-17 to 2005-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU05 for the date range from 2005-07-18 to 2005-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV05 for the date range from 2005-08-18 to 2005-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX05 for the date range from 2005-09-16 to 2005-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ05 for the date range from 2005-10-18 to 2005-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF06 for the date range from 2005-11-18 to 2005-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG06 for the date range from 2005-12-16 to 2006-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH06 for the date range from 2006-01-18 to 2006-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ06 for the date range from 2006-02-17 to 2006-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK06 for the date range from 2006-03-17 to 2006-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM06 for the date range from 2006-04-18 to 2006-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN06 for the date range from 2006-05-18 to 2006-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ06 for the date range from 2006-06-16 to 2006-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU06 for the date range from 2006-07-18 to 2006-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV06 for the date range from 2006-08-18 to 2006-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX06 for the date range from 2006-09-18 to 2006-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ06 for the date range from 2006-10-18 to 2006-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF07 for the date range from 2006-11-17 to 2006-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG07 for the date range from 2006-12-18 to 2007-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH07 for the date range from 2007-01-18 to 2007-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ07 for the date range from 2007-02-16 to 2007-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK07 for the date range from 2007-03-16 to 2007-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM07 for the date range from 2007-04-18 to 2007-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN07 for the date range from 2007-05-18 to 2007-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ07 for the date range from 2007-06-18 to 2007-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU07 for the date range from 2007-07-18 to 2007-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV07 for the date range from 2007-08-17 to 2007-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX07 for the date range from 2007-09-18 to 2007-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ07 for the date range from 2007-10-18 to 2007-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF08 for the date range from 2007-11-16 to 2007-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG08 for the date range from 2007-12-18 to 2008-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH08 for the date range from 2008-01-18 to 2008-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ08 for the date range from 2008-02-18 to 2008-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK08 for the date range from 2008-03-18 to 2008-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM08 for the date range from 2008-04-18 to 2008-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN08 for the date range from 2008-05-16 to 2008-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ08 for the date range from 2008-06-18 to 2008-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU08 for the date range from 2008-07-18 to 2008-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV08 for the date range from 2008-08-18 to 2008-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX08 for the date range from 2008-09-18 to 2008-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ08 for the date range from 2008-10-17 to 2008-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF09 for the date range from 2008-11-18 to 2008-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG09 for the date range from 2008-12-18 to 2009-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH09 for the date range from 2009-01-16 to 2009-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ09 for the date range from 2009-02-18 to 2009-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK09 for the date range from 2009-03-18 to 2009-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM09 for the date range from 2009-04-17 to 2009-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN09 for the date range from 2009-05-18 to 2009-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ09 for the date range from 2009-06-18 to 2009-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU09 for the date range from 2009-07-17 to 2009-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV09 for the date range from 2009-08-18 to 2009-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX09 for the date range from 2009-09-18 to 2009-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ09 for the date range from 2009-10-16 to 2009-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF10 for the date range from 2009-11-18 to 2009-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG10 for the date range from 2009-12-18 to 2010-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH10 for the date range from 2010-01-18 to 2010-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ10 for the date range from 2010-02-18 to 2010-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK10 for the date range from 2010-03-18 to 2010-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM10 for the date range from 2010-04-16 to 2010-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN10 for the date range from 2010-05-18 to 2010-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ10 for the date range from 2010-06-18 to 2010-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU10 for the date range from 2010-07-16 to 2010-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV10 for the date range from 2010-08-18 to 2010-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX10 for the date range from 2010-09-17 to 2010-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ10 for the date range from 2010-10-18 to 2010-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF11 for the date range from 2010-11-18 to 2010-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG11 for the date range from 2010-12-17 to 2011-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH11 for the date range from 2011-01-18 to 2011-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ11 for the date range from 2011-02-18 to 2011-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK11 for the date range from 2011-03-18 to 2011-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM11 for the date range from 2011-04-18 to 2011-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN11 for the date range from 2011-05-18 to 2011-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ11 for the date range from 2011-06-17 to 2011-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU11 for the date range from 2011-07-18 to 2011-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV11 for the date range from 2011-08-18 to 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX11 for the date range from 2011-09-16 to 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ11 for the date range from 2011-10-18 to 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF12 for the date range from 2011-11-18 to 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG12 for the date range from 2011-12-16 to 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH12 for the date range from 2012-01-18 to 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ12 for the date range from 2012-02-17 to 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK12 for the date range from 2012-03-16 to 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM12 for the date range from 2012-04-18 to 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN12 for the date range from 2012-05-18 to 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ12 for the date range from 2012-06-18 to 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU12 for the date range from 2012-07-18 to 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV12 for the date range from 2012-08-17 to 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX12 for the date range from 2012-09-18 to 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ12 for the date range from 2012-10-18 to 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF13 for the date range from 2012-11-16 to 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG13 for the date range from 2012-12-18 to 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH13 for the date range from 2013-01-18 to 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ13 for the date range from 2013-02-18 to 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK13 for the date range from 2013-03-18 to 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM13 for the date range from 2013-04-18 to 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN13 for the date range from 2013-05-17 to 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ13 for the date range from 2013-06-18 to 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU13 for the date range from 2013-07-18 to 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV13 for the date range from 2013-08-16 to 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX13 for the date range from 2013-09-18 to 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ13 for the date range from 2013-10-18 to 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF14 for the date range from 2013-11-18 to 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG14 for the date range from 2013-12-18 to 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH14 for the date range from 2014-01-17 to 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ14 for the date range from 2014-02-18 to 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK14 for the date range from 2014-03-18 to 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM14 for the date range from 2014-04-18 to 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN14 for the date range from 2014-05-16 to 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ14 for the date range from 2014-06-18 to 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU14 for the date range from 2014-07-18 to 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV14 for the date range from 2014-08-18 to 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX14 for the date range from 2014-09-18 to 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ14 for the date range from 2014-10-17 to 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF15 for the date range from 2014-11-18 to 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG15 for the date range from 2014-12-18 to 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH15 for the date range from 2015-01-16 to 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ15 for the date range from 2015-02-18 to 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK15 for the date range from 2015-03-18 to 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM15 for the date range from 2015-04-17 to 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN15 for the date range from 2015-05-18 to 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN15.dly. Date: 2015-05-18, Price: 6024. Date: 2015-06-17, Price: 5992 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM15.dly. Date: 2015-04-17, Price: 5732. Date: 2015-05-15, Price: 5969 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK15.dly. Date: 2015-03-18, Price: 4665. Date: 2015-04-16, Price: 5671 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ15.dly. Date: 2015-02-18, Price: 5282. Date: 2015-03-17, Price: 4346 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH15.dly. Date: 2015-01-16, Price: 4913. Date: 2015-02-17, Price: 5353 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG15.dly. Date: 2014-12-18, Price: 5436. Date: 2015-01-15, Price: 4625 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF15.dly. Date: 2014-11-18, Price: 7464. Date: 2014-12-17, Price: 5647 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ14.dly. Date: 2014-10-17, Price: 8206. Date: 2014-11-17, Price: 7564 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX14.dly. Date: 2014-09-18, Price: 9198. Date: 2014-10-16, Price: 8270 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV14.dly. Date: 2014-08-18, Price: 9375. Date: 2014-09-17, Price: 9442 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU14.dly. Date: 2014-07-18, Price: 10195. Date: 2014-08-15, Price: 9735 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ14.dly. Date: 2014-06-18, Price: 10559. Date: 2014-07-17, Price: 10319 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN14.dly. Date: 2014-05-16, Price: 10158. Date: 2014-06-17, Price: 10636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM14.dly. Date: 2014-04-18, Price: 10365. Date: 2014-05-15, Price: 10150 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK14.dly. Date: 2014-03-18, Price: 9888. Date: 2014-04-17, Price: 10430 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ14.dly. Date: 2014-02-18, Price: 10210. Date: 2014-03-17, Price: 9808 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH14.dly. Date: 2014-01-17, Price: 9459. Date: 2014-02-17, Price: 10243 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG14.dly. Date: 2013-12-18, Price: 9806. Date: 2014-01-16, Price: 9396 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF14.dly. Date: 2013-11-18, Price: 9368. Date: 2013-12-17, Price: 9722 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ13.dly. Date: 2013-10-18, Price: 10111. Date: 2013-11-15, Price: 9384 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX13.dly. Date: 2013-09-18, Price: 10728. Date: 2013-10-17, Price: 10067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV13.dly. Date: 2013-08-16, Price: 10729. Date: 2013-09-17, Price: 10542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU13.dly. Date: 2013-07-18, Price: 10781. Date: 2013-08-15, Price: 10733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ13.dly. Date: 2013-06-18, Price: 9867. Date: 2013-07-17, Price: 10648 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN13.dly. Date: 2013-05-17, Price: 9629. Date: 2013-06-17, Price: 9777 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM13.dly. Date: 2013-04-18, Price: 8800. Date: 2013-05-16, Price: 9516 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK13.dly. Date: 2013-03-18, Price: 9411. Date: 2013-04-17, Price: 8668 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ13.dly. Date: 2013-02-18, Price: 9710. Date: 2013-03-15, Price: 9345 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH13.dly. Date: 2013-01-18, Price: 9604. Date: 2013-02-15, Price: 9586 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG13.dly. Date: 2012-12-18, Price: 8840. Date: 2013-01-17, Price: 9549 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF13.dly. Date: 2012-11-16, Price: 8692. Date: 2012-12-17, Price: 8720 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ12.dly. Date: 2012-10-18, Price: 9253. Date: 2012-11-15, Price: 8545 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX12.dly. Date: 2012-09-18, Price: 9562. Date: 2012-10-17, Price: 9212 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV12.dly. Date: 2012-08-17, Price: 9632. Date: 2012-09-17, Price: 9662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU12.dly. Date: 2012-07-18, Price: 9017. Date: 2012-08-16, Price: 9560 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ12.dly. Date: 2012-06-18, Price: 8360. Date: 2012-07-17, Price: 8922 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN12.dly. Date: 2012-05-18, Price: 9180. Date: 2012-06-15, Price: 8403 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM12.dly. Date: 2012-04-18, Price: 10312. Date: 2012-05-17, Price: 9256 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK12.dly. Date: 2012-03-16, Price: 10758. Date: 2012-04-17, Price: 10420 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ12.dly. Date: 2012-02-17, Price: 10360. Date: 2012-03-15, Price: 10511 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH12.dly. Date: 2012-01-18, Price: 10076. Date: 2012-02-16, Price: 10231 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG12.dly. Date: 2011-12-16, Price: 9375. Date: 2012-01-17, Price: 10071 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF12.dly. Date: 2011-11-18, Price: 9767. Date: 2011-12-15, Price: 9387 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ11.dly. Date: 2011-10-18, Price: 8853. Date: 2011-11-17, Price: 9882 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX11.dly. Date: 2011-09-16, Price: 8818. Date: 2011-10-17, Price: 8638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV11.dly. Date: 2011-08-18, Price: 8251. Date: 2011-09-15, Price: 8940 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU11.dly. Date: 2011-07-18, Price: 9625. Date: 2011-08-17, Price: 8758 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ11.dly. Date: 2011-06-17, Price: 9340. Date: 2011-07-15, Price: 9724 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN11.dly. Date: 2011-05-18, Price: 10056. Date: 2011-06-16, Price: 9495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM11.dly. Date: 2011-04-18, Price: 10769. Date: 2011-05-17, Price: 9691 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK11.dly. Date: 2011-03-18, Price: 10185. Date: 2011-04-15, Price: 10966 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ11.dly. Date: 2011-02-18, Price: 8971. Date: 2011-03-17, Price: 10142 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH11.dly. Date: 2011-01-18, Price: 9231. Date: 2011-02-17, Price: 8636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG11.dly. Date: 2010-12-17, Price: 8860. Date: 2011-01-17, Price: 9138 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF11.dly. Date: 2010-11-18, Price: 8242. Date: 2010-12-16, Price: 8770 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ10.dly. Date: 2010-10-18, Price: 8380. Date: 2010-11-17, Price: 8044 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX10.dly. Date: 2010-09-17, Price: 7492. Date: 2010-10-15, Price: 8125 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV10.dly. Date: 2010-08-18, Price: 7578. Date: 2010-09-16, Price: 7457 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU10.dly. Date: 2010-07-16, Price: 7638. Date: 2010-08-17, Price: 7577 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ10.dly. Date: 2010-06-18, Price: 7826. Date: 2010-07-15, Price: 7662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN10.dly. Date: 2010-05-18, Price: 7270. Date: 2010-06-17, Price: 7679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM10.dly. Date: 2010-04-16, Price: 8467. Date: 2010-05-17, Price: 7008 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK10.dly. Date: 2010-03-18, Price: 8254. Date: 2010-04-15, Price: 8551 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ10.dly. Date: 2010-02-18, Price: 7942. Date: 2010-03-17, Price: 8293 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH10.dly. Date: 2010-01-18, Price: 7932. Date: 2010-02-17, Price: 7733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG10.dly. Date: 2009-12-18, Price: 7442. Date: 2010-01-15, Price: 7800 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF10.dly. Date: 2009-11-18, Price: 8010. Date: 2009-12-17, Price: 7265 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ09.dly. Date: 2009-10-16, Price: 7902. Date: 2009-11-17, Price: 7914 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX09.dly. Date: 2009-09-18, Price: 7249. Date: 2009-10-15, Price: 7758 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV09.dly. Date: 2009-08-18, Price: 7109. Date: 2009-09-17, Price: 7247 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU09.dly. Date: 2009-07-17, Price: 6458. Date: 2009-08-17, Price: 6675 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ09.dly. Date: 2009-06-18, Price: 7191. Date: 2009-07-16, Price: 6202 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN09.dly. Date: 2009-05-18, Price: 5959. Date: 2009-06-17, Price: 7103 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM09.dly. Date: 2009-04-17, Price: 5247. Date: 2009-05-15, Price: 5634 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK09.dly. Date: 2009-03-18, Price: 4890. Date: 2009-04-16, Price: 4998 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ09.dly. Date: 2009-02-18, Price: 3741. Date: 2009-03-17, Price: 4916 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH09.dly. Date: 2009-01-16, Price: 4257. Date: 2009-02-17, Price: 3493 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG09.dly. Date: 2008-12-18, Price: 4167. Date: 2009-01-15, Price: 3540 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF09.dly. Date: 2008-11-18, Price: 5476. Date: 2008-12-17, Price: 4006 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ08.dly. Date: 2008-10-17, Price: 7213. Date: 2008-11-17, Price: 5495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX08.dly. Date: 2008-09-18, Price: 9754. Date: 2008-10-16, Price: 6985 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV08.dly. Date: 2008-08-18, Price: 11289. Date: 2008-09-17, Price: 9716 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU08.dly. Date: 2008-07-18, Price: 12947. Date: 2008-08-15, Price: 11377 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ08.dly. Date: 2008-06-18, Price: 13717. Date: 2008-07-17, Price: 12929 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN08.dly. Date: 2008-05-16, Price: 12604. Date: 2008-06-17, Price: 13401 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM08.dly. Date: 2008-04-18, Price: 11616. Date: 2008-05-15, Price: 12412 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK08.dly. Date: 2008-03-18, Price: 10850. Date: 2008-04-17, Price: 11486 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ08.dly. Date: 2008-02-18, Price: 9970. Date: 2008-03-17, Price: 10568 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH08.dly. Date: 2008-01-18, Price: 8992. Date: 2008-02-15, Price: 9550 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG08.dly. Date: 2007-12-18, Price: 9008. Date: 2008-01-17, Price: 9013 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF08.dly. Date: 2007-11-16, Price: 9384. Date: 2007-12-17, Price: 9063 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ07.dly. Date: 2007-10-18, Price: 8804. Date: 2007-11-15, Price: 9343 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX07.dly. Date: 2007-09-18, Price: 8023. Date: 2007-10-17, Price: 8740 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV07.dly. Date: 2007-08-17, Price: 7182. Date: 2007-09-17, Price: 8057 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU07.dly. Date: 2007-07-18, Price: 7530. Date: 2007-08-16, Price: 7100 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ07.dly. Date: 2007-06-18, Price: 6962. Date: 2007-07-17, Price: 7402 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN07.dly. Date: 2007-05-18, Price: 6598. Date: 2007-06-15, Price: 6800 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM07.dly. Date: 2007-04-18, Price: 6438. Date: 2007-05-17, Price: 6486 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK07.dly. Date: 2007-03-16, Price: 5958. Date: 2007-04-17, Price: 6310 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ07.dly. Date: 2007-02-16, Price: 5986. Date: 2007-03-15, Price: 5755 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH07.dly. Date: 2007-01-18, Price: 5181. Date: 2007-02-15, Price: 5799 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG07.dly. Date: 2006-12-18, Price: 6279. Date: 2007-01-17, Price: 5224 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF07.dly. Date: 2006-11-17, Price: 5897. Date: 2006-12-15, Price: 6343 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ06.dly. Date: 2006-10-18, Price: 5930. Date: 2006-11-16, Price: 5626 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX06.dly. Date: 2006-09-18, Price: 6445. Date: 2006-10-17, Price: 5893 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV06.dly. Date: 2006-08-18, Price: 7210. Date: 2006-09-15, Price: 6333 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU06.dly. Date: 2006-07-18, Price: 7526. Date: 2006-08-17, Price: 7006 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ06.dly. Date: 2006-06-16, Price: 7020. Date: 2006-07-17, Price: 7530 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN06.dly. Date: 2006-05-18, Price: 7014. Date: 2006-06-15, Price: 6950 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM06.dly. Date: 2006-04-18, Price: 7309. Date: 2006-05-17, Price: 6869 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK06.dly. Date: 2006-03-17, Price: 6420. Date: 2006-04-17, Price: 7040 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ06.dly. Date: 2006-02-17, Price: 6129. Date: 2006-03-16, Price: 6358 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH06.dly. Date: 2006-01-18, Price: 6625. Date: 2006-02-16, Price: 5846 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG06.dly. Date: 2005-12-16, Price: 5905. Date: 2006-01-17, Price: 6631 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF06.dly. Date: 2005-11-18, Price: 5721. Date: 2005-12-15, Price: 5999 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ05.dly. Date: 2005-10-18, Price: 6244. Date: 2005-11-17, Price: 5634 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX05.dly. Date: 2005-09-16, Price: 6334. Date: 2005-10-17, Price: 6436 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV05.dly. Date: 2005-08-18, Price: 6377. Date: 2005-09-15, Price: 6475 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU05.dly. Date: 2005-07-18, Price: 5842. Date: 2005-08-17, Price: 6325 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ05.dly. Date: 2005-06-17, Price: 5918. Date: 2005-07-15, Price: 5809 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN05.dly. Date: 2005-05-18, Price: 4913. Date: 2005-06-16, Price: 5658 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM05.dly. Date: 2005-04-18, Price: 5147. Date: 2005-05-17, Price: 4897 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK05.dly. Date: 2005-03-18, Price: 5724. Date: 2005-04-15, Price: 5049 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ05.dly. Date: 2005-02-18, Price: 4901. Date: 2005-03-17, Price: 5640 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH05.dly. Date: 2005-01-18, Price: 4848. Date: 2005-02-17, Price: 4754 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG05.dly. Date: 2004-12-17, Price: 4657. Date: 2005-01-17, Price: 4838 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF05.dly. Date: 2004-11-18, Price: 4638. Date: 2004-12-16, Price: 4418 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ04.dly. Date: 2004-10-18, Price: 5284. Date: 2004-11-17, Price: 4684 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX04.dly. Date: 2004-09-17, Price: 4559. Date: 2004-10-15, Price: 5493 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV04.dly. Date: 2004-08-18, Price: 4635. Date: 2004-09-16, Price: 4388 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU04.dly. Date: 2004-07-16, Price: 4130. Date: 2004-08-17, Price: 4675 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ04.dly. Date: 2004-06-18, Price: 3900. Date: 2004-07-15, Price: 4077 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN04.dly. Date: 2004-05-18, Price: 4042. Date: 2004-06-17, Price: 3846 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLM04.dly. Date: 2004-04-16, Price: 3699. Date: 2004-05-17, Price: 4155 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLK04.dly. Date: 2004-03-18, Price: 3739. Date: 2004-04-15, Price: 3757 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLJ04.dly. Date: 2004-02-18, Price: 3448. Date: 2004-03-17, Price: 3818 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLH04.dly. Date: 2004-01-16, Price: 3400. Date: 2004-02-17, Price: 3519 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLG04.dly. Date: 2003-12-18, Price: 3375. Date: 2004-01-15, Price: 3344 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLF04.dly. Date: 2003-11-18, Price: 3270. Date: 2003-12-17, Price: 3335 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLZ03.dly. Date: 2003-10-17, Price: 3070. Date: 2003-11-17, Price: 3173 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLX03.dly. Date: 2003-09-18, Price: 2724. Date: 2003-10-16, Price: 3154 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLV03.dly. Date: 2003-08-18, Price: 3088. Date: 2003-09-17, Price: 2703 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLU03.dly. Date: 2003-07-18, Price: 3103. Date: 2003-08-15, Price: 3105 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLQ03.dly. Date: 2003-06-18, Price: 2877. Date: 2003-07-17, Price: 3141 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Price data for daily data file CLN03.dly. Date: 2003-05-16, Price: 2875. Date: 2003-06-17, Price: 3107 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Symbols used for continuous contract chart: | 2017-03-29 08:22:08 CLN03 | 2017-03-29 08:22:08 CLQ03 | 2017-03-29 08:22:08 CLU03 | 2017-03-29 08:22:08 CLV03 | 2017-03-29 08:22:08 CLX03 | 2017-03-29 08:22:08 CLZ03 | 2017-03-29 08:22:08 CLF04 | 2017-03-29 08:22:08 CLG04 | 2017-03-29 08:22:08 CLH04 | 2017-03-29 08:22:08 CLJ04 | 2017-03-29 08:22:08 CLK04 | 2017-03-29 08:22:08 CLM04 | 2017-03-29 08:22:08 CLN04 | 2017-03-29 08:22:08 CLQ04 | 2017-03-29 08:22:08 CLU04 | 2017-03-29 08:22:08 CLV04 | 2017-03-29 08:22:08 CLX04 | 2017-03-29 08:22:08 CLZ04 | 2017-03-29 08:22:08 CLF05 | 2017-03-29 08:22:08 CLG05 | 2017-03-29 08:22:08 CLH05 | 2017-03-29 08:22:08 CLJ05 | 2017-03-29 08:22:08 CLK05 | 2017-03-29 08:22:08 CLM05 | 2017-03-29 08:22:08 CLN05 | 2017-03-29 08:22:08 CLQ05 | 2017-03-29 08:22:08 CLU05 | 2017-03-29 08:22:08 CLV05 | 2017-03-29 08:22:08 CLX05 | 2017-03-29 08:22:08 CLZ05 | 2017-03-29 08:22:08 CLF06 | 2017-03-29 08:22:08 CLG06 | 2017-03-29 08:22:08 CLH06 | 2017-03-29 08:22:08 CLJ06 | 2017-03-29 08:22:08 CLK06 | 2017-03-29 08:22:08 CLM06 | 2017-03-29 08:22:08 CLN06 | 2017-03-29 08:22:08 CLQ06 | 2017-03-29 08:22:08 CLU06 | 2017-03-29 08:22:08 CLV06 | 2017-03-29 08:22:08 CLX06 | 2017-03-29 08:22:08 CLZ06 | 2017-03-29 08:22:08 CLF07 | 2017-03-29 08:22:08 CLG07 | 2017-03-29 08:22:08 CLH07 | 2017-03-29 08:22:08 CLJ07 | 2017-03-29 08:22:08 CLK07 | 2017-03-29 08:22:08 CLM07 | 2017-03-29 08:22:08 CLN07 | 2017-03-29 08:22:08 CLQ07 | 2017-03-29 08:22:08 CLU07 | 2017-03-29 08:22:08 CLV07 | 2017-03-29 08:22:08 CLX07 | 2017-03-29 08:22:08 CLZ07 | 2017-03-29 08:22:08 CLF08 | 2017-03-29 08:22:08 CLG08 | 2017-03-29 08:22:08 CLH08 | 2017-03-29 08:22:08 CLJ08 | 2017-03-29 08:22:08 CLK08 | 2017-03-29 08:22:08 CLM08 | 2017-03-29 08:22:08 CLN08 | 2017-03-29 08:22:08 CLQ08 | 2017-03-29 08:22:08 CLU08 | 2017-03-29 08:22:08 CLV08 | 2017-03-29 08:22:08 CLX08 | 2017-03-29 08:22:08 CLZ08 | 2017-03-29 08:22:08 CLF09 | 2017-03-29 08:22:08 CLG09 | 2017-03-29 08:22:08 CLH09 | 2017-03-29 08:22:08 CLJ09 | 2017-03-29 08:22:08 CLK09 | 2017-03-29 08:22:08 CLM09 | 2017-03-29 08:22:08 CLN09 | 2017-03-29 08:22:08 CLQ09 | 2017-03-29 08:22:08 CLU09 | 2017-03-29 08:22:08 CLV09 | 2017-03-29 08:22:08 CLX09 | 2017-03-29 08:22:08 CLZ09 | 2017-03-29 08:22:08 CLF10 | 2017-03-29 08:22:08 CLG10 | 2017-03-29 08:22:08 CLH10 | 2017-03-29 08:22:08 CLJ10 | 2017-03-29 08:22:08 CLK10 | 2017-03-29 08:22:08 CLM10 | 2017-03-29 08:22:08 CLN10 | 2017-03-29 08:22:08 CLQ10 | 2017-03-29 08:22:08 CLU10 | 2017-03-29 08:22:08 CLV10 | 2017-03-29 08:22:08 CLX10 | 2017-03-29 08:22:08 CLZ10 | 2017-03-29 08:22:08 CLF11 | 2017-03-29 08:22:08 CLG11 | 2017-03-29 08:22:08 CLH11 | 2017-03-29 08:22:08 CLJ11 | 2017-03-29 08:22:08 CLK11 | 2017-03-29 08:22:08 CLM11 | 2017-03-29 08:22:08 CLN11 | 2017-03-29 08:22:08 CLQ11 | 2017-03-29 08:22:08 CLU11 | 2017-03-29 08:22:08 CLV11 | 2017-03-29 08:22:08 CLX11 | 2017-03-29 08:22:08 CLZ11 | 2017-03-29 08:22:08 CLF12 | 2017-03-29 08:22:08 CLG12 | 2017-03-29 08:22:08 CLH12 | 2017-03-29 08:22:08 CLJ12 | 2017-03-29 08:22:08 CLK12 | 2017-03-29 08:22:08 CLM12 | 2017-03-29 08:22:08 CLN12 | 2017-03-29 08:22:08 CLQ12 | 2017-03-29 08:22:08 CLU12 | 2017-03-29 08:22:08 CLV12 | 2017-03-29 08:22:08 CLX12 | 2017-03-29 08:22:08 CLZ12 | 2017-03-29 08:22:08 CLF13 | 2017-03-29 08:22:08 CLG13 | 2017-03-29 08:22:08 CLH13 | 2017-03-29 08:22:08 CLJ13 | 2017-03-29 08:22:08 CLK13 | 2017-03-29 08:22:08 CLM13 | 2017-03-29 08:22:08 CLN13 | 2017-03-29 08:22:08 CLQ13 | 2017-03-29 08:22:08 CLU13 | 2017-03-29 08:22:08 CLV13 | 2017-03-29 08:22:08 CLX13 | 2017-03-29 08:22:08 CLZ13 | 2017-03-29 08:22:08 CLF14 | 2017-03-29 08:22:08 CLG14 | 2017-03-29 08:22:08 CLH14 | 2017-03-29 08:22:08 CLJ14 | 2017-03-29 08:22:08 CLK14 | 2017-03-29 08:22:08 CLM14 | 2017-03-29 08:22:08 CLN14 | 2017-03-29 08:22:08 CLQ14 | 2017-03-29 08:22:08 CLU14 | 2017-03-29 08:22:08 CLV14 | 2017-03-29 08:22:08 CLX14 | 2017-03-29 08:22:08 CLZ14 | 2017-03-29 08:22:08 CLF15 | 2017-03-29 08:22:08 CLG15 | 2017-03-29 08:22:08 CLH15 | 2017-03-29 08:22:08 CLJ15 | 2017-03-29 08:22:08 CLK15 | 2017-03-29 08:22:08 CLM15 | 2017-03-29 08:22:08 CLN15 | 2017-03-29 08:22:08 CLQ15 | 2017-03-29 08:22:08 CLU15 | 2017-03-29 08:22:08 CLV15 | 2017-03-29 08:22:08 CLX15 | 2017-03-29 08:22:08 CLZ15 | 2017-03-29 08:22:08 CLF16 | 2017-03-29 08:22:08 CLG16 | 2017-03-29 08:22:08 CLH16 | 2017-03-29 08:22:08 CLJ16 | 2017-03-29 08:22:08 CLK16 | 2017-03-29 08:22:08 CLM16 | 2017-03-29 08:22:08 CLN16 | 2017-03-29 08:22:08 CLQ16 | 2017-03-29 08:22:08 CLU16 | 2017-03-29 08:22:08 CLV16 | 2017-03-29 08:22:08 CLX16 | 2017-03-29 08:22:08 CLZ16 | 2017-03-29 08:22:08 CLF17 | 2017-03-29 08:22:08 CLG17 | 2017-03-29 08:22:08 CLH17 | 2017-03-29 08:22:08 CLJ17 | 2017-03-29 08:22:08 CL.20170500.CME_NY | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Checking for volume based rollover dates. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20030700.CME_NY to CL.20030800.CME_NY occurs at 2003-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20030800.CME_NY to CL.20030900.CME_NY occurs at 2003-07-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20030900.CME_NY to CL.20031000.CME_NY occurs at 2003-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20031000.CME_NY to CL.20031100.CME_NY occurs at 2003-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20031100.CME_NY to CL.20031200.CME_NY occurs at 2003-10-10 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20031200.CME_NY to CL.20040100.CME_NY occurs at 2003-11-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040100.CME_NY to CL.20040200.CME_NY occurs at 2003-12-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040200.CME_NY to CL.20040300.CME_NY occurs at 2004-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040300.CME_NY to CL.20040400.CME_NY occurs at 2004-02-12 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040400.CME_NY to CL.20040500.CME_NY occurs at 2004-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040500.CME_NY to CL.20040600.CME_NY occurs at 2004-04-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040600.CME_NY to CL.20040700.CME_NY occurs at 2004-05-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040700.CME_NY to CL.20040800.CME_NY occurs at 2004-06-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040800.CME_NY to CL.20040900.CME_NY occurs at 2004-07-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20040900.CME_NY to CL.20041000.CME_NY occurs at 2004-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20041000.CME_NY to CL.20041100.CME_NY occurs at 2004-09-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20041100.CME_NY to CL.20041200.CME_NY occurs at 2004-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20041200.CME_NY to CL.20050100.CME_NY occurs at 2004-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050100.CME_NY to CL.20050200.CME_NY occurs at 2004-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050200.CME_NY to CL.20050300.CME_NY occurs at 2005-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050300.CME_NY to CL.20050400.CME_NY occurs at 2005-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050400.CME_NY to CL.20050500.CME_NY occurs at 2005-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050500.CME_NY to CL.20050600.CME_NY occurs at 2005-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050600.CME_NY to CL.20050700.CME_NY occurs at 2005-05-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050700.CME_NY to CL.20050800.CME_NY occurs at 2005-06-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050800.CME_NY to CL.20050900.CME_NY occurs at 2005-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20050900.CME_NY to CL.20051000.CME_NY occurs at 2005-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20051000.CME_NY to CL.20051100.CME_NY occurs at 2005-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20051100.CME_NY to CL.20051200.CME_NY occurs at 2005-10-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20051200.CME_NY to CL.20060100.CME_NY occurs at 2005-11-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060100.CME_NY to CL.20060200.CME_NY occurs at 2005-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060200.CME_NY to CL.20060300.CME_NY occurs at 2006-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060300.CME_NY to CL.20060400.CME_NY occurs at 2006-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060400.CME_NY to CL.20060500.CME_NY occurs at 2006-03-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060500.CME_NY to CL.20060600.CME_NY occurs at 2006-04-12 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060600.CME_NY to CL.20060700.CME_NY occurs at 2006-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060700.CME_NY to CL.20060800.CME_NY occurs at 2006-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060800.CME_NY to CL.20060900.CME_NY occurs at 2006-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20060900.CME_NY to CL.20061000.CME_NY occurs at 2006-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20061000.CME_NY to CL.20061100.CME_NY occurs at 2006-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20061100.CME_NY to CL.20061200.CME_NY occurs at 2006-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20061200.CME_NY to CL.20070100.CME_NY occurs at 2006-11-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070100.CME_NY to CL.20070200.CME_NY occurs at 2006-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070200.CME_NY to CL.20070300.CME_NY occurs at 2007-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070300.CME_NY to CL.20070400.CME_NY occurs at 2007-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070400.CME_NY to CL.20070500.CME_NY occurs at 2007-03-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070500.CME_NY to CL.20070600.CME_NY occurs at 2007-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070600.CME_NY to CL.20070700.CME_NY occurs at 2007-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070700.CME_NY to CL.20070800.CME_NY occurs at 2007-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070800.CME_NY to CL.20070900.CME_NY occurs at 2007-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20070900.CME_NY to CL.20071000.CME_NY occurs at 2007-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20071000.CME_NY to CL.20071100.CME_NY occurs at 2007-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20071100.CME_NY to CL.20071200.CME_NY occurs at 2007-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20071200.CME_NY to CL.20080100.CME_NY occurs at 2007-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080100.CME_NY to CL.20080200.CME_NY occurs at 2007-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080200.CME_NY to CL.20080300.CME_NY occurs at 2008-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080300.CME_NY to CL.20080400.CME_NY occurs at 2008-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080400.CME_NY to CL.20080500.CME_NY occurs at 2008-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080500.CME_NY to CL.20080600.CME_NY occurs at 2008-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080600.CME_NY to CL.20080700.CME_NY occurs at 2008-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080700.CME_NY to CL.20080800.CME_NY occurs at 2008-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080800.CME_NY to CL.20080900.CME_NY occurs at 2008-07-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20080900.CME_NY to CL.20081000.CME_NY occurs at 2008-08-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20081000.CME_NY to CL.20081100.CME_NY occurs at 2008-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20081100.CME_NY to CL.20081200.CME_NY occurs at 2008-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20081200.CME_NY to CL.20090100.CME_NY occurs at 2008-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090100.CME_NY to CL.20090200.CME_NY occurs at 2008-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090200.CME_NY to CL.20090300.CME_NY occurs at 2009-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090300.CME_NY to CL.20090400.CME_NY occurs at 2009-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090400.CME_NY to CL.20090500.CME_NY occurs at 2009-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090500.CME_NY to CL.20090600.CME_NY occurs at 2009-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090600.CME_NY to CL.20090700.CME_NY occurs at 2009-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090700.CME_NY to CL.20090800.CME_NY occurs at 2009-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090800.CME_NY to CL.20090900.CME_NY occurs at 2009-07-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20090900.CME_NY to CL.20091000.CME_NY occurs at 2009-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20091000.CME_NY to CL.20091100.CME_NY occurs at 2009-09-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20091100.CME_NY to CL.20091200.CME_NY occurs at 2009-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20091200.CME_NY to CL.20100100.CME_NY occurs at 2009-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100100.CME_NY to CL.20100200.CME_NY occurs at 2009-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100200.CME_NY to CL.20100300.CME_NY occurs at 2010-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100300.CME_NY to CL.20100400.CME_NY occurs at 2010-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100400.CME_NY to CL.20100500.CME_NY occurs at 2010-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100500.CME_NY to CL.20100600.CME_NY occurs at 2010-04-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100600.CME_NY to CL.20100700.CME_NY occurs at 2010-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100700.CME_NY to CL.20100800.CME_NY occurs at 2010-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100800.CME_NY to CL.20100900.CME_NY occurs at 2010-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20100900.CME_NY to CL.20101000.CME_NY occurs at 2010-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20101000.CME_NY to CL.20101100.CME_NY occurs at 2010-09-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20101100.CME_NY to CL.20101200.CME_NY occurs at 2010-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20101200.CME_NY to CL.20110100.CME_NY occurs at 2010-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110100.CME_NY to CL.20110200.CME_NY occurs at 2010-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110200.CME_NY to CL.20110300.CME_NY occurs at 2011-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110300.CME_NY to CL.20110400.CME_NY occurs at 2011-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110400.CME_NY to CL.20110500.CME_NY occurs at 2011-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110500.CME_NY to CL.20110600.CME_NY occurs at 2011-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110600.CME_NY to CL.20110700.CME_NY occurs at 2011-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110700.CME_NY to CL.20110800.CME_NY occurs at 2011-06-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110800.CME_NY to CL.20110900.CME_NY occurs at 2011-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20110900.CME_NY to CL.20111000.CME_NY occurs at 2011-08-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20111000.CME_NY to CL.20111100.CME_NY occurs at 2011-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20111100.CME_NY to CL.20111200.CME_NY occurs at 2011-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20111200.CME_NY to CL.20120100.CME_NY occurs at 2011-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120100.CME_NY to CL.20120200.CME_NY occurs at 2011-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120200.CME_NY to CL.20120300.CME_NY occurs at 2012-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120300.CME_NY to CL.20120400.CME_NY occurs at 2012-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120400.CME_NY to CL.20120500.CME_NY occurs at 2012-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120500.CME_NY to CL.20120600.CME_NY occurs at 2012-04-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120600.CME_NY to CL.20120700.CME_NY occurs at 2012-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120700.CME_NY to CL.20120800.CME_NY occurs at 2012-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120800.CME_NY to CL.20120900.CME_NY occurs at 2012-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20120900.CME_NY to CL.20121000.CME_NY occurs at 2012-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20121000.CME_NY to CL.20121100.CME_NY occurs at 2012-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20121100.CME_NY to CL.20121200.CME_NY occurs at 2012-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20121200.CME_NY to CL.20130100.CME_NY occurs at 2012-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130100.CME_NY to CL.20130200.CME_NY occurs at 2012-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130200.CME_NY to CL.20130300.CME_NY occurs at 2013-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130300.CME_NY to CL.20130400.CME_NY occurs at 2013-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130400.CME_NY to CL.20130500.CME_NY occurs at 2013-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130500.CME_NY to CL.20130600.CME_NY occurs at 2013-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130600.CME_NY to CL.20130700.CME_NY occurs at 2013-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130700.CME_NY to CL.20130800.CME_NY occurs at 2013-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130800.CME_NY to CL.20130900.CME_NY occurs at 2013-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20130900.CME_NY to CL.20131000.CME_NY occurs at 2013-08-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20131000.CME_NY to CL.20131100.CME_NY occurs at 2013-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20131100.CME_NY to CL.20131200.CME_NY occurs at 2013-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20131200.CME_NY to CL.20140100.CME_NY occurs at 2013-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140100.CME_NY to CL.20140200.CME_NY occurs at 2013-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140200.CME_NY to CL.20140300.CME_NY occurs at 2014-01-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140300.CME_NY to CL.20140400.CME_NY occurs at 2014-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140400.CME_NY to CL.20140500.CME_NY occurs at 2014-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140500.CME_NY to CL.20140600.CME_NY occurs at 2014-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140600.CME_NY to CL.20140700.CME_NY occurs at 2014-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150600.CME_NY to CL.20150700.CME_NY occurs at 2015-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150700.CME_NY to CL.20150800.CME_NY occurs at 2015-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030700.CME_NY Open price on 2003-06-18 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030800.CME_NY Open price on 2003-06-18 is 2949. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030700.CME_NY price difference to CL.20030800.CME_NY is -156. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030800.CME_NY Open price on 2003-07-15 is 3134. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030900.CME_NY Open price on 2003-07-15 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030800.CME_NY price difference to CL.20030900.CME_NY is -29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030900.CME_NY Open price on 2003-08-18 is 3131. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031000.CME_NY Open price on 2003-08-18 is 3130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20030900.CME_NY price difference to CL.20031000.CME_NY is -1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031000.CME_NY Open price on 2003-09-16 is 2814. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031100.CME_NY Open price on 2003-09-16 is 2817. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031000.CME_NY price difference to CL.20031100.CME_NY is 3. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031100.CME_NY Open price on 2003-10-10 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031200.CME_NY Open price on 2003-10-10 is 3108. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031100.CME_NY price difference to CL.20031200.CME_NY is 3. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031200.CME_NY Open price on 2003-11-14 is 3190. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040100.CME_NY Open price on 2003-11-14 is 3149. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20031200.CME_NY price difference to CL.20040100.CME_NY is -41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040100.CME_NY Open price on 2003-12-15 is 3204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040200.CME_NY Open price on 2003-12-15 is 3215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040100.CME_NY price difference to CL.20040200.CME_NY is 11. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040200.CME_NY Open price on 2004-01-15 is 3457. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040300.CME_NY Open price on 2004-01-15 is 3385. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040200.CME_NY price difference to CL.20040300.CME_NY is -72. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040300.CME_NY Open price on 2004-02-12 is 3400. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040400.CME_NY Open price on 2004-02-12 is 3315. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040300.CME_NY price difference to CL.20040400.CME_NY is -85. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040400.CME_NY Open price on 2004-03-17 is 3744. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040500.CME_NY Open price on 2004-03-17 is 3663. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040400.CME_NY price difference to CL.20040500.CME_NY is -81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040500.CME_NY Open price on 2004-04-15 is 3670. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040600.CME_NY Open price on 2004-04-15 is 3642. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040500.CME_NY price difference to CL.20040600.CME_NY is -28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040600.CME_NY Open price on 2004-05-14 is 4108. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040700.CME_NY Open price on 2004-05-14 is 4070. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040600.CME_NY price difference to CL.20040700.CME_NY is -38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040700.CME_NY Open price on 2004-06-15 is 3759. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040800.CME_NY Open price on 2004-06-15 is 3788. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040700.CME_NY price difference to CL.20040800.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040800.CME_NY Open price on 2004-07-15 is 4097. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040900.CME_NY Open price on 2004-07-15 is 4115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040800.CME_NY price difference to CL.20040900.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040900.CME_NY Open price on 2004-08-18 is 4675. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041000.CME_NY Open price on 2004-08-18 is 4619. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20040900.CME_NY price difference to CL.20041000.CME_NY is -56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041000.CME_NY Open price on 2004-09-17 is 4401. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041100.CME_NY Open price on 2004-09-17 is 4392. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041000.CME_NY price difference to CL.20041100.CME_NY is -9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041100.CME_NY Open price on 2004-10-18 is 5480. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041200.CME_NY Open price on 2004-10-18 is 5397. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041100.CME_NY price difference to CL.20041200.CME_NY is -83. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041200.CME_NY Open price on 2004-11-17 is 4616. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050100.CME_NY Open price on 2004-11-17 is 4620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20041200.CME_NY price difference to CL.20050100.CME_NY is 4. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050100.CME_NY Open price on 2004-12-16 is 4430. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050200.CME_NY Open price on 2004-12-16 is 4470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050100.CME_NY price difference to CL.20050200.CME_NY is 40. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050200.CME_NY Open price on 2005-01-18 is 4860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050300.CME_NY Open price on 2005-01-18 is 4860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050200.CME_NY price difference to CL.20050300.CME_NY is 0. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050300.CME_NY Open price on 2005-02-16 is 4728. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050400.CME_NY Open price on 2005-02-16 is 4780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050300.CME_NY price difference to CL.20050400.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050400.CME_NY Open price on 2005-03-17 is 5645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050500.CME_NY Open price on 2005-03-17 is 5705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050400.CME_NY price difference to CL.20050500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050500.CME_NY Open price on 2005-04-18 is 5043. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050600.CME_NY Open price on 2005-04-18 is 5200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050500.CME_NY price difference to CL.20050600.CME_NY is 157. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050600.CME_NY Open price on 2005-05-17 is 4864. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050700.CME_NY Open price on 2005-05-17 is 5025. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050600.CME_NY price difference to CL.20050700.CME_NY is 161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050700.CME_NY Open price on 2005-06-16 is 5551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050800.CME_NY Open price on 2005-06-16 is 5635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050700.CME_NY price difference to CL.20050800.CME_NY is 84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050800.CME_NY Open price on 2005-07-18 is 5800. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050900.CME_NY Open price on 2005-07-18 is 5904. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050800.CME_NY price difference to CL.20050900.CME_NY is 104. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050900.CME_NY Open price on 2005-08-18 is 6333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051000.CME_NY Open price on 2005-08-18 is 6440. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20050900.CME_NY price difference to CL.20051000.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051000.CME_NY Open price on 2005-09-16 is 6470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051100.CME_NY Open price on 2005-09-16 is 6512. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051000.CME_NY price difference to CL.20051100.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051100.CME_NY Open price on 2005-10-14 is 6305. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051200.CME_NY Open price on 2005-10-14 is 6265. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051100.CME_NY price difference to CL.20051200.CME_NY is -40. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051200.CME_NY Open price on 2005-11-16 is 5698. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060100.CME_NY Open price on 2005-11-16 is 5771. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20051200.CME_NY price difference to CL.20060100.CME_NY is 73. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060100.CME_NY Open price on 2005-12-16 is 5990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060200.CME_NY Open price on 2005-12-16 is 6105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060100.CME_NY price difference to CL.20060200.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060200.CME_NY Open price on 2006-01-18 is 6635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060300.CME_NY Open price on 2006-01-18 is 6700. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060200.CME_NY price difference to CL.20060300.CME_NY is 65. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060300.CME_NY Open price on 2006-02-16 is 5770. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060400.CME_NY Open price on 2006-02-16 is 5960. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060300.CME_NY price difference to CL.20060400.CME_NY is 190. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060400.CME_NY Open price on 2006-03-14 is 6175. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060500.CME_NY Open price on 2006-03-14 is 6370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060400.CME_NY price difference to CL.20060500.CME_NY is 195. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060500.CME_NY Open price on 2006-04-12 is 6895. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060600.CME_NY Open price on 2006-04-12 is 7037. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060500.CME_NY price difference to CL.20060600.CME_NY is 142. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060600.CME_NY Open price on 2006-05-18 is 6865. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060700.CME_NY Open price on 2006-05-18 is 6965. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060600.CME_NY price difference to CL.20060700.CME_NY is 100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060700.CME_NY Open price on 2006-06-19 is 6987. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060800.CME_NY Open price on 2006-06-19 is 7022. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060700.CME_NY price difference to CL.20060800.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060800.CME_NY Open price on 2006-07-18 is 7520. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060900.CME_NY Open price on 2006-07-18 is 7681. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060800.CME_NY price difference to CL.20060900.CME_NY is 161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060900.CME_NY Open price on 2006-08-18 is 7048. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061000.CME_NY Open price on 2006-08-18 is 7196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20060900.CME_NY price difference to CL.20061000.CME_NY is 148. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061000.CME_NY Open price on 2006-09-19 is 6385. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061100.CME_NY Open price on 2006-09-19 is 6450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061000.CME_NY price difference to CL.20061100.CME_NY is 65. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061100.CME_NY Open price on 2006-10-18 is 5910. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061200.CME_NY Open price on 2006-10-18 is 6096. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061100.CME_NY price difference to CL.20061200.CME_NY is 186. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061200.CME_NY Open price on 2006-11-16 is 5877. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070100.CME_NY Open price on 2006-11-16 is 6072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20061200.CME_NY price difference to CL.20070100.CME_NY is 195. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070100.CME_NY Open price on 2006-12-18 is 6320. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070200.CME_NY Open price on 2006-12-18 is 6362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070100.CME_NY price difference to CL.20070200.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070200.CME_NY Open price on 2007-01-18 is 5240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070300.CME_NY Open price on 2007-01-18 is 5315. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070200.CME_NY price difference to CL.20070300.CME_NY is 75. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070300.CME_NY Open price on 2007-02-16 is 5804. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070400.CME_NY Open price on 2007-02-16 is 5857. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070300.CME_NY price difference to CL.20070400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070400.CME_NY Open price on 2007-03-16 is 5753. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070500.CME_NY Open price on 2007-03-16 is 5996. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070400.CME_NY price difference to CL.20070500.CME_NY is 243. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070500.CME_NY Open price on 2007-04-18 is 6325. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070600.CME_NY Open price on 2007-04-18 is 6464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070500.CME_NY price difference to CL.20070600.CME_NY is 139. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070600.CME_NY Open price on 2007-05-21 is 6495. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070700.CME_NY Open price on 2007-05-21 is 6594. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070600.CME_NY price difference to CL.20070700.CME_NY is 99. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070700.CME_NY Open price on 2007-06-18 is 6813. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070800.CME_NY Open price on 2007-06-18 is 6871. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070700.CME_NY price difference to CL.20070800.CME_NY is 58. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070800.CME_NY Open price on 2007-07-18 is 7421. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070900.CME_NY Open price on 2007-07-18 is 7428. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070800.CME_NY price difference to CL.20070900.CME_NY is 7. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070900.CME_NY Open price on 2007-08-20 is 7177. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071000.CME_NY Open price on 2007-08-20 is 7151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20070900.CME_NY price difference to CL.20071000.CME_NY is -26. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071000.CME_NY Open price on 2007-09-19 is 8217. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071100.CME_NY Open price on 2007-09-19 is 8098. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071000.CME_NY price difference to CL.20071100.CME_NY is -119. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071100.CME_NY Open price on 2007-10-18 is 8710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071200.CME_NY Open price on 2007-10-18 is 8590. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071100.CME_NY price difference to CL.20071200.CME_NY is -120. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071200.CME_NY Open price on 2007-11-15 is 9395. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080100.CME_NY Open price on 2007-11-15 is 9270. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20071200.CME_NY price difference to CL.20080100.CME_NY is -125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080100.CME_NY Open price on 2007-12-17 is 9143. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080200.CME_NY Open price on 2007-12-17 is 9155. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080100.CME_NY price difference to CL.20080200.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080200.CME_NY Open price on 2008-01-18 is 8990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080300.CME_NY Open price on 2008-01-18 is 8938. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080200.CME_NY price difference to CL.20080300.CME_NY is -52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080300.CME_NY Open price on 2008-02-19 is 9537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080400.CME_NY Open price on 2008-02-19 is 9546. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080300.CME_NY price difference to CL.20080400.CME_NY is 9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080400.CME_NY Open price on 2008-03-18 is 10615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080500.CME_NY Open price on 2008-03-18 is 10464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080400.CME_NY price difference to CL.20080500.CME_NY is -151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080500.CME_NY Open price on 2008-04-21 is 11693. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080600.CME_NY Open price on 2008-04-21 is 11654. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080500.CME_NY price difference to CL.20080600.CME_NY is -39. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080600.CME_NY Open price on 2008-05-19 is 12635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080700.CME_NY Open price on 2008-05-19 is 12615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080600.CME_NY price difference to CL.20080700.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080700.CME_NY Open price on 2008-06-19 is 13609. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080800.CME_NY Open price on 2008-06-19 is 13800. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080700.CME_NY price difference to CL.20080800.CME_NY is 191. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080800.CME_NY Open price on 2008-07-21 is 12888. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080900.CME_NY Open price on 2008-07-21 is 12950. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080800.CME_NY price difference to CL.20080900.CME_NY is 62. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080900.CME_NY Open price on 2008-08-19 is 11311. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081000.CME_NY Open price on 2008-08-19 is 11320. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20080900.CME_NY price difference to CL.20081000.CME_NY is 9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081000.CME_NY Open price on 2008-09-19 is 9795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081100.CME_NY Open price on 2008-09-19 is 9758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081000.CME_NY price difference to CL.20081100.CME_NY is -37. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081100.CME_NY Open price on 2008-10-17 is 7230. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081200.CME_NY Open price on 2008-10-17 is 7268. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081100.CME_NY price difference to CL.20081200.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081200.CME_NY Open price on 2008-11-19 is 5470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090100.CME_NY Open price on 2008-11-19 is 5508. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20081200.CME_NY price difference to CL.20090100.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090100.CME_NY Open price on 2008-12-17 is 4375. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090200.CME_NY Open price on 2008-12-17 is 4682. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090100.CME_NY price difference to CL.20090200.CME_NY is 307. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090200.CME_NY Open price on 2009-01-15 is 3734. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090300.CME_NY Open price on 2009-01-15 is 4445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090200.CME_NY price difference to CL.20090300.CME_NY is 711. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090300.CME_NY Open price on 2009-02-17 is 3781. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090400.CME_NY Open price on 2009-02-17 is 4208. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090300.CME_NY price difference to CL.20090400.CME_NY is 427. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090400.CME_NY Open price on 2009-03-18 is 4867. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090500.CME_NY Open price on 2009-03-18 is 4941. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090400.CME_NY price difference to CL.20090500.CME_NY is 74. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090500.CME_NY Open price on 2009-04-17 is 4993. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090600.CME_NY Open price on 2009-04-17 is 5200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090500.CME_NY price difference to CL.20090600.CME_NY is 207. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090600.CME_NY Open price on 2009-05-18 is 5647. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090700.CME_NY Open price on 2009-05-18 is 5722. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090600.CME_NY price difference to CL.20090700.CME_NY is 75. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090700.CME_NY Open price on 2009-06-19 is 7135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090800.CME_NY Open price on 2009-06-19 is 7188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090700.CME_NY price difference to CL.20090800.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090800.CME_NY Open price on 2009-07-17 is 6224. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090900.CME_NY Open price on 2009-07-17 is 6310. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090800.CME_NY price difference to CL.20090900.CME_NY is 86. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090900.CME_NY Open price on 2009-08-18 is 6680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091000.CME_NY Open price on 2009-08-18 is 6881. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20090900.CME_NY price difference to CL.20091000.CME_NY is 201. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091000.CME_NY Open price on 2009-09-21 is 7178. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091100.CME_NY Open price on 2009-09-21 is 7221. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091000.CME_NY price difference to CL.20091100.CME_NY is 43. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091100.CME_NY Open price on 2009-10-19 is 7856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091200.CME_NY Open price on 2009-10-19 is 7912. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091100.CME_NY price difference to CL.20091200.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091200.CME_NY Open price on 2009-11-19 is 7963. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100100.CME_NY Open price on 2009-11-19 is 8016. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20091200.CME_NY price difference to CL.20100100.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100100.CME_NY Open price on 2009-12-17 is 7274. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100200.CME_NY Open price on 2009-12-17 is 7451. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100100.CME_NY price difference to CL.20100200.CME_NY is 177. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100200.CME_NY Open price on 2010-01-19 is 7785. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100300.CME_NY Open price on 2010-01-19 is 7821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100200.CME_NY price difference to CL.20100300.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100300.CME_NY Open price on 2010-02-19 is 7837. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100400.CME_NY Open price on 2010-02-19 is 7883. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100300.CME_NY price difference to CL.20100400.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100400.CME_NY Open price on 2010-03-19 is 8217. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100500.CME_NY Open price on 2010-03-19 is 8246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100400.CME_NY price difference to CL.20100500.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100500.CME_NY Open price on 2010-04-16 is 8535. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100600.CME_NY Open price on 2010-04-16 is 8656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100500.CME_NY price difference to CL.20100600.CME_NY is 121. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100600.CME_NY Open price on 2010-05-18 is 7050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100700.CME_NY Open price on 2010-05-18 is 7387. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100600.CME_NY price difference to CL.20100700.CME_NY is 337. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100700.CME_NY Open price on 2010-06-18 is 7655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100800.CME_NY Open price on 2010-06-18 is 7789. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100700.CME_NY price difference to CL.20100800.CME_NY is 134. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100800.CME_NY Open price on 2010-07-19 is 7572. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100900.CME_NY Open price on 2010-07-19 is 7607. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100800.CME_NY price difference to CL.20100900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100900.CME_NY Open price on 2010-08-18 is 7545. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101000.CME_NY Open price on 2010-08-18 is 7580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20100900.CME_NY price difference to CL.20101000.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101000.CME_NY Open price on 2010-09-17 is 7447. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101100.CME_NY Open price on 2010-09-17 is 7563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101000.CME_NY price difference to CL.20101100.CME_NY is 116. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101100.CME_NY Open price on 2010-10-18 is 8138. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101200.CME_NY Open price on 2010-10-18 is 8220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101100.CME_NY price difference to CL.20101200.CME_NY is 82. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101200.CME_NY Open price on 2010-11-17 is 8244. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110100.CME_NY Open price on 2010-11-17 is 8286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20101200.CME_NY price difference to CL.20110100.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110100.CME_NY Open price on 2010-12-17 is 8787. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110200.CME_NY Open price on 2010-12-17 is 8850. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110100.CME_NY price difference to CL.20110200.CME_NY is 63. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110200.CME_NY Open price on 2011-01-18 is 9151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110300.CME_NY Open price on 2011-01-18 is 9255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110200.CME_NY price difference to CL.20110300.CME_NY is 104. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110300.CME_NY Open price on 2011-02-17 is 8525. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110400.CME_NY Open price on 2011-02-17 is 8812. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110300.CME_NY price difference to CL.20110400.CME_NY is 287. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110400.CME_NY Open price on 2011-03-18 is 10178. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110500.CME_NY Open price on 2011-03-18 is 10280. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110400.CME_NY price difference to CL.20110500.CME_NY is 102. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110500.CME_NY Open price on 2011-04-18 is 10943. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110600.CME_NY Open price on 2011-04-18 is 11005. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110500.CME_NY price difference to CL.20110600.CME_NY is 62. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110600.CME_NY Open price on 2011-05-18 is 9757. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110700.CME_NY Open price on 2011-05-18 is 9818. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110600.CME_NY price difference to CL.20110700.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110700.CME_NY Open price on 2011-06-20 is 9280. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110800.CME_NY Open price on 2011-06-20 is 9317. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110700.CME_NY price difference to CL.20110800.CME_NY is 37. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110800.CME_NY Open price on 2011-07-19 is 9616. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110900.CME_NY Open price on 2011-07-19 is 9645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110800.CME_NY price difference to CL.20110900.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110900.CME_NY Open price on 2011-08-19 is 8130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111000.CME_NY Open price on 2011-08-19 is 8145. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20110900.CME_NY price difference to CL.20111000.CME_NY is 15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111000.CME_NY Open price on 2011-09-19 is 8775. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111100.CME_NY Open price on 2011-09-19 is 8780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111000.CME_NY price difference to CL.20111100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111100.CME_NY Open price on 2011-10-18 is 8620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111200.CME_NY Open price on 2011-10-18 is 8630. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111100.CME_NY price difference to CL.20111200.CME_NY is 10. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111200.CME_NY Open price on 2011-11-17 is 10176. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120100.CME_NY Open price on 2011-11-17 is 10174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20111200.CME_NY price difference to CL.20120100.CME_NY is -2. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120100.CME_NY Open price on 2011-12-19 is 9376. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120200.CME_NY Open price on 2011-12-19 is 9377. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120100.CME_NY price difference to CL.20120200.CME_NY is 1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120200.CME_NY Open price on 2012-01-19 is 10114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120300.CME_NY Open price on 2012-01-19 is 10135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120200.CME_NY price difference to CL.20120300.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120300.CME_NY Open price on 2012-02-17 is 10235. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120400.CME_NY Open price on 2012-02-17 is 10264. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120300.CME_NY price difference to CL.20120400.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120400.CME_NY Open price on 2012-03-19 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120500.CME_NY Open price on 2012-03-19 is 10778. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120400.CME_NY price difference to CL.20120500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120500.CME_NY Open price on 2012-04-19 is 10273. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120600.CME_NY Open price on 2012-04-19 is 10321. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120500.CME_NY price difference to CL.20120600.CME_NY is 48. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120600.CME_NY Open price on 2012-05-21 is 9127. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120700.CME_NY Open price on 2012-05-21 is 9171. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120600.CME_NY price difference to CL.20120700.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120700.CME_NY Open price on 2012-06-19 is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120800.CME_NY Open price on 2012-06-19 is 8344. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120700.CME_NY price difference to CL.20120800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120800.CME_NY Open price on 2012-07-19 is 9008. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120900.CME_NY Open price on 2012-07-19 is 9035. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120800.CME_NY price difference to CL.20120900.CME_NY is 27. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120900.CME_NY Open price on 2012-08-20 is 9636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121000.CME_NY Open price on 2012-08-20 is 9664. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20120900.CME_NY price difference to CL.20121000.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121000.CME_NY Open price on 2012-09-19 is 9549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121100.CME_NY Open price on 2012-09-19 is 9583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121000.CME_NY price difference to CL.20121100.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121100.CME_NY Open price on 2012-10-19 is 9204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121200.CME_NY Open price on 2012-10-19 is 9248. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121100.CME_NY price difference to CL.20121200.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121200.CME_NY Open price on 2012-11-15 is 8636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130100.CME_NY Open price on 2012-11-15 is 8677. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20121200.CME_NY price difference to CL.20130100.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130100.CME_NY Open price on 2012-12-18 is 8745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130200.CME_NY Open price on 2012-12-18 is 8794. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130100.CME_NY price difference to CL.20130200.CME_NY is 49. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130200.CME_NY Open price on 2013-01-18 is 9519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130300.CME_NY Open price on 2013-01-18 is 9565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130200.CME_NY price difference to CL.20130300.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130300.CME_NY Open price on 2013-02-19 is 9597. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130400.CME_NY Open price on 2013-02-19 is 9639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130300.CME_NY price difference to CL.20130400.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130400.CME_NY Open price on 2013-03-18 is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130500.CME_NY Open price on 2013-03-18 is 9362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130400.CME_NY price difference to CL.20130500.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130500.CME_NY Open price on 2013-04-18 is 8639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130600.CME_NY Open price on 2013-04-18 is 8660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130500.CME_NY price difference to CL.20130600.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130600.CME_NY Open price on 2013-05-20 is 9593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130700.CME_NY Open price on 2013-05-20 is 9625. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130600.CME_NY price difference to CL.20130700.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130700.CME_NY Open price on 2013-06-18 is 9793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130800.CME_NY Open price on 2013-06-18 is 9816. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130700.CME_NY price difference to CL.20130800.CME_NY is 23. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130800.CME_NY Open price on 2013-07-18 is 10656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130900.CME_NY Open price on 2013-07-18 is 10635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130800.CME_NY price difference to CL.20130900.CME_NY is -21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130900.CME_NY Open price on 2013-08-16 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131000.CME_NY Open price on 2013-08-16 is 10701. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20130900.CME_NY price difference to CL.20131000.CME_NY is -17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131000.CME_NY Open price on 2013-09-18 is 10553. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131100.CME_NY Open price on 2013-09-18 is 10477. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131000.CME_NY price difference to CL.20131100.CME_NY is -76. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131100.CME_NY Open price on 2013-10-18 is 10072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131200.CME_NY Open price on 2013-10-18 is 10100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131100.CME_NY price difference to CL.20131200.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131200.CME_NY Open price on 2013-11-19 is 9300. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140100.CME_NY Open price on 2013-11-19 is 9364. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20131200.CME_NY price difference to CL.20140100.CME_NY is 64. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140100.CME_NY Open price on 2013-12-17 is 9730. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140200.CME_NY Open price on 2013-12-17 is 9754. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140100.CME_NY price difference to CL.20140200.CME_NY is 24. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140200.CME_NY Open price on 2014-01-17 is 9417. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140300.CME_NY Open price on 2014-01-17 is 9429. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140200.CME_NY price difference to CL.20140300.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140300.CME_NY Open price on 2014-02-18 is 10032. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140400.CME_NY Open price on 2014-02-18 is 10012. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140300.CME_NY price difference to CL.20140400.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140400.CME_NY Open price on 2014-03-18 is 9797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140500.CME_NY Open price on 2014-03-18 is 9746. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140400.CME_NY price difference to CL.20140500.CME_NY is -51. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140500.CME_NY Open price on 2014-04-21 is 10454. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140600.CME_NY Open price on 2014-04-21 is 10370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140500.CME_NY price difference to CL.20140600.CME_NY is -84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140600.CME_NY Open price on 2014-05-19 is 10213. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140700.CME_NY Open price on 2014-05-19 is 10168. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140600.CME_NY price difference to CL.20140700.CME_NY is -45. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140700.CME_NY Open price on 2014-06-18 is 10660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140800.CME_NY Open price on 2014-06-18 is 10606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -54. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140800.CME_NY Open price on 2014-07-18 is 10372. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140900.CME_NY Open price on 2014-07-18 is 10277. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -95. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140900.CME_NY Open price on 2014-08-18 is 9710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141000.CME_NY Open price on 2014-08-18 is 9514. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141000.CME_NY Open price on 2014-09-19 is 9297. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141100.CME_NY Open price on 2014-09-19 is 9196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -101. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141100.CME_NY Open price on 2014-10-17 is 8318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141200.CME_NY Open price on 2014-10-17 is 8240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -78. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141200.CME_NY Open price on 2014-11-18 is 7549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150100.CME_NY Open price on 2014-11-18 is 7554. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150100.CME_NY Open price on 2014-12-18 is 5583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150200.CME_NY Open price on 2014-12-18 is 5617. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150200.CME_NY Open price on 2015-01-16 is 4635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150300.CME_NY Open price on 2015-01-16 is 4673. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150300.CME_NY Open price on 2015-02-18 is 5324. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150400.CME_NY Open price on 2015-02-18 is 5405. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150400.CME_NY Open price on 2015-03-18 is 4251. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150500.CME_NY Open price on 2015-03-18 is 4450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150500.CME_NY Open price on 2015-04-17 is 5656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150600.CME_NY Open price on 2015-04-17 is 5797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 141. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150600.CME_NY Open price on 2015-05-18 is 5985. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150700.CME_NY Open price on 2015-05-18 is 6062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150600.CME_NY price difference to CL.20150700.CME_NY is 77. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150700.CME_NY Open price on 2015-06-19 is 6050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150800.CME_NY Open price on 2015-06-19 is 6088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150700.CME_NY price difference to CL.20150800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20030700.CME_NY is 8715. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20030800.CME_NY is 8871. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20030900.CME_NY is 8900. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20031000.CME_NY is 8901. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20031100.CME_NY is 8898. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20031200.CME_NY is 8895. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040100.CME_NY is 8936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040200.CME_NY is 8925. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040300.CME_NY is 8997. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040400.CME_NY is 9082. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040500.CME_NY is 9163. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040600.CME_NY is 9191. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040700.CME_NY is 9229. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040800.CME_NY is 9200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20040900.CME_NY is 9182. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20041000.CME_NY is 9238. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20041100.CME_NY is 9247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20041200.CME_NY is 9330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050100.CME_NY is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050200.CME_NY is 9286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050300.CME_NY is 9286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050400.CME_NY is 9234. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050500.CME_NY is 9174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050600.CME_NY is 9017. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050700.CME_NY is 8856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050800.CME_NY is 8772. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20050900.CME_NY is 8668. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20051000.CME_NY is 8561. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20051100.CME_NY is 8519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20051200.CME_NY is 8559. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060100.CME_NY is 8486. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060200.CME_NY is 8371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060300.CME_NY is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060400.CME_NY is 8116. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060500.CME_NY is 7921. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060600.CME_NY is 7779. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060700.CME_NY is 7679. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060800.CME_NY is 7644. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20060900.CME_NY is 7483. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20061000.CME_NY is 7335. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20061100.CME_NY is 7270. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20061200.CME_NY is 7084. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070100.CME_NY is 6889. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070200.CME_NY is 6847. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070300.CME_NY is 6772. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070400.CME_NY is 6719. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070500.CME_NY is 6476. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070600.CME_NY is 6337. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070700.CME_NY is 6238. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070800.CME_NY is 6180. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20070900.CME_NY is 6173. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20071000.CME_NY is 6199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20071100.CME_NY is 6318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20071200.CME_NY is 6438. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080100.CME_NY is 6563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080200.CME_NY is 6551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080300.CME_NY is 6603. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080400.CME_NY is 6594. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080500.CME_NY is 6745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080600.CME_NY is 6784. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080700.CME_NY is 6804. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080800.CME_NY is 6613. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20080900.CME_NY is 6551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20081000.CME_NY is 6542. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20081100.CME_NY is 6579. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20081200.CME_NY is 6541. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090100.CME_NY is 6503. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090200.CME_NY is 6196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090300.CME_NY is 5485. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090400.CME_NY is 5058. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090500.CME_NY is 4984. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090600.CME_NY is 4777. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090700.CME_NY is 4702. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090800.CME_NY is 4649. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20090900.CME_NY is 4563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20091000.CME_NY is 4362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20091100.CME_NY is 4319. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20091200.CME_NY is 4263. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100100.CME_NY is 4210. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100200.CME_NY is 4033. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100300.CME_NY is 3997. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100400.CME_NY is 3951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100500.CME_NY is 3922. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100600.CME_NY is 3801. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100700.CME_NY is 3464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100800.CME_NY is 3330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20100900.CME_NY is 3295. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20101000.CME_NY is 3260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20101100.CME_NY is 3144. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20101200.CME_NY is 3062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110100.CME_NY is 3020. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110200.CME_NY is 2957. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110300.CME_NY is 2853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110400.CME_NY is 2566. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110500.CME_NY is 2464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110600.CME_NY is 2402. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110700.CME_NY is 2341. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110800.CME_NY is 2304. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20110900.CME_NY is 2275. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20111000.CME_NY is 2260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20111100.CME_NY is 2255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20111200.CME_NY is 2245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120100.CME_NY is 2247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120200.CME_NY is 2246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120300.CME_NY is 2225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120400.CME_NY is 2196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120500.CME_NY is 2136. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120600.CME_NY is 2088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120700.CME_NY is 2044. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120800.CME_NY is 2006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20120900.CME_NY is 1979. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20121000.CME_NY is 1951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20121100.CME_NY is 1917. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20121200.CME_NY is 1873. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130100.CME_NY is 1832. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130200.CME_NY is 1783. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130300.CME_NY is 1737. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130400.CME_NY is 1695. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130500.CME_NY is 1659. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130600.CME_NY is 1638. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130700.CME_NY is 1606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130800.CME_NY is 1583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20130900.CME_NY is 1604. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20131000.CME_NY is 1621. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20131100.CME_NY is 1697. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20131200.CME_NY is 1669. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140100.CME_NY is 1605. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140200.CME_NY is 1581. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140300.CME_NY is 1569. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140400.CME_NY is 1589. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140500.CME_NY is 1640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140600.CME_NY is 1724. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140700.CME_NY is 1769. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140800.CME_NY is 1823. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20140900.CME_NY is 1918. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20141000.CME_NY is 2114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20141100.CME_NY is 2215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20141200.CME_NY is 2293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150100.CME_NY is 2288. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150200.CME_NY is 2254. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150300.CME_NY is 2216. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150400.CME_NY is 2135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150500.CME_NY is 1936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150600.CME_NY is 1795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150700.CME_NY is 1718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Weekly #15 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Reloading chart. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20111000.CME_NY to next contract occurs at 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20111100.CME_NY to next contract occurs at 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20111200.CME_NY to next contract occurs at 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120100.CME_NY to next contract occurs at 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120200.CME_NY to next contract occurs at 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120300.CME_NY to next contract occurs at 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120400.CME_NY to next contract occurs at 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120500.CME_NY to next contract occurs at 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120600.CME_NY to next contract occurs at 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120700.CME_NY to next contract occurs at 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120800.CME_NY to next contract occurs at 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20120900.CME_NY to next contract occurs at 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20121000.CME_NY to next contract occurs at 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20121100.CME_NY to next contract occurs at 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20121200.CME_NY to next contract occurs at 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130100.CME_NY to next contract occurs at 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130200.CME_NY to next contract occurs at 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130300.CME_NY to next contract occurs at 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130400.CME_NY to next contract occurs at 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130500.CME_NY to next contract occurs at 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130600.CME_NY to next contract occurs at 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130700.CME_NY to next contract occurs at 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130800.CME_NY to next contract occurs at 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20130900.CME_NY to next contract occurs at 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20131000.CME_NY to next contract occurs at 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20131100.CME_NY to next contract occurs at 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20131200.CME_NY to next contract occurs at 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140100.CME_NY to next contract occurs at 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140200.CME_NY to next contract occurs at 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140300.CME_NY to next contract occurs at 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140400.CME_NY to next contract occurs at 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140500.CME_NY to next contract occurs at 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140600.CME_NY to next contract occurs at 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150700.CME_NY to next contract occurs at 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV11 for the date range from 2011-08-18 to 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX11 for the date range from 2011-09-16 to 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ11 for the date range from 2011-10-18 to 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF12 for the date range from 2011-11-18 to 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG12 for the date range from 2011-12-16 to 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH12 for the date range from 2012-01-18 to 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ12 for the date range from 2012-02-17 to 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLK12 for the date range from 2012-03-16 to 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLM12 for the date range from 2012-04-18 to 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLN12 for the date range from 2012-05-18 to 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLQ12 for the date range from 2012-06-18 to 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLU12 for the date range from 2012-07-18 to 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV12 for the date range from 2012-08-17 to 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX12 for the date range from 2012-09-18 to 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ12 for the date range from 2012-10-18 to 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF13 for the date range from 2012-11-16 to 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG13 for the date range from 2012-12-18 to 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH13 for the date range from 2013-01-18 to 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ13 for the date range from 2013-02-18 to 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLK13 for the date range from 2013-03-18 to 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLM13 for the date range from 2013-04-18 to 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLN13 for the date range from 2013-05-17 to 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLQ13 for the date range from 2013-06-18 to 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLU13 for the date range from 2013-07-18 to 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV13 for the date range from 2013-08-16 to 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX13 for the date range from 2013-09-18 to 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ13 for the date range from 2013-10-18 to 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF14 for the date range from 2013-11-18 to 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG14 for the date range from 2013-12-18 to 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH14 for the date range from 2014-01-17 to 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ14 for the date range from 2014-02-18 to 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLK14 for the date range from 2014-03-18 to 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLM14 for the date range from 2014-04-18 to 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLN14 for the date range from 2014-05-16 to 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLQ14 for the date range from 2014-06-18 to 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLU14 for the date range from 2014-07-18 to 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV14 for the date range from 2014-08-18 to 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX14 for the date range from 2014-09-18 to 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ14 for the date range from 2014-10-17 to 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF15 for the date range from 2014-11-18 to 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG15 for the date range from 2014-12-18 to 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH15 for the date range from 2015-01-16 to 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ15 for the date range from 2015-02-18 to 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLK15 for the date range from 2015-03-18 to 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLM15 for the date range from 2015-04-17 to 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLN15 for the date range from 2015-05-18 to 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLN15.dly. Date: 2015-05-18, Price: 6024. Date: 2015-06-17, Price: 5992 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLM15.dly. Date: 2015-04-17, Price: 5732. Date: 2015-05-15, Price: 5969 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLK15.dly. Date: 2015-03-18, Price: 4665. Date: 2015-04-16, Price: 5671 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ15.dly. Date: 2015-02-18, Price: 5282. Date: 2015-03-17, Price: 4346 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH15.dly. Date: 2015-01-16, Price: 4913. Date: 2015-02-17, Price: 5353 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG15.dly. Date: 2014-12-18, Price: 5436. Date: 2015-01-15, Price: 4625 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF15.dly. Date: 2014-11-18, Price: 7464. Date: 2014-12-17, Price: 5647 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ14.dly. Date: 2014-10-17, Price: 8206. Date: 2014-11-17, Price: 7564 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX14.dly. Date: 2014-09-18, Price: 9198. Date: 2014-10-16, Price: 8270 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV14.dly. Date: 2014-08-18, Price: 9375. Date: 2014-09-17, Price: 9442 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLU14.dly. Date: 2014-07-18, Price: 10195. Date: 2014-08-15, Price: 9735 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLQ14.dly. Date: 2014-06-18, Price: 10559. Date: 2014-07-17, Price: 10319 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLN14.dly. Date: 2014-05-16, Price: 10158. Date: 2014-06-17, Price: 10636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLM14.dly. Date: 2014-04-18, Price: 10365. Date: 2014-05-15, Price: 10150 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLK14.dly. Date: 2014-03-18, Price: 9888. Date: 2014-04-17, Price: 10430 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ14.dly. Date: 2014-02-18, Price: 10210. Date: 2014-03-17, Price: 9808 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH14.dly. Date: 2014-01-17, Price: 9459. Date: 2014-02-17, Price: 10243 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG14.dly. Date: 2013-12-18, Price: 9806. Date: 2014-01-16, Price: 9396 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF14.dly. Date: 2013-11-18, Price: 9368. Date: 2013-12-17, Price: 9722 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ13.dly. Date: 2013-10-18, Price: 10111. Date: 2013-11-15, Price: 9384 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX13.dly. Date: 2013-09-18, Price: 10728. Date: 2013-10-17, Price: 10067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV13.dly. Date: 2013-08-16, Price: 10729. Date: 2013-09-17, Price: 10542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLU13.dly. Date: 2013-07-18, Price: 10781. Date: 2013-08-15, Price: 10733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLQ13.dly. Date: 2013-06-18, Price: 9867. Date: 2013-07-17, Price: 10648 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLN13.dly. Date: 2013-05-17, Price: 9629. Date: 2013-06-17, Price: 9777 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLM13.dly. Date: 2013-04-18, Price: 8800. Date: 2013-05-16, Price: 9516 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLK13.dly. Date: 2013-03-18, Price: 9411. Date: 2013-04-17, Price: 8668 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ13.dly. Date: 2013-02-18, Price: 9710. Date: 2013-03-15, Price: 9345 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH13.dly. Date: 2013-01-18, Price: 9604. Date: 2013-02-15, Price: 9586 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG13.dly. Date: 2012-12-18, Price: 8840. Date: 2013-01-17, Price: 9549 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF13.dly. Date: 2012-11-16, Price: 8692. Date: 2012-12-17, Price: 8720 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ12.dly. Date: 2012-10-18, Price: 9253. Date: 2012-11-15, Price: 8545 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX12.dly. Date: 2012-09-18, Price: 9562. Date: 2012-10-17, Price: 9212 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV12.dly. Date: 2012-08-17, Price: 9632. Date: 2012-09-17, Price: 9662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLU12.dly. Date: 2012-07-18, Price: 9017. Date: 2012-08-16, Price: 9560 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLQ12.dly. Date: 2012-06-18, Price: 8360. Date: 2012-07-17, Price: 8922 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLN12.dly. Date: 2012-05-18, Price: 9180. Date: 2012-06-15, Price: 8403 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLM12.dly. Date: 2012-04-18, Price: 10312. Date: 2012-05-17, Price: 9256 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLK12.dly. Date: 2012-03-16, Price: 10758. Date: 2012-04-17, Price: 10420 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLJ12.dly. Date: 2012-02-17, Price: 10360. Date: 2012-03-15, Price: 10511 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLH12.dly. Date: 2012-01-18, Price: 10076. Date: 2012-02-16, Price: 10231 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLG12.dly. Date: 2011-12-16, Price: 9375. Date: 2012-01-17, Price: 10071 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLF12.dly. Date: 2011-11-18, Price: 9767. Date: 2011-12-15, Price: 9387 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLZ11.dly. Date: 2011-10-18, Price: 8853. Date: 2011-11-17, Price: 9882 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLX11.dly. Date: 2011-09-16, Price: 8818. Date: 2011-10-17, Price: 8638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Price data for daily data file CLV11.dly. Date: 2011-08-18, Price: 8251. Date: 2011-09-15, Price: 8940 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Symbols used for continuous contract chart: | 2017-03-29 08:22:08 CLV11 | 2017-03-29 08:22:08 CLX11 | 2017-03-29 08:22:08 CLZ11 | 2017-03-29 08:22:08 CLF12 | 2017-03-29 08:22:08 CLG12 | 2017-03-29 08:22:08 CLH12 | 2017-03-29 08:22:08 CLJ12 | 2017-03-29 08:22:08 CLK12 | 2017-03-29 08:22:08 CLM12 | 2017-03-29 08:22:08 CLN12 | 2017-03-29 08:22:08 CLQ12 | 2017-03-29 08:22:08 CLU12 | 2017-03-29 08:22:08 CLV12 | 2017-03-29 08:22:08 CLX12 | 2017-03-29 08:22:08 CLZ12 | 2017-03-29 08:22:08 CLF13 | 2017-03-29 08:22:08 CLG13 | 2017-03-29 08:22:08 CLH13 | 2017-03-29 08:22:08 CLJ13 | 2017-03-29 08:22:08 CLK13 | 2017-03-29 08:22:08 CLM13 | 2017-03-29 08:22:08 CLN13 | 2017-03-29 08:22:08 CLQ13 | 2017-03-29 08:22:08 CLU13 | 2017-03-29 08:22:08 CLV13 | 2017-03-29 08:22:08 CLX13 | 2017-03-29 08:22:08 CLZ13 | 2017-03-29 08:22:08 CLF14 | 2017-03-29 08:22:08 CLG14 | 2017-03-29 08:22:08 CLH14 | 2017-03-29 08:22:08 CLJ14 | 2017-03-29 08:22:08 CLK14 | 2017-03-29 08:22:08 CLM14 | 2017-03-29 08:22:08 CLN14 | 2017-03-29 08:22:08 CLQ14 | 2017-03-29 08:22:08 CLU14 | 2017-03-29 08:22:08 CLV14 | 2017-03-29 08:22:08 CLX14 | 2017-03-29 08:22:08 CLZ14 | 2017-03-29 08:22:08 CLF15 | 2017-03-29 08:22:08 CLG15 | 2017-03-29 08:22:08 CLH15 | 2017-03-29 08:22:08 CLJ15 | 2017-03-29 08:22:08 CLK15 | 2017-03-29 08:22:08 CLM15 | 2017-03-29 08:22:08 CLN15 | 2017-03-29 08:22:08 CLQ15 | 2017-03-29 08:22:08 CLU15 | 2017-03-29 08:22:08 CLV15 | 2017-03-29 08:22:08 CLX15 | 2017-03-29 08:22:08 CLZ15 | 2017-03-29 08:22:08 CLF16 | 2017-03-29 08:22:08 CLG16 | 2017-03-29 08:22:08 CLH16 | 2017-03-29 08:22:08 CLJ16 | 2017-03-29 08:22:08 CLK16 | 2017-03-29 08:22:08 CLM16 | 2017-03-29 08:22:08 CLN16 | 2017-03-29 08:22:08 CLQ16 | 2017-03-29 08:22:08 CLU16 | 2017-03-29 08:22:08 CLV16 | 2017-03-29 08:22:08 CLX16 | 2017-03-29 08:22:08 CLZ16 | 2017-03-29 08:22:08 CLF17 | 2017-03-29 08:22:08 CLG17 | 2017-03-29 08:22:08 CLH17 | 2017-03-29 08:22:08 CLJ17 | 2017-03-29 08:22:08 CL.20170500.CME_NY | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Checking for volume based rollover dates. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20111000.CME_NY to CL.20111100.CME_NY occurs at 2011-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20111100.CME_NY to CL.20111200.CME_NY occurs at 2011-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20111200.CME_NY to CL.20120100.CME_NY occurs at 2011-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120100.CME_NY to CL.20120200.CME_NY occurs at 2011-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120200.CME_NY to CL.20120300.CME_NY occurs at 2012-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120300.CME_NY to CL.20120400.CME_NY occurs at 2012-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120400.CME_NY to CL.20120500.CME_NY occurs at 2012-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120500.CME_NY to CL.20120600.CME_NY occurs at 2012-04-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120600.CME_NY to CL.20120700.CME_NY occurs at 2012-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120700.CME_NY to CL.20120800.CME_NY occurs at 2012-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120800.CME_NY to CL.20120900.CME_NY occurs at 2012-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20120900.CME_NY to CL.20121000.CME_NY occurs at 2012-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20121000.CME_NY to CL.20121100.CME_NY occurs at 2012-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20121100.CME_NY to CL.20121200.CME_NY occurs at 2012-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20121200.CME_NY to CL.20130100.CME_NY occurs at 2012-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130100.CME_NY to CL.20130200.CME_NY occurs at 2012-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130200.CME_NY to CL.20130300.CME_NY occurs at 2013-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130300.CME_NY to CL.20130400.CME_NY occurs at 2013-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130400.CME_NY to CL.20130500.CME_NY occurs at 2013-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130500.CME_NY to CL.20130600.CME_NY occurs at 2013-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130600.CME_NY to CL.20130700.CME_NY occurs at 2013-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130700.CME_NY to CL.20130800.CME_NY occurs at 2013-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130800.CME_NY to CL.20130900.CME_NY occurs at 2013-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20130900.CME_NY to CL.20131000.CME_NY occurs at 2013-08-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20131000.CME_NY to CL.20131100.CME_NY occurs at 2013-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20131100.CME_NY to CL.20131200.CME_NY occurs at 2013-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20131200.CME_NY to CL.20140100.CME_NY occurs at 2013-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140100.CME_NY to CL.20140200.CME_NY occurs at 2013-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140200.CME_NY to CL.20140300.CME_NY occurs at 2014-01-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140300.CME_NY to CL.20140400.CME_NY occurs at 2014-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140400.CME_NY to CL.20140500.CME_NY occurs at 2014-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140500.CME_NY to CL.20140600.CME_NY occurs at 2014-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140600.CME_NY to CL.20140700.CME_NY occurs at 2014-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150600.CME_NY to CL.20150700.CME_NY occurs at 2015-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150700.CME_NY to CL.20150800.CME_NY occurs at 2015-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111000.CME_NY Open price on 2011-09-19 is 8775. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111100.CME_NY Open price on 2011-09-19 is 8780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111000.CME_NY price difference to CL.20111100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111100.CME_NY Open price on 2011-10-18 is 8620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111200.CME_NY Open price on 2011-10-18 is 8630. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111100.CME_NY price difference to CL.20111200.CME_NY is 10. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111200.CME_NY Open price on 2011-11-17 is 10176. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120100.CME_NY Open price on 2011-11-17 is 10174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20111200.CME_NY price difference to CL.20120100.CME_NY is -2. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120100.CME_NY Open price on 2011-12-19 is 9376. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120200.CME_NY Open price on 2011-12-19 is 9377. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120100.CME_NY price difference to CL.20120200.CME_NY is 1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120200.CME_NY Open price on 2012-01-19 is 10114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120300.CME_NY Open price on 2012-01-19 is 10135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120200.CME_NY price difference to CL.20120300.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120300.CME_NY Open price on 2012-02-17 is 10235. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120400.CME_NY Open price on 2012-02-17 is 10264. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120300.CME_NY price difference to CL.20120400.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120400.CME_NY Open price on 2012-03-19 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120500.CME_NY Open price on 2012-03-19 is 10778. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120400.CME_NY price difference to CL.20120500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120500.CME_NY Open price on 2012-04-19 is 10273. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120600.CME_NY Open price on 2012-04-19 is 10321. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120500.CME_NY price difference to CL.20120600.CME_NY is 48. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120600.CME_NY Open price on 2012-05-21 is 9127. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120700.CME_NY Open price on 2012-05-21 is 9171. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120600.CME_NY price difference to CL.20120700.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120700.CME_NY Open price on 2012-06-19 is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120800.CME_NY Open price on 2012-06-19 is 8344. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120700.CME_NY price difference to CL.20120800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120800.CME_NY Open price on 2012-07-19 is 9008. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120900.CME_NY Open price on 2012-07-19 is 9035. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120800.CME_NY price difference to CL.20120900.CME_NY is 27. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120900.CME_NY Open price on 2012-08-20 is 9636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121000.CME_NY Open price on 2012-08-20 is 9664. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20120900.CME_NY price difference to CL.20121000.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121000.CME_NY Open price on 2012-09-19 is 9549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121100.CME_NY Open price on 2012-09-19 is 9583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121000.CME_NY price difference to CL.20121100.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121100.CME_NY Open price on 2012-10-19 is 9204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121200.CME_NY Open price on 2012-10-19 is 9248. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121100.CME_NY price difference to CL.20121200.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121200.CME_NY Open price on 2012-11-15 is 8636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130100.CME_NY Open price on 2012-11-15 is 8677. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20121200.CME_NY price difference to CL.20130100.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130100.CME_NY Open price on 2012-12-18 is 8745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130200.CME_NY Open price on 2012-12-18 is 8794. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130100.CME_NY price difference to CL.20130200.CME_NY is 49. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130200.CME_NY Open price on 2013-01-18 is 9519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130300.CME_NY Open price on 2013-01-18 is 9565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130200.CME_NY price difference to CL.20130300.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130300.CME_NY Open price on 2013-02-19 is 9597. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130400.CME_NY Open price on 2013-02-19 is 9639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130300.CME_NY price difference to CL.20130400.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130400.CME_NY Open price on 2013-03-18 is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130500.CME_NY Open price on 2013-03-18 is 9362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130400.CME_NY price difference to CL.20130500.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130500.CME_NY Open price on 2013-04-18 is 8639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130600.CME_NY Open price on 2013-04-18 is 8660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130500.CME_NY price difference to CL.20130600.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130600.CME_NY Open price on 2013-05-20 is 9593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130700.CME_NY Open price on 2013-05-20 is 9625. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130600.CME_NY price difference to CL.20130700.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130700.CME_NY Open price on 2013-06-18 is 9793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130800.CME_NY Open price on 2013-06-18 is 9816. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130700.CME_NY price difference to CL.20130800.CME_NY is 23. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130800.CME_NY Open price on 2013-07-18 is 10656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130900.CME_NY Open price on 2013-07-18 is 10635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130800.CME_NY price difference to CL.20130900.CME_NY is -21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130900.CME_NY Open price on 2013-08-16 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131000.CME_NY Open price on 2013-08-16 is 10701. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20130900.CME_NY price difference to CL.20131000.CME_NY is -17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131000.CME_NY Open price on 2013-09-18 is 10553. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131100.CME_NY Open price on 2013-09-18 is 10477. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131000.CME_NY price difference to CL.20131100.CME_NY is -76. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131100.CME_NY Open price on 2013-10-18 is 10072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131200.CME_NY Open price on 2013-10-18 is 10100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131100.CME_NY price difference to CL.20131200.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131200.CME_NY Open price on 2013-11-19 is 9300. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140100.CME_NY Open price on 2013-11-19 is 9364. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20131200.CME_NY price difference to CL.20140100.CME_NY is 64. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140100.CME_NY Open price on 2013-12-17 is 9730. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140200.CME_NY Open price on 2013-12-17 is 9754. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140100.CME_NY price difference to CL.20140200.CME_NY is 24. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140200.CME_NY Open price on 2014-01-17 is 9417. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140300.CME_NY Open price on 2014-01-17 is 9429. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140200.CME_NY price difference to CL.20140300.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140300.CME_NY Open price on 2014-02-18 is 10032. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140400.CME_NY Open price on 2014-02-18 is 10012. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140300.CME_NY price difference to CL.20140400.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140400.CME_NY Open price on 2014-03-18 is 9797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140500.CME_NY Open price on 2014-03-18 is 9746. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140400.CME_NY price difference to CL.20140500.CME_NY is -51. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140500.CME_NY Open price on 2014-04-21 is 10454. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140600.CME_NY Open price on 2014-04-21 is 10370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140500.CME_NY price difference to CL.20140600.CME_NY is -84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140600.CME_NY Open price on 2014-05-19 is 10213. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140700.CME_NY Open price on 2014-05-19 is 10168. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140600.CME_NY price difference to CL.20140700.CME_NY is -45. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140700.CME_NY Open price on 2014-06-18 is 10660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140800.CME_NY Open price on 2014-06-18 is 10606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -54. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140800.CME_NY Open price on 2014-07-18 is 10372. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140900.CME_NY Open price on 2014-07-18 is 10277. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -95. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140900.CME_NY Open price on 2014-08-18 is 9710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141000.CME_NY Open price on 2014-08-18 is 9514. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141000.CME_NY Open price on 2014-09-19 is 9297. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141100.CME_NY Open price on 2014-09-19 is 9196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -101. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141100.CME_NY Open price on 2014-10-17 is 8318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141200.CME_NY Open price on 2014-10-17 is 8240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -78. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141200.CME_NY Open price on 2014-11-18 is 7549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150100.CME_NY Open price on 2014-11-18 is 7554. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150100.CME_NY Open price on 2014-12-18 is 5583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150200.CME_NY Open price on 2014-12-18 is 5617. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150200.CME_NY Open price on 2015-01-16 is 4635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150300.CME_NY Open price on 2015-01-16 is 4673. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150300.CME_NY Open price on 2015-02-18 is 5324. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150400.CME_NY Open price on 2015-02-18 is 5405. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150400.CME_NY Open price on 2015-03-18 is 4251. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150500.CME_NY Open price on 2015-03-18 is 4450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150500.CME_NY Open price on 2015-04-17 is 5656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150600.CME_NY Open price on 2015-04-17 is 5797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 141. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150600.CME_NY Open price on 2015-05-18 is 5985. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150700.CME_NY Open price on 2015-05-18 is 6062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150600.CME_NY price difference to CL.20150700.CME_NY is 77. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150700.CME_NY Open price on 2015-06-19 is 6050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150800.CME_NY Open price on 2015-06-19 is 6088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150700.CME_NY price difference to CL.20150800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20111000.CME_NY is 2260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20111100.CME_NY is 2255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20111200.CME_NY is 2245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120100.CME_NY is 2247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120200.CME_NY is 2246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120300.CME_NY is 2225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120400.CME_NY is 2196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120500.CME_NY is 2136. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120600.CME_NY is 2088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120700.CME_NY is 2044. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120800.CME_NY is 2006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20120900.CME_NY is 1979. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20121000.CME_NY is 1951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20121100.CME_NY is 1917. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20121200.CME_NY is 1873. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130100.CME_NY is 1832. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130200.CME_NY is 1783. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130300.CME_NY is 1737. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130400.CME_NY is 1695. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130500.CME_NY is 1659. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130600.CME_NY is 1638. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130700.CME_NY is 1606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130800.CME_NY is 1583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20130900.CME_NY is 1604. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20131000.CME_NY is 1621. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20131100.CME_NY is 1697. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20131200.CME_NY is 1669. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140100.CME_NY is 1605. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140200.CME_NY is 1581. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140300.CME_NY is 1569. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140400.CME_NY is 1589. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140500.CME_NY is 1640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140600.CME_NY is 1724. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140700.CME_NY is 1769. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140800.CME_NY is 1823. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20140900.CME_NY is 1918. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20141000.CME_NY is 2114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20141100.CME_NY is 2215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20141200.CME_NY is 2293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150100.CME_NY is 2288. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150200.CME_NY is 2254. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150300.CME_NY is 2216. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150400.CME_NY is 2135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150500.CME_NY is 1936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150600.CME_NY is 1795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150700.CME_NY is 1718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Daily #8 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:08 Chart #15 has tagged chart #7 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:08 Chart #15 has tagged chart #7 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:08 Chart #15 has tagged chart #7 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Reloading chart. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Limiting the number of years to load data for to 20 years for the continuous futures chart. Reason: Account limitation. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Limiting the number of years to download historical data for to 20 years for the continuous futures chart. Reason: Account limitation. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19961100.CME_NY to next contract occurs at 1996-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19961200.CME_NY to next contract occurs at 1996-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970100.CME_NY to next contract occurs at 1996-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970200.CME_NY to next contract occurs at 1997-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970300.CME_NY to next contract occurs at 1997-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970400.CME_NY to next contract occurs at 1997-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970500.CME_NY to next contract occurs at 1997-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970600.CME_NY to next contract occurs at 1997-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970700.CME_NY to next contract occurs at 1997-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970800.CME_NY to next contract occurs at 1997-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19970900.CME_NY to next contract occurs at 1997-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19971000.CME_NY to next contract occurs at 1997-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19971100.CME_NY to next contract occurs at 1997-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19971200.CME_NY to next contract occurs at 1997-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980100.CME_NY to next contract occurs at 1997-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980200.CME_NY to next contract occurs at 1998-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980300.CME_NY to next contract occurs at 1998-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980400.CME_NY to next contract occurs at 1998-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980500.CME_NY to next contract occurs at 1998-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980600.CME_NY to next contract occurs at 1998-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980700.CME_NY to next contract occurs at 1998-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980800.CME_NY to next contract occurs at 1998-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19980900.CME_NY to next contract occurs at 1998-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19981000.CME_NY to next contract occurs at 1998-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19981100.CME_NY to next contract occurs at 1998-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19981200.CME_NY to next contract occurs at 1998-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990100.CME_NY to next contract occurs at 1998-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990200.CME_NY to next contract occurs at 1999-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990300.CME_NY to next contract occurs at 1999-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990400.CME_NY to next contract occurs at 1999-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990500.CME_NY to next contract occurs at 1999-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990600.CME_NY to next contract occurs at 1999-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990700.CME_NY to next contract occurs at 1999-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990800.CME_NY to next contract occurs at 1999-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19990900.CME_NY to next contract occurs at 1999-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19991000.CME_NY to next contract occurs at 1999-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19991100.CME_NY to next contract occurs at 1999-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.19991200.CME_NY to next contract occurs at 1999-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000100.CME_NY to next contract occurs at 1999-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000200.CME_NY to next contract occurs at 2000-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000300.CME_NY to next contract occurs at 2000-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000400.CME_NY to next contract occurs at 2000-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000500.CME_NY to next contract occurs at 2000-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000600.CME_NY to next contract occurs at 2000-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000700.CME_NY to next contract occurs at 2000-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000800.CME_NY to next contract occurs at 2000-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20000900.CME_NY to next contract occurs at 2000-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20001000.CME_NY to next contract occurs at 2000-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20001100.CME_NY to next contract occurs at 2000-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20001200.CME_NY to next contract occurs at 2000-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010100.CME_NY to next contract occurs at 2000-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010200.CME_NY to next contract occurs at 2001-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010300.CME_NY to next contract occurs at 2001-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010400.CME_NY to next contract occurs at 2001-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010500.CME_NY to next contract occurs at 2001-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010600.CME_NY to next contract occurs at 2001-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010700.CME_NY to next contract occurs at 2001-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010800.CME_NY to next contract occurs at 2001-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20010900.CME_NY to next contract occurs at 2001-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20011000.CME_NY to next contract occurs at 2001-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20011100.CME_NY to next contract occurs at 2001-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20011200.CME_NY to next contract occurs at 2001-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020100.CME_NY to next contract occurs at 2001-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020200.CME_NY to next contract occurs at 2002-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020300.CME_NY to next contract occurs at 2002-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020400.CME_NY to next contract occurs at 2002-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020500.CME_NY to next contract occurs at 2002-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020600.CME_NY to next contract occurs at 2002-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020700.CME_NY to next contract occurs at 2002-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020800.CME_NY to next contract occurs at 2002-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20020900.CME_NY to next contract occurs at 2002-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20021000.CME_NY to next contract occurs at 2002-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20021100.CME_NY to next contract occurs at 2002-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20021200.CME_NY to next contract occurs at 2002-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030100.CME_NY to next contract occurs at 2002-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030200.CME_NY to next contract occurs at 2003-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030300.CME_NY to next contract occurs at 2003-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030400.CME_NY to next contract occurs at 2003-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030500.CME_NY to next contract occurs at 2003-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030600.CME_NY to next contract occurs at 2003-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030700.CME_NY to next contract occurs at 2003-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030800.CME_NY to next contract occurs at 2003-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20030900.CME_NY to next contract occurs at 2003-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20031000.CME_NY to next contract occurs at 2003-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20031100.CME_NY to next contract occurs at 2003-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20031200.CME_NY to next contract occurs at 2003-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040100.CME_NY to next contract occurs at 2003-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040200.CME_NY to next contract occurs at 2004-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040300.CME_NY to next contract occurs at 2004-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040400.CME_NY to next contract occurs at 2004-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040500.CME_NY to next contract occurs at 2004-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040600.CME_NY to next contract occurs at 2004-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040700.CME_NY to next contract occurs at 2004-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040800.CME_NY to next contract occurs at 2004-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20040900.CME_NY to next contract occurs at 2004-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20041000.CME_NY to next contract occurs at 2004-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20041100.CME_NY to next contract occurs at 2004-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20041200.CME_NY to next contract occurs at 2004-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050100.CME_NY to next contract occurs at 2004-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050200.CME_NY to next contract occurs at 2005-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050300.CME_NY to next contract occurs at 2005-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050400.CME_NY to next contract occurs at 2005-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050500.CME_NY to next contract occurs at 2005-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050600.CME_NY to next contract occurs at 2005-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050700.CME_NY to next contract occurs at 2005-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050800.CME_NY to next contract occurs at 2005-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20050900.CME_NY to next contract occurs at 2005-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20051000.CME_NY to next contract occurs at 2005-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20051100.CME_NY to next contract occurs at 2005-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20051200.CME_NY to next contract occurs at 2005-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060100.CME_NY to next contract occurs at 2005-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060200.CME_NY to next contract occurs at 2006-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060300.CME_NY to next contract occurs at 2006-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060400.CME_NY to next contract occurs at 2006-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060500.CME_NY to next contract occurs at 2006-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060600.CME_NY to next contract occurs at 2006-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060700.CME_NY to next contract occurs at 2006-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060800.CME_NY to next contract occurs at 2006-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20060900.CME_NY to next contract occurs at 2006-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20061000.CME_NY to next contract occurs at 2006-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20061100.CME_NY to next contract occurs at 2006-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20061200.CME_NY to next contract occurs at 2006-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070100.CME_NY to next contract occurs at 2006-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070200.CME_NY to next contract occurs at 2007-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070300.CME_NY to next contract occurs at 2007-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070400.CME_NY to next contract occurs at 2007-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070500.CME_NY to next contract occurs at 2007-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070600.CME_NY to next contract occurs at 2007-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070700.CME_NY to next contract occurs at 2007-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070800.CME_NY to next contract occurs at 2007-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20070900.CME_NY to next contract occurs at 2007-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20071000.CME_NY to next contract occurs at 2007-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20071100.CME_NY to next contract occurs at 2007-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20071200.CME_NY to next contract occurs at 2007-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080100.CME_NY to next contract occurs at 2007-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080200.CME_NY to next contract occurs at 2008-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080300.CME_NY to next contract occurs at 2008-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080400.CME_NY to next contract occurs at 2008-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080500.CME_NY to next contract occurs at 2008-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080600.CME_NY to next contract occurs at 2008-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080700.CME_NY to next contract occurs at 2008-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080800.CME_NY to next contract occurs at 2008-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20080900.CME_NY to next contract occurs at 2008-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20081000.CME_NY to next contract occurs at 2008-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20081100.CME_NY to next contract occurs at 2008-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20081200.CME_NY to next contract occurs at 2008-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090100.CME_NY to next contract occurs at 2008-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090200.CME_NY to next contract occurs at 2009-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090300.CME_NY to next contract occurs at 2009-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090400.CME_NY to next contract occurs at 2009-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090500.CME_NY to next contract occurs at 2009-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090600.CME_NY to next contract occurs at 2009-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090700.CME_NY to next contract occurs at 2009-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090800.CME_NY to next contract occurs at 2009-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20090900.CME_NY to next contract occurs at 2009-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20091000.CME_NY to next contract occurs at 2009-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20091100.CME_NY to next contract occurs at 2009-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20091200.CME_NY to next contract occurs at 2009-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100100.CME_NY to next contract occurs at 2009-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100200.CME_NY to next contract occurs at 2010-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100300.CME_NY to next contract occurs at 2010-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100400.CME_NY to next contract occurs at 2010-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100500.CME_NY to next contract occurs at 2010-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100600.CME_NY to next contract occurs at 2010-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100700.CME_NY to next contract occurs at 2010-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100800.CME_NY to next contract occurs at 2010-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20100900.CME_NY to next contract occurs at 2010-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20101000.CME_NY to next contract occurs at 2010-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20101100.CME_NY to next contract occurs at 2010-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20101200.CME_NY to next contract occurs at 2010-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110100.CME_NY to next contract occurs at 2010-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110200.CME_NY to next contract occurs at 2011-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110300.CME_NY to next contract occurs at 2011-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110400.CME_NY to next contract occurs at 2011-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110500.CME_NY to next contract occurs at 2011-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110600.CME_NY to next contract occurs at 2011-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110700.CME_NY to next contract occurs at 2011-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110800.CME_NY to next contract occurs at 2011-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20110900.CME_NY to next contract occurs at 2011-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20111000.CME_NY to next contract occurs at 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20111100.CME_NY to next contract occurs at 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20111200.CME_NY to next contract occurs at 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120100.CME_NY to next contract occurs at 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120200.CME_NY to next contract occurs at 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120300.CME_NY to next contract occurs at 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120400.CME_NY to next contract occurs at 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120500.CME_NY to next contract occurs at 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120600.CME_NY to next contract occurs at 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120700.CME_NY to next contract occurs at 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120800.CME_NY to next contract occurs at 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20120900.CME_NY to next contract occurs at 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20121000.CME_NY to next contract occurs at 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20121100.CME_NY to next contract occurs at 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20121200.CME_NY to next contract occurs at 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130100.CME_NY to next contract occurs at 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130200.CME_NY to next contract occurs at 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130300.CME_NY to next contract occurs at 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130400.CME_NY to next contract occurs at 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130500.CME_NY to next contract occurs at 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130600.CME_NY to next contract occurs at 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130700.CME_NY to next contract occurs at 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130800.CME_NY to next contract occurs at 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20130900.CME_NY to next contract occurs at 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20131000.CME_NY to next contract occurs at 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20131100.CME_NY to next contract occurs at 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20131200.CME_NY to next contract occurs at 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140100.CME_NY to next contract occurs at 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140200.CME_NY to next contract occurs at 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140300.CME_NY to next contract occurs at 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140400.CME_NY to next contract occurs at 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140500.CME_NY to next contract occurs at 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140600.CME_NY to next contract occurs at 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150700.CME_NY to next contract occurs at 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150800.CME_NY to next contract occurs at 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20150900.CME_NY to next contract occurs at 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20151000.CME_NY to next contract occurs at 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20151100.CME_NY to next contract occurs at 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20151200.CME_NY to next contract occurs at 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160100.CME_NY to next contract occurs at 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160200.CME_NY to next contract occurs at 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160300.CME_NY to next contract occurs at 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160400.CME_NY to next contract occurs at 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160500.CME_NY to next contract occurs at 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160600.CME_NY to next contract occurs at 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160700.CME_NY to next contract occurs at 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160800.CME_NY to next contract occurs at 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20160900.CME_NY to next contract occurs at 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20161000.CME_NY to next contract occurs at 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20161100.CME_NY to next contract occurs at 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20161200.CME_NY to next contract occurs at 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20170100.CME_NY to next contract occurs at 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20170200.CME_NY to next contract occurs at 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20170300.CME_NY to next contract occurs at 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20170400.CME_NY to next contract occurs at 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Date rule based rollover from CL.20170500.CME_NY to next contract occurs at 2017-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX96 for the date range from 1996-09-18 to 1996-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ96 for the date range from 1996-10-18 to 1996-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF97 for the date range from 1996-11-18 to 1996-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG97 for the date range from 1996-12-18 to 1997-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH97 for the date range from 1997-01-17 to 1997-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ97 for the date range from 1997-02-18 to 1997-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK97 for the date range from 1997-03-18 to 1997-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM97 for the date range from 1997-04-18 to 1997-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN97 for the date range from 1997-05-16 to 1997-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ97 for the date range from 1997-06-18 to 1997-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU97 for the date range from 1997-07-18 to 1997-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV97 for the date range from 1997-08-18 to 1997-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX97 for the date range from 1997-09-18 to 1997-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ97 for the date range from 1997-10-17 to 1997-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF98 for the date range from 1997-11-18 to 1997-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG98 for the date range from 1997-12-18 to 1998-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH98 for the date range from 1998-01-16 to 1998-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ98 for the date range from 1998-02-18 to 1998-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK98 for the date range from 1998-03-18 to 1998-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM98 for the date range from 1998-04-17 to 1998-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN98 for the date range from 1998-05-18 to 1998-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ98 for the date range from 1998-06-18 to 1998-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU98 for the date range from 1998-07-17 to 1998-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV98 for the date range from 1998-08-18 to 1998-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX98 for the date range from 1998-09-18 to 1998-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ98 for the date range from 1998-10-16 to 1998-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF99 for the date range from 1998-11-18 to 1998-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG99 for the date range from 1998-12-18 to 1999-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH99 for the date range from 1999-01-18 to 1999-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ99 for the date range from 1999-02-18 to 1999-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK99 for the date range from 1999-03-18 to 1999-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM99 for the date range from 1999-04-16 to 1999-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN99 for the date range from 1999-05-18 to 1999-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ99 for the date range from 1999-06-18 to 1999-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU99 for the date range from 1999-07-16 to 1999-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV99 for the date range from 1999-08-18 to 1999-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX99 for the date range from 1999-09-17 to 1999-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ99 for the date range from 1999-10-18 to 1999-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF00 for the date range from 1999-11-18 to 1999-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG00 for the date range from 1999-12-17 to 2000-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH00 for the date range from 2000-01-18 to 2000-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ00 for the date range from 2000-02-18 to 2000-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK00 for the date range from 2000-03-17 to 2000-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM00 for the date range from 2000-04-18 to 2000-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN00 for the date range from 2000-05-18 to 2000-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ00 for the date range from 2000-06-16 to 2000-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU00 for the date range from 2000-07-18 to 2000-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV00 for the date range from 2000-08-18 to 2000-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX00 for the date range from 2000-09-18 to 2000-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ00 for the date range from 2000-10-18 to 2000-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF01 for the date range from 2000-11-17 to 2000-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG01 for the date range from 2000-12-18 to 2001-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH01 for the date range from 2001-01-18 to 2001-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ01 for the date range from 2001-02-16 to 2001-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK01 for the date range from 2001-03-16 to 2001-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM01 for the date range from 2001-04-18 to 2001-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN01 for the date range from 2001-05-18 to 2001-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ01 for the date range from 2001-06-18 to 2001-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU01 for the date range from 2001-07-18 to 2001-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV01 for the date range from 2001-08-17 to 2001-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX01 for the date range from 2001-09-18 to 2001-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ01 for the date range from 2001-10-18 to 2001-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF02 for the date range from 2001-11-16 to 2001-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG02 for the date range from 2001-12-18 to 2002-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH02 for the date range from 2002-01-18 to 2002-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ02 for the date range from 2002-02-18 to 2002-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK02 for the date range from 2002-03-18 to 2002-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM02 for the date range from 2002-04-18 to 2002-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN02 for the date range from 2002-05-17 to 2002-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ02 for the date range from 2002-06-18 to 2002-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU02 for the date range from 2002-07-18 to 2002-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV02 for the date range from 2002-08-16 to 2002-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX02 for the date range from 2002-09-18 to 2002-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ02 for the date range from 2002-10-18 to 2002-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF03 for the date range from 2002-11-18 to 2002-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG03 for the date range from 2002-12-18 to 2003-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH03 for the date range from 2003-01-17 to 2003-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ03 for the date range from 2003-02-18 to 2003-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK03 for the date range from 2003-03-18 to 2003-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM03 for the date range from 2003-04-18 to 2003-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN03 for the date range from 2003-05-16 to 2003-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ03 for the date range from 2003-06-18 to 2003-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU03 for the date range from 2003-07-18 to 2003-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV03 for the date range from 2003-08-18 to 2003-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX03 for the date range from 2003-09-18 to 2003-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ03 for the date range from 2003-10-17 to 2003-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF04 for the date range from 2003-11-18 to 2003-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG04 for the date range from 2003-12-18 to 2004-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH04 for the date range from 2004-01-16 to 2004-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ04 for the date range from 2004-02-18 to 2004-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK04 for the date range from 2004-03-18 to 2004-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM04 for the date range from 2004-04-16 to 2004-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN04 for the date range from 2004-05-18 to 2004-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ04 for the date range from 2004-06-18 to 2004-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU04 for the date range from 2004-07-16 to 2004-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV04 for the date range from 2004-08-18 to 2004-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX04 for the date range from 2004-09-17 to 2004-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ04 for the date range from 2004-10-18 to 2004-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF05 for the date range from 2004-11-18 to 2004-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG05 for the date range from 2004-12-17 to 2005-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH05 for the date range from 2005-01-18 to 2005-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ05 for the date range from 2005-02-18 to 2005-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK05 for the date range from 2005-03-18 to 2005-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM05 for the date range from 2005-04-18 to 2005-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN05 for the date range from 2005-05-18 to 2005-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ05 for the date range from 2005-06-17 to 2005-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU05 for the date range from 2005-07-18 to 2005-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV05 for the date range from 2005-08-18 to 2005-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX05 for the date range from 2005-09-16 to 2005-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ05 for the date range from 2005-10-18 to 2005-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF06 for the date range from 2005-11-18 to 2005-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG06 for the date range from 2005-12-16 to 2006-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH06 for the date range from 2006-01-18 to 2006-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ06 for the date range from 2006-02-17 to 2006-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK06 for the date range from 2006-03-17 to 2006-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM06 for the date range from 2006-04-18 to 2006-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN06 for the date range from 2006-05-18 to 2006-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ06 for the date range from 2006-06-16 to 2006-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU06 for the date range from 2006-07-18 to 2006-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV06 for the date range from 2006-08-18 to 2006-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX06 for the date range from 2006-09-18 to 2006-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ06 for the date range from 2006-10-18 to 2006-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF07 for the date range from 2006-11-17 to 2006-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG07 for the date range from 2006-12-18 to 2007-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH07 for the date range from 2007-01-18 to 2007-02-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ07 for the date range from 2007-02-16 to 2007-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK07 for the date range from 2007-03-16 to 2007-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM07 for the date range from 2007-04-18 to 2007-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN07 for the date range from 2007-05-18 to 2007-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ07 for the date range from 2007-06-18 to 2007-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU07 for the date range from 2007-07-18 to 2007-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV07 for the date range from 2007-08-17 to 2007-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX07 for the date range from 2007-09-18 to 2007-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ07 for the date range from 2007-10-18 to 2007-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF08 for the date range from 2007-11-16 to 2007-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG08 for the date range from 2007-12-18 to 2008-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH08 for the date range from 2008-01-18 to 2008-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ08 for the date range from 2008-02-18 to 2008-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK08 for the date range from 2008-03-18 to 2008-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM08 for the date range from 2008-04-18 to 2008-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN08 for the date range from 2008-05-16 to 2008-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ08 for the date range from 2008-06-18 to 2008-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU08 for the date range from 2008-07-18 to 2008-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV08 for the date range from 2008-08-18 to 2008-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX08 for the date range from 2008-09-18 to 2008-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ08 for the date range from 2008-10-17 to 2008-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF09 for the date range from 2008-11-18 to 2008-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG09 for the date range from 2008-12-18 to 2009-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH09 for the date range from 2009-01-16 to 2009-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ09 for the date range from 2009-02-18 to 2009-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK09 for the date range from 2009-03-18 to 2009-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM09 for the date range from 2009-04-17 to 2009-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN09 for the date range from 2009-05-18 to 2009-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ09 for the date range from 2009-06-18 to 2009-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU09 for the date range from 2009-07-17 to 2009-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV09 for the date range from 2009-08-18 to 2009-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX09 for the date range from 2009-09-18 to 2009-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ09 for the date range from 2009-10-16 to 2009-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF10 for the date range from 2009-11-18 to 2009-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG10 for the date range from 2009-12-18 to 2010-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH10 for the date range from 2010-01-18 to 2010-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ10 for the date range from 2010-02-18 to 2010-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK10 for the date range from 2010-03-18 to 2010-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM10 for the date range from 2010-04-16 to 2010-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN10 for the date range from 2010-05-18 to 2010-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ10 for the date range from 2010-06-18 to 2010-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU10 for the date range from 2010-07-16 to 2010-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV10 for the date range from 2010-08-18 to 2010-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX10 for the date range from 2010-09-17 to 2010-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ10 for the date range from 2010-10-18 to 2010-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF11 for the date range from 2010-11-18 to 2010-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG11 for the date range from 2010-12-17 to 2011-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH11 for the date range from 2011-01-18 to 2011-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ11 for the date range from 2011-02-18 to 2011-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK11 for the date range from 2011-03-18 to 2011-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM11 for the date range from 2011-04-18 to 2011-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN11 for the date range from 2011-05-18 to 2011-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ11 for the date range from 2011-06-17 to 2011-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU11 for the date range from 2011-07-18 to 2011-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV11 for the date range from 2011-08-18 to 2011-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX11 for the date range from 2011-09-16 to 2011-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ11 for the date range from 2011-10-18 to 2011-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF12 for the date range from 2011-11-18 to 2011-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG12 for the date range from 2011-12-16 to 2012-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH12 for the date range from 2012-01-18 to 2012-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ12 for the date range from 2012-02-17 to 2012-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK12 for the date range from 2012-03-16 to 2012-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM12 for the date range from 2012-04-18 to 2012-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN12 for the date range from 2012-05-18 to 2012-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ12 for the date range from 2012-06-18 to 2012-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU12 for the date range from 2012-07-18 to 2012-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV12 for the date range from 2012-08-17 to 2012-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX12 for the date range from 2012-09-18 to 2012-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ12 for the date range from 2012-10-18 to 2012-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF13 for the date range from 2012-11-16 to 2012-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG13 for the date range from 2012-12-18 to 2013-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH13 for the date range from 2013-01-18 to 2013-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ13 for the date range from 2013-02-18 to 2013-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK13 for the date range from 2013-03-18 to 2013-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM13 for the date range from 2013-04-18 to 2013-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN13 for the date range from 2013-05-17 to 2013-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ13 for the date range from 2013-06-18 to 2013-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU13 for the date range from 2013-07-18 to 2013-08-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV13 for the date range from 2013-08-16 to 2013-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX13 for the date range from 2013-09-18 to 2013-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ13 for the date range from 2013-10-18 to 2013-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF14 for the date range from 2013-11-18 to 2013-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG14 for the date range from 2013-12-18 to 2014-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH14 for the date range from 2014-01-17 to 2014-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ14 for the date range from 2014-02-18 to 2014-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK14 for the date range from 2014-03-18 to 2014-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM14 for the date range from 2014-04-18 to 2014-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN14 for the date range from 2014-05-16 to 2014-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ14 for the date range from 2014-06-18 to 2014-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU14 for the date range from 2014-07-18 to 2014-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV14 for the date range from 2014-08-18 to 2014-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX14 for the date range from 2014-09-18 to 2014-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ14 for the date range from 2014-10-17 to 2014-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF15 for the date range from 2014-11-18 to 2014-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG15 for the date range from 2014-12-18 to 2015-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH15 for the date range from 2015-01-16 to 2015-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ15 for the date range from 2015-02-18 to 2015-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK15 for the date range from 2015-03-18 to 2015-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM15 for the date range from 2015-04-17 to 2015-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN15 for the date range from 2015-05-18 to 2015-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ15 for the date range from 2015-06-18 to 2015-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU15 for the date range from 2015-07-17 to 2015-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV15 for the date range from 2015-08-18 to 2015-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX15 for the date range from 2015-09-18 to 2015-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ15 for the date range from 2015-10-16 to 2015-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF16 for the date range from 2015-11-18 to 2015-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG16 for the date range from 2015-12-18 to 2016-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH16 for the date range from 2016-01-18 to 2016-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-18 to 2016-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-18 to 2016-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLM16 for the date range from 2016-04-18 to 2016-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLN16 for the date range from 2016-05-18 to 2016-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLQ16 for the date range from 2016-06-17 to 2016-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLU16 for the date range from 2016-07-18 to 2016-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLV16 for the date range from 2016-08-18 to 2016-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLX16 for the date range from 2016-09-16 to 2016-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLZ16 for the date range from 2016-10-18 to 2016-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLF17 for the date range from 2016-11-18 to 2016-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLG17 for the date range from 2016-12-16 to 2017-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLH17 for the date range from 2017-01-18 to 2017-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CLJ17 for the date range from 2017-02-17 to 2017-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking Daily data file for symbol CL.20170500.CME_NY for the date range from 2017-03-17 to 2017-03-29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CL.20170500.CME_NY.dly. Date: 2017-03-17, Price: 4931. Date: 2017-03-29, Price: 4857 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ17.dly. Date: 2017-02-17, Price: 5378. Date: 2017-03-16, Price: 4875 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH17.dly. Date: 2017-01-18, Price: 5189. Date: 2017-02-16, Price: 5336 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG17.dly. Date: 2016-12-16, Price: 5295. Date: 2017-01-17, Price: 5248 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF17.dly. Date: 2016-11-18, Price: 4636. Date: 2016-12-15, Price: 5090 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ16.dly. Date: 2016-10-18, Price: 5062. Date: 2016-11-17, Price: 4542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX16.dly. Date: 2016-09-16, Price: 4362. Date: 2016-10-17, Price: 4994 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV16.dly. Date: 2016-08-18, Price: 4889. Date: 2016-09-15, Price: 4391 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU16.dly. Date: 2016-07-18, Price: 4594. Date: 2016-08-17, Price: 4679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ16.dly. Date: 2016-06-17, Price: 4856. Date: 2016-07-15, Price: 4595 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN16.dly. Date: 2016-05-18, Price: 4878. Date: 2016-06-16, Price: 4621 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM16.dly. Date: 2016-04-18, Price: 4119. Date: 2016-05-17, Price: 4831 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK16.dly. Date: 2016-03-18, Price: 4114. Date: 2016-04-15, Price: 4036 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ16.dly. Date: 2016-02-18, Price: 3293. Date: 2016-03-17, Price: 4020 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH16.dly. Date: 2016-01-18, Price: 2957. Date: 2016-02-17, Price: 3066 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG16.dly. Date: 2015-12-18, Price: 3606. Date: 2016-01-15, Price: 2942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF16.dly. Date: 2015-11-18, Price: 4195. Date: 2015-12-17, Price: 3495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ15.dly. Date: 2015-10-16, Price: 4772. Date: 2015-11-17, Price: 4067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX15.dly. Date: 2015-09-18, Price: 4502. Date: 2015-10-15, Price: 4638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV15.dly. Date: 2015-08-18, Price: 4312. Date: 2015-09-17, Price: 4690 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU15.dly. Date: 2015-07-17, Price: 5121. Date: 2015-08-17, Price: 4187 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ15.dly. Date: 2015-06-18, Price: 6082. Date: 2015-07-16, Price: 5091 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN15.dly. Date: 2015-05-18, Price: 6024. Date: 2015-06-17, Price: 5992 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM15.dly. Date: 2015-04-17, Price: 5732. Date: 2015-05-15, Price: 5969 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK15.dly. Date: 2015-03-18, Price: 4665. Date: 2015-04-16, Price: 5671 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ15.dly. Date: 2015-02-18, Price: 5282. Date: 2015-03-17, Price: 4346 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH15.dly. Date: 2015-01-16, Price: 4913. Date: 2015-02-17, Price: 5353 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG15.dly. Date: 2014-12-18, Price: 5436. Date: 2015-01-15, Price: 4625 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF15.dly. Date: 2014-11-18, Price: 7464. Date: 2014-12-17, Price: 5647 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ14.dly. Date: 2014-10-17, Price: 8206. Date: 2014-11-17, Price: 7564 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX14.dly. Date: 2014-09-18, Price: 9198. Date: 2014-10-16, Price: 8270 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV14.dly. Date: 2014-08-18, Price: 9375. Date: 2014-09-17, Price: 9442 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU14.dly. Date: 2014-07-18, Price: 10195. Date: 2014-08-15, Price: 9735 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ14.dly. Date: 2014-06-18, Price: 10559. Date: 2014-07-17, Price: 10319 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN14.dly. Date: 2014-05-16, Price: 10158. Date: 2014-06-17, Price: 10636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM14.dly. Date: 2014-04-18, Price: 10365. Date: 2014-05-15, Price: 10150 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK14.dly. Date: 2014-03-18, Price: 9888. Date: 2014-04-17, Price: 10430 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ14.dly. Date: 2014-02-18, Price: 10210. Date: 2014-03-17, Price: 9808 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH14.dly. Date: 2014-01-17, Price: 9459. Date: 2014-02-17, Price: 10243 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG14.dly. Date: 2013-12-18, Price: 9806. Date: 2014-01-16, Price: 9396 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF14.dly. Date: 2013-11-18, Price: 9368. Date: 2013-12-17, Price: 9722 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ13.dly. Date: 2013-10-18, Price: 10111. Date: 2013-11-15, Price: 9384 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX13.dly. Date: 2013-09-18, Price: 10728. Date: 2013-10-17, Price: 10067 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV13.dly. Date: 2013-08-16, Price: 10729. Date: 2013-09-17, Price: 10542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU13.dly. Date: 2013-07-18, Price: 10781. Date: 2013-08-15, Price: 10733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ13.dly. Date: 2013-06-18, Price: 9867. Date: 2013-07-17, Price: 10648 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN13.dly. Date: 2013-05-17, Price: 9629. Date: 2013-06-17, Price: 9777 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM13.dly. Date: 2013-04-18, Price: 8800. Date: 2013-05-16, Price: 9516 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK13.dly. Date: 2013-03-18, Price: 9411. Date: 2013-04-17, Price: 8668 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ13.dly. Date: 2013-02-18, Price: 9710. Date: 2013-03-15, Price: 9345 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH13.dly. Date: 2013-01-18, Price: 9604. Date: 2013-02-15, Price: 9586 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG13.dly. Date: 2012-12-18, Price: 8840. Date: 2013-01-17, Price: 9549 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF13.dly. Date: 2012-11-16, Price: 8692. Date: 2012-12-17, Price: 8720 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ12.dly. Date: 2012-10-18, Price: 9253. Date: 2012-11-15, Price: 8545 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX12.dly. Date: 2012-09-18, Price: 9562. Date: 2012-10-17, Price: 9212 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV12.dly. Date: 2012-08-17, Price: 9632. Date: 2012-09-17, Price: 9662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU12.dly. Date: 2012-07-18, Price: 9017. Date: 2012-08-16, Price: 9560 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ12.dly. Date: 2012-06-18, Price: 8360. Date: 2012-07-17, Price: 8922 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN12.dly. Date: 2012-05-18, Price: 9180. Date: 2012-06-15, Price: 8403 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM12.dly. Date: 2012-04-18, Price: 10312. Date: 2012-05-17, Price: 9256 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK12.dly. Date: 2012-03-16, Price: 10758. Date: 2012-04-17, Price: 10420 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ12.dly. Date: 2012-02-17, Price: 10360. Date: 2012-03-15, Price: 10511 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH12.dly. Date: 2012-01-18, Price: 10076. Date: 2012-02-16, Price: 10231 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG12.dly. Date: 2011-12-16, Price: 9375. Date: 2012-01-17, Price: 10071 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF12.dly. Date: 2011-11-18, Price: 9767. Date: 2011-12-15, Price: 9387 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ11.dly. Date: 2011-10-18, Price: 8853. Date: 2011-11-17, Price: 9882 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX11.dly. Date: 2011-09-16, Price: 8818. Date: 2011-10-17, Price: 8638 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV11.dly. Date: 2011-08-18, Price: 8251. Date: 2011-09-15, Price: 8940 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU11.dly. Date: 2011-07-18, Price: 9625. Date: 2011-08-17, Price: 8758 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ11.dly. Date: 2011-06-17, Price: 9340. Date: 2011-07-15, Price: 9724 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN11.dly. Date: 2011-05-18, Price: 10056. Date: 2011-06-16, Price: 9495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM11.dly. Date: 2011-04-18, Price: 10769. Date: 2011-05-17, Price: 9691 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK11.dly. Date: 2011-03-18, Price: 10185. Date: 2011-04-15, Price: 10966 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ11.dly. Date: 2011-02-18, Price: 8971. Date: 2011-03-17, Price: 10142 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH11.dly. Date: 2011-01-18, Price: 9231. Date: 2011-02-17, Price: 8636 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG11.dly. Date: 2010-12-17, Price: 8860. Date: 2011-01-17, Price: 9138 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF11.dly. Date: 2010-11-18, Price: 8242. Date: 2010-12-16, Price: 8770 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ10.dly. Date: 2010-10-18, Price: 8380. Date: 2010-11-17, Price: 8044 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX10.dly. Date: 2010-09-17, Price: 7492. Date: 2010-10-15, Price: 8125 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV10.dly. Date: 2010-08-18, Price: 7578. Date: 2010-09-16, Price: 7457 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU10.dly. Date: 2010-07-16, Price: 7638. Date: 2010-08-17, Price: 7577 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ10.dly. Date: 2010-06-18, Price: 7826. Date: 2010-07-15, Price: 7662 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN10.dly. Date: 2010-05-18, Price: 7270. Date: 2010-06-17, Price: 7679 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM10.dly. Date: 2010-04-16, Price: 8467. Date: 2010-05-17, Price: 7008 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK10.dly. Date: 2010-03-18, Price: 8254. Date: 2010-04-15, Price: 8551 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ10.dly. Date: 2010-02-18, Price: 7942. Date: 2010-03-17, Price: 8293 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH10.dly. Date: 2010-01-18, Price: 7932. Date: 2010-02-17, Price: 7733 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG10.dly. Date: 2009-12-18, Price: 7442. Date: 2010-01-15, Price: 7800 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF10.dly. Date: 2009-11-18, Price: 8010. Date: 2009-12-17, Price: 7265 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ09.dly. Date: 2009-10-16, Price: 7902. Date: 2009-11-17, Price: 7914 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX09.dly. Date: 2009-09-18, Price: 7249. Date: 2009-10-15, Price: 7758 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV09.dly. Date: 2009-08-18, Price: 7109. Date: 2009-09-17, Price: 7247 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU09.dly. Date: 2009-07-17, Price: 6458. Date: 2009-08-17, Price: 6675 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ09.dly. Date: 2009-06-18, Price: 7191. Date: 2009-07-16, Price: 6202 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN09.dly. Date: 2009-05-18, Price: 5959. Date: 2009-06-17, Price: 7103 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM09.dly. Date: 2009-04-17, Price: 5247. Date: 2009-05-15, Price: 5634 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK09.dly. Date: 2009-03-18, Price: 4890. Date: 2009-04-16, Price: 4998 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ09.dly. Date: 2009-02-18, Price: 3741. Date: 2009-03-17, Price: 4916 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH09.dly. Date: 2009-01-16, Price: 4257. Date: 2009-02-17, Price: 3493 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG09.dly. Date: 2008-12-18, Price: 4167. Date: 2009-01-15, Price: 3540 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF09.dly. Date: 2008-11-18, Price: 5476. Date: 2008-12-17, Price: 4006 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ08.dly. Date: 2008-10-17, Price: 7213. Date: 2008-11-17, Price: 5495 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX08.dly. Date: 2008-09-18, Price: 9754. Date: 2008-10-16, Price: 6985 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV08.dly. Date: 2008-08-18, Price: 11289. Date: 2008-09-17, Price: 9716 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU08.dly. Date: 2008-07-18, Price: 12947. Date: 2008-08-15, Price: 11377 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ08.dly. Date: 2008-06-18, Price: 13717. Date: 2008-07-17, Price: 12929 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN08.dly. Date: 2008-05-16, Price: 12604. Date: 2008-06-17, Price: 13401 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM08.dly. Date: 2008-04-18, Price: 11616. Date: 2008-05-15, Price: 12412 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK08.dly. Date: 2008-03-18, Price: 10850. Date: 2008-04-17, Price: 11486 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ08.dly. Date: 2008-02-18, Price: 9970. Date: 2008-03-17, Price: 10568 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH08.dly. Date: 2008-01-18, Price: 8992. Date: 2008-02-15, Price: 9550 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG08.dly. Date: 2007-12-18, Price: 9008. Date: 2008-01-17, Price: 9013 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF08.dly. Date: 2007-11-16, Price: 9384. Date: 2007-12-17, Price: 9063 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ07.dly. Date: 2007-10-18, Price: 8804. Date: 2007-11-15, Price: 9343 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX07.dly. Date: 2007-09-18, Price: 8023. Date: 2007-10-17, Price: 8740 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV07.dly. Date: 2007-08-17, Price: 7182. Date: 2007-09-17, Price: 8057 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU07.dly. Date: 2007-07-18, Price: 7530. Date: 2007-08-16, Price: 7100 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ07.dly. Date: 2007-06-18, Price: 6962. Date: 2007-07-17, Price: 7402 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN07.dly. Date: 2007-05-18, Price: 6598. Date: 2007-06-15, Price: 6800 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM07.dly. Date: 2007-04-18, Price: 6438. Date: 2007-05-17, Price: 6486 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK07.dly. Date: 2007-03-16, Price: 5958. Date: 2007-04-17, Price: 6310 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ07.dly. Date: 2007-02-16, Price: 5986. Date: 2007-03-15, Price: 5755 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH07.dly. Date: 2007-01-18, Price: 5181. Date: 2007-02-15, Price: 5799 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG07.dly. Date: 2006-12-18, Price: 6279. Date: 2007-01-17, Price: 5224 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF07.dly. Date: 2006-11-17, Price: 5897. Date: 2006-12-15, Price: 6343 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ06.dly. Date: 2006-10-18, Price: 5930. Date: 2006-11-16, Price: 5626 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX06.dly. Date: 2006-09-18, Price: 6445. Date: 2006-10-17, Price: 5893 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV06.dly. Date: 2006-08-18, Price: 7210. Date: 2006-09-15, Price: 6333 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU06.dly. Date: 2006-07-18, Price: 7526. Date: 2006-08-17, Price: 7006 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ06.dly. Date: 2006-06-16, Price: 7020. Date: 2006-07-17, Price: 7530 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN06.dly. Date: 2006-05-18, Price: 7014. Date: 2006-06-15, Price: 6950 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM06.dly. Date: 2006-04-18, Price: 7309. Date: 2006-05-17, Price: 6869 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK06.dly. Date: 2006-03-17, Price: 6420. Date: 2006-04-17, Price: 7040 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ06.dly. Date: 2006-02-17, Price: 6129. Date: 2006-03-16, Price: 6358 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH06.dly. Date: 2006-01-18, Price: 6625. Date: 2006-02-16, Price: 5846 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG06.dly. Date: 2005-12-16, Price: 5905. Date: 2006-01-17, Price: 6631 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF06.dly. Date: 2005-11-18, Price: 5721. Date: 2005-12-15, Price: 5999 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ05.dly. Date: 2005-10-18, Price: 6244. Date: 2005-11-17, Price: 5634 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX05.dly. Date: 2005-09-16, Price: 6334. Date: 2005-10-17, Price: 6436 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV05.dly. Date: 2005-08-18, Price: 6377. Date: 2005-09-15, Price: 6475 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU05.dly. Date: 2005-07-18, Price: 5842. Date: 2005-08-17, Price: 6325 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ05.dly. Date: 2005-06-17, Price: 5918. Date: 2005-07-15, Price: 5809 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN05.dly. Date: 2005-05-18, Price: 4913. Date: 2005-06-16, Price: 5658 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM05.dly. Date: 2005-04-18, Price: 5147. Date: 2005-05-17, Price: 4897 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK05.dly. Date: 2005-03-18, Price: 5724. Date: 2005-04-15, Price: 5049 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ05.dly. Date: 2005-02-18, Price: 4901. Date: 2005-03-17, Price: 5640 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH05.dly. Date: 2005-01-18, Price: 4848. Date: 2005-02-17, Price: 4754 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG05.dly. Date: 2004-12-17, Price: 4657. Date: 2005-01-17, Price: 4838 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF05.dly. Date: 2004-11-18, Price: 4638. Date: 2004-12-16, Price: 4418 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ04.dly. Date: 2004-10-18, Price: 5284. Date: 2004-11-17, Price: 4684 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX04.dly. Date: 2004-09-17, Price: 4559. Date: 2004-10-15, Price: 5493 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV04.dly. Date: 2004-08-18, Price: 4635. Date: 2004-09-16, Price: 4388 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU04.dly. Date: 2004-07-16, Price: 4130. Date: 2004-08-17, Price: 4675 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ04.dly. Date: 2004-06-18, Price: 3900. Date: 2004-07-15, Price: 4077 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN04.dly. Date: 2004-05-18, Price: 4042. Date: 2004-06-17, Price: 3846 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM04.dly. Date: 2004-04-16, Price: 3699. Date: 2004-05-17, Price: 4155 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK04.dly. Date: 2004-03-18, Price: 3739. Date: 2004-04-15, Price: 3757 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ04.dly. Date: 2004-02-18, Price: 3448. Date: 2004-03-17, Price: 3818 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH04.dly. Date: 2004-01-16, Price: 3400. Date: 2004-02-17, Price: 3519 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG04.dly. Date: 2003-12-18, Price: 3375. Date: 2004-01-15, Price: 3344 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF04.dly. Date: 2003-11-18, Price: 3270. Date: 2003-12-17, Price: 3335 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ03.dly. Date: 2003-10-17, Price: 3070. Date: 2003-11-17, Price: 3173 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX03.dly. Date: 2003-09-18, Price: 2724. Date: 2003-10-16, Price: 3154 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV03.dly. Date: 2003-08-18, Price: 3088. Date: 2003-09-17, Price: 2703 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU03.dly. Date: 2003-07-18, Price: 3103. Date: 2003-08-15, Price: 3105 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ03.dly. Date: 2003-06-18, Price: 2877. Date: 2003-07-17, Price: 3141 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN03.dly. Date: 2003-05-16, Price: 2875. Date: 2003-06-17, Price: 3107 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM03.dly. Date: 2003-04-18, Price: 2883. Date: 2003-05-15, Price: 2874 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK03.dly. Date: 2003-03-18, Price: 3005. Date: 2003-04-17, Price: 3055 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ03.dly. Date: 2003-02-18, Price: 3551. Date: 2003-03-17, Price: 3493 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH03.dly. Date: 2003-01-17, Price: 3296. Date: 2003-02-17, Price: 3696 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG03.dly. Date: 2002-12-18, Price: 3043. Date: 2003-01-16, Price: 3366 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF03.dly. Date: 2002-11-18, Price: 2580. Date: 2002-12-17, Price: 3010 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ02.dly. Date: 2002-10-18, Price: 2960. Date: 2002-11-15, Price: 2551 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX02.dly. Date: 2002-09-18, Price: 2967. Date: 2002-10-17, Price: 2962 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV02.dly. Date: 2002-08-16, Price: 2851. Date: 2002-09-17, Price: 2908 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU02.dly. Date: 2002-07-18, Price: 2766. Date: 2002-08-15, Price: 2906 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ02.dly. Date: 2002-06-18, Price: 2565. Date: 2002-07-17, Price: 2788 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN02.dly. Date: 2002-05-17, Price: 2715. Date: 2002-06-17, Price: 2609 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM02.dly. Date: 2002-04-18, Price: 2628. Date: 2002-05-16, Price: 2795 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK02.dly. Date: 2002-03-18, Price: 2544. Date: 2002-04-17, Price: 2594 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ02.dly. Date: 2002-02-18, Price: 2112. Date: 2002-03-15, Price: 2451 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH02.dly. Date: 2002-01-18, Price: 1866. Date: 2002-02-15, Price: 2150 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG02.dly. Date: 2001-12-18, Price: 1960. Date: 2002-01-17, Price: 1797 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF02.dly. Date: 2001-11-16, Price: 1837. Date: 2001-12-17, Price: 1922 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ01.dly. Date: 2001-10-18, Price: 2148. Date: 2001-11-15, Price: 1745 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX01.dly. Date: 2001-09-18, Price: 2808. Date: 2001-10-17, Price: 2181 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV01.dly. Date: 2001-08-17, Price: 2561. Date: 2001-09-17, Price: 2881 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU01.dly. Date: 2001-07-18, Price: 2493. Date: 2001-08-16, Price: 2740 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ01.dly. Date: 2001-06-18, Price: 2767. Date: 2001-07-17, Price: 2557 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN01.dly. Date: 2001-05-18, Price: 3034. Date: 2001-06-15, Price: 2851 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM01.dly. Date: 2001-04-18, Price: 2855. Date: 2001-05-17, Price: 2891 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK01.dly. Date: 2001-03-16, Price: 2692. Date: 2001-04-17, Price: 2824 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ01.dly. Date: 2001-02-16, Price: 2900. Date: 2001-03-15, Price: 2655 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH01.dly. Date: 2001-01-18, Price: 2867. Date: 2001-02-15, Price: 2880 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG01.dly. Date: 2000-12-18, Price: 2859. Date: 2001-01-17, Price: 2960 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG01.dly has a volume of 0 at 2000-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF01.dly. Date: 2000-11-17, Price: 3503. Date: 2000-12-15, Price: 2887 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF01.dly has a volume of 0 at 2000-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF01.dly has a volume of 0 at 2000-12-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ00.dly. Date: 2000-10-18, Price: 3247. Date: 2000-11-16, Price: 3512 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ00.dly has a volume of 0 at 2000-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ00.dly has a volume of 0 at 2000-11-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX00.dly. Date: 2000-09-18, Price: 3555. Date: 2000-10-17, Price: 3299 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX00.dly has a volume of 0 at 2000-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX00.dly has a volume of 0 at 2000-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV00.dly. Date: 2000-08-18, Price: 3156. Date: 2000-09-15, Price: 3592 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV00.dly has a volume of 0 at 2000-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV00.dly has a volume of 0 at 2000-09-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU00.dly. Date: 2000-07-18, Price: 3064. Date: 2000-08-17, Price: 3194 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU00.dly has a volume of 0 at 2000-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU00.dly has a volume of 0 at 2000-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ00.dly. Date: 2000-06-16, Price: 3002. Date: 2000-07-17, Price: 3083 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ00.dly has a volume of 0 at 2000-06-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ00.dly has a volume of 0 at 2000-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN00.dly. Date: 2000-05-18, Price: 3023. Date: 2000-06-15, Price: 3295 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN00.dly has a volume of 0 at 2000-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN00.dly has a volume of 0 at 2000-06-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM00.dly. Date: 2000-04-18, Price: 2485. Date: 2000-05-17, Price: 2932 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM00.dly has a volume of 0 at 2000-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM00.dly has a volume of 0 at 2000-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK00.dly. Date: 2000-03-17, Price: 2908. Date: 2000-04-17, Price: 2589 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK00.dly has a volume of 0 at 2000-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK00.dly has a volume of 0 at 2000-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ00.dly. Date: 2000-02-18, Price: 2845. Date: 2000-03-16, Price: 3109 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ00.dly has a volume of 0 at 2000-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ00.dly has a volume of 0 at 2000-03-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH00.dly. Date: 2000-01-18, Price: 2780. Date: 2000-02-17, Price: 2946 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH00.dly has a volume of 0 at 2000-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH00.dly has a volume of 0 at 2000-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG00.dly. Date: 1999-12-17, Price: 2652. Date: 2000-01-17, Price: 2885 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG00.dly has a volume of 0 at 1999-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG00.dly has a volume of 0 at 2000-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF00.dly. Date: 1999-11-18, Price: 2533. Date: 1999-12-16, Price: 2683 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF00.dly has a volume of 0 at 1999-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF00.dly has a volume of 0 at 1999-12-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ99.dly. Date: 1999-10-18, Price: 2271. Date: 1999-11-17, Price: 2660 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ99.dly has a volume of 0 at 1999-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ99.dly has a volume of 0 at 1999-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX99.dly. Date: 1999-09-17, Price: 2418. Date: 1999-10-15, Price: 2282 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX99.dly has a volume of 0 at 1999-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX99.dly has a volume of 0 at 1999-10-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV99.dly. Date: 1999-08-18, Price: 2173. Date: 1999-09-16, Price: 2451 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV99.dly has a volume of 0 at 1999-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV99.dly has a volume of 0 at 1999-09-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU99.dly. Date: 1999-07-16, Price: 2072. Date: 1999-08-17, Price: 2174 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU99.dly has a volume of 0 at 1999-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU99.dly has a volume of 0 at 1999-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ99.dly. Date: 1999-06-18, Price: 1818. Date: 1999-07-15, Price: 2016 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ99.dly has a volume of 0 at 1999-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ99.dly has a volume of 0 at 1999-07-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN99.dly. Date: 1999-05-18, Price: 1705. Date: 1999-06-17, Price: 1819 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN99.dly has a volume of 0 at 1999-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN99.dly has a volume of 0 at 1999-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM99.dly. Date: 1999-04-16, Price: 1734. Date: 1999-05-17, Price: 1794 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM99.dly has a volume of 0 at 1999-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM99.dly has a volume of 0 at 1999-05-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK99.dly. Date: 1999-03-18, Price: 1510. Date: 1999-04-15, Price: 1687 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK99.dly has a volume of 0 at 1999-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK99.dly has a volume of 0 at 1999-04-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ99.dly. Date: 1999-02-18, Price: 1217. Date: 1999-03-17, Price: 1505 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ99.dly has a volume of 0 at 1999-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ99.dly has a volume of 0 at 1999-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH99.dly. Date: 1999-01-18, Price: 1219. Date: 1999-02-17, Price: 1153 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH99.dly has a volume of 0 at 1999-01-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH99.dly has a volume of 0 at 1999-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG99.dly. Date: 1998-12-18, Price: 1126. Date: 1999-01-15, Price: 1211 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG99.dly has a volume of 0 at 1998-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG99.dly has a volume of 0 at 1999-01-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF99.dly. Date: 1998-11-18, Price: 1276. Date: 1998-12-17, Price: 1103 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF99.dly has a volume of 0 at 1998-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF99.dly has a volume of 0 at 1998-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ98.dly. Date: 1998-10-16, Price: 1433. Date: 1998-11-17, Price: 1245 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ98.dly has a volume of 0 at 1998-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ98.dly has a volume of 0 at 1998-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX98.dly. Date: 1998-09-18, Price: 1562. Date: 1998-10-15, Price: 1405 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX98.dly has a volume of 0 at 1998-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX98.dly has a volume of 0 at 1998-10-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV98.dly. Date: 1998-08-18, Price: 1317. Date: 1998-09-17, Price: 1486 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV98.dly has a volume of 0 at 1998-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV98.dly has a volume of 0 at 1998-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU98.dly. Date: 1998-07-17, Price: 1430. Date: 1998-08-17, Price: 1320 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU98.dly has a volume of 0 at 1998-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU98.dly has a volume of 0 at 1998-08-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ98.dly. Date: 1998-06-18, Price: 1310. Date: 1998-07-16, Price: 1448 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ98.dly has a volume of 0 at 1998-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ98.dly has a volume of 0 at 1998-07-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN98.dly. Date: 1998-05-18, Price: 1511. Date: 1998-06-17, Price: 1255 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN98.dly has a volume of 0 at 1998-05-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN98.dly has a volume of 0 at 1998-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM98.dly. Date: 1998-04-17, Price: 1591. Date: 1998-05-15, Price: 1447 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM98.dly has a volume of 0 at 1998-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM98.dly has a volume of 0 at 1998-05-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK98.dly. Date: 1998-03-18, Price: 1461. Date: 1998-04-16, Price: 1590 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK98.dly has a volume of 0 at 1998-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK98.dly has a volume of 0 at 1998-04-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ98.dly. Date: 1998-02-18, Price: 1645. Date: 1998-03-17, Price: 1321 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ98.dly has a volume of 0 at 1998-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ98.dly has a volume of 0 at 1998-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH98.dly. Date: 1998-01-16, Price: 1669. Date: 1998-02-17, Price: 1566 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH98.dly has a volume of 0 at 1998-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH98.dly has a volume of 0 at 1998-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG98.dly. Date: 1997-12-18, Price: 1874. Date: 1998-01-15, Price: 1634 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG98.dly has a volume of 0 at 1997-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG98.dly has a volume of 0 at 1998-01-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF98.dly. Date: 1997-11-18, Price: 2029. Date: 1997-12-17, Price: 1819 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF98.dly has a volume of 0 at 1997-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF98.dly has a volume of 0 at 1997-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ97.dly. Date: 1997-10-17, Price: 2074. Date: 1997-11-17, Price: 2026 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ97.dly has a volume of 0 at 1997-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ97.dly has a volume of 0 at 1997-11-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX97.dly. Date: 1997-09-18, Price: 1953. Date: 1997-10-16, Price: 2097 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX97.dly has a volume of 0 at 1997-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX97.dly has a volume of 0 at 1997-10-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLV97.dly. Date: 1997-08-18, Price: 2015. Date: 1997-09-17, Price: 1942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV97.dly has a volume of 0 at 1997-08-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLV97.dly has a volume of 0 at 1997-09-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLU97.dly. Date: 1997-07-18, Price: 1943. Date: 1997-08-15, Price: 2007 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU97.dly has a volume of 0 at 1997-07-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLU97.dly has a volume of 0 at 1997-08-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLQ97.dly. Date: 1997-06-18, Price: 1892. Date: 1997-07-17, Price: 1999 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ97.dly has a volume of 0 at 1997-06-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLQ97.dly has a volume of 0 at 1997-07-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLN97.dly. Date: 1997-05-16, Price: 2218. Date: 1997-06-17, Price: 1923 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN97.dly has a volume of 0 at 1997-05-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLN97.dly has a volume of 0 at 1997-06-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLM97.dly. Date: 1997-04-18, Price: 1967. Date: 1997-05-15, Price: 2130 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM97.dly has a volume of 0 at 1997-04-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLM97.dly has a volume of 0 at 1997-05-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLK97.dly. Date: 1997-03-18, Price: 2168. Date: 1997-04-17, Price: 1942 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK97.dly has a volume of 0 at 1997-03-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLK97.dly has a volume of 0 at 1997-04-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLJ97.dly. Date: 1997-02-18, Price: 2212. Date: 1997-03-17, Price: 2092 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ97.dly has a volume of 0 at 1997-02-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLJ97.dly has a volume of 0 at 1997-03-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLH97.dly. Date: 1997-01-17, Price: 2443. Date: 1997-02-17, Price: 2252 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH97.dly has a volume of 0 at 1997-01-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLH97.dly has a volume of 0 at 1997-02-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLG97.dly. Date: 1996-12-18, Price: 2526. Date: 1997-01-16, Price: 2552 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG97.dly has a volume of 0 at 1996-12-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLG97.dly has a volume of 0 at 1997-01-16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLF97.dly. Date: 1996-11-18, Price: 2366. Date: 1996-12-17, Price: 2571 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF97.dly has a volume of 0 at 1996-11-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLF97.dly has a volume of 0 at 1996-12-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLZ96.dly. Date: 1996-10-18, Price: 2534. Date: 1996-11-15, Price: 2417 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ96.dly has a volume of 0 at 1996-10-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLZ96.dly has a volume of 0 at 1996-11-15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Price data for daily data file CLX96.dly. Date: 1996-09-18, Price: 2348. Date: 1996-10-17, Price: 2542 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX96.dly has a volume of 0 at 1996-09-18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | File CLX96.dly has a volume of 0 at 1996-10-17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Symbols used for continuous contract chart: | 2017-03-29 08:22:08 CLX96 | 2017-03-29 08:22:08 CLZ96 | 2017-03-29 08:22:08 CLF97 | 2017-03-29 08:22:08 CLG97 | 2017-03-29 08:22:08 CLH97 | 2017-03-29 08:22:08 CLJ97 | 2017-03-29 08:22:08 CLK97 | 2017-03-29 08:22:08 CLM97 | 2017-03-29 08:22:08 CLN97 | 2017-03-29 08:22:08 CLQ97 | 2017-03-29 08:22:08 CLU97 | 2017-03-29 08:22:08 CLV97 | 2017-03-29 08:22:08 CLX97 | 2017-03-29 08:22:08 CLZ97 | 2017-03-29 08:22:08 CLF98 | 2017-03-29 08:22:08 CLG98 | 2017-03-29 08:22:08 CLH98 | 2017-03-29 08:22:08 CLJ98 | 2017-03-29 08:22:08 CLK98 | 2017-03-29 08:22:08 CLM98 | 2017-03-29 08:22:08 CLN98 | 2017-03-29 08:22:08 CLQ98 | 2017-03-29 08:22:08 CLU98 | 2017-03-29 08:22:08 CLV98 | 2017-03-29 08:22:08 CLX98 | 2017-03-29 08:22:08 CLZ98 | 2017-03-29 08:22:08 CLF99 | 2017-03-29 08:22:08 CLG99 | 2017-03-29 08:22:08 CLH99 | 2017-03-29 08:22:08 CLJ99 | 2017-03-29 08:22:08 CLK99 | 2017-03-29 08:22:08 CLM99 | 2017-03-29 08:22:08 CLN99 | 2017-03-29 08:22:08 CLQ99 | 2017-03-29 08:22:08 CLU99 | 2017-03-29 08:22:08 CLV99 | 2017-03-29 08:22:08 CLX99 | 2017-03-29 08:22:08 CLZ99 | 2017-03-29 08:22:08 CLF00 | 2017-03-29 08:22:08 CLG00 | 2017-03-29 08:22:08 CLH00 | 2017-03-29 08:22:08 CLJ00 | 2017-03-29 08:22:08 CLK00 | 2017-03-29 08:22:08 CLM00 | 2017-03-29 08:22:08 CLN00 | 2017-03-29 08:22:08 CLQ00 | 2017-03-29 08:22:08 CLU00 | 2017-03-29 08:22:08 CLV00 | 2017-03-29 08:22:08 CLX00 | 2017-03-29 08:22:08 CLZ00 | 2017-03-29 08:22:08 CLF01 | 2017-03-29 08:22:08 CLG01 | 2017-03-29 08:22:08 CLH01 | 2017-03-29 08:22:08 CLJ01 | 2017-03-29 08:22:08 CLK01 | 2017-03-29 08:22:08 CLM01 | 2017-03-29 08:22:08 CLN01 | 2017-03-29 08:22:08 CLQ01 | 2017-03-29 08:22:08 CLU01 | 2017-03-29 08:22:08 CLV01 | 2017-03-29 08:22:08 CLX01 | 2017-03-29 08:22:08 CLZ01 | 2017-03-29 08:22:08 CLF02 | 2017-03-29 08:22:08 CLG02 | 2017-03-29 08:22:08 CLH02 | 2017-03-29 08:22:08 CLJ02 | 2017-03-29 08:22:08 CLK02 | 2017-03-29 08:22:08 CLM02 | 2017-03-29 08:22:08 CLN02 | 2017-03-29 08:22:08 CLQ02 | 2017-03-29 08:22:08 CLU02 | 2017-03-29 08:22:08 CLV02 | 2017-03-29 08:22:08 CLX02 | 2017-03-29 08:22:08 CLZ02 | 2017-03-29 08:22:08 CLF03 | 2017-03-29 08:22:08 CLG03 | 2017-03-29 08:22:08 CLH03 | 2017-03-29 08:22:08 CLJ03 | 2017-03-29 08:22:08 CLK03 | 2017-03-29 08:22:08 CLM03 | 2017-03-29 08:22:08 CLN03 | 2017-03-29 08:22:08 CLQ03 | 2017-03-29 08:22:08 CLU03 | 2017-03-29 08:22:08 CLV03 | 2017-03-29 08:22:08 CLX03 | 2017-03-29 08:22:08 CLZ03 | 2017-03-29 08:22:08 CLF04 | 2017-03-29 08:22:08 CLG04 | 2017-03-29 08:22:08 CLH04 | 2017-03-29 08:22:08 CLJ04 | 2017-03-29 08:22:08 CLK04 | 2017-03-29 08:22:08 CLM04 | 2017-03-29 08:22:08 CLN04 | 2017-03-29 08:22:08 CLQ04 | 2017-03-29 08:22:08 CLU04 | 2017-03-29 08:22:08 CLV04 | 2017-03-29 08:22:08 CLX04 | 2017-03-29 08:22:08 CLZ04 | 2017-03-29 08:22:08 CLF05 | 2017-03-29 08:22:08 CLG05 | 2017-03-29 08:22:08 CLH05 | 2017-03-29 08:22:08 CLJ05 | 2017-03-29 08:22:08 CLK05 | 2017-03-29 08:22:08 CLM05 | 2017-03-29 08:22:08 CLN05 | 2017-03-29 08:22:08 CLQ05 | 2017-03-29 08:22:08 CLU05 | 2017-03-29 08:22:08 CLV05 | 2017-03-29 08:22:08 CLX05 | 2017-03-29 08:22:08 CLZ05 | 2017-03-29 08:22:08 CLF06 | 2017-03-29 08:22:08 CLG06 | 2017-03-29 08:22:08 CLH06 | 2017-03-29 08:22:08 CLJ06 | 2017-03-29 08:22:08 CLK06 | 2017-03-29 08:22:08 CLM06 | 2017-03-29 08:22:08 CLN06 | 2017-03-29 08:22:08 CLQ06 | 2017-03-29 08:22:08 CLU06 | 2017-03-29 08:22:08 CLV06 | 2017-03-29 08:22:08 CLX06 | 2017-03-29 08:22:08 CLZ06 | 2017-03-29 08:22:08 CLF07 | 2017-03-29 08:22:08 CLG07 | 2017-03-29 08:22:08 CLH07 | 2017-03-29 08:22:08 CLJ07 | 2017-03-29 08:22:08 CLK07 | 2017-03-29 08:22:08 CLM07 | 2017-03-29 08:22:08 CLN07 | 2017-03-29 08:22:08 CLQ07 | 2017-03-29 08:22:08 CLU07 | 2017-03-29 08:22:08 CLV07 | 2017-03-29 08:22:08 CLX07 | 2017-03-29 08:22:08 CLZ07 | 2017-03-29 08:22:08 CLF08 | 2017-03-29 08:22:08 CLG08 | 2017-03-29 08:22:08 CLH08 | 2017-03-29 08:22:08 CLJ08 | 2017-03-29 08:22:08 CLK08 | 2017-03-29 08:22:08 CLM08 | 2017-03-29 08:22:08 CLN08 | 2017-03-29 08:22:08 CLQ08 | 2017-03-29 08:22:08 CLU08 | 2017-03-29 08:22:08 CLV08 | 2017-03-29 08:22:08 CLX08 | 2017-03-29 08:22:08 CLZ08 | 2017-03-29 08:22:08 CLF09 | 2017-03-29 08:22:08 CLG09 | 2017-03-29 08:22:08 CLH09 | 2017-03-29 08:22:08 CLJ09 | 2017-03-29 08:22:08 CLK09 | 2017-03-29 08:22:08 CLM09 | 2017-03-29 08:22:08 CLN09 | 2017-03-29 08:22:08 CLQ09 | 2017-03-29 08:22:08 CLU09 | 2017-03-29 08:22:08 CLV09 | 2017-03-29 08:22:08 CLX09 | 2017-03-29 08:22:08 CLZ09 | 2017-03-29 08:22:08 CLF10 | 2017-03-29 08:22:08 CLG10 | 2017-03-29 08:22:08 CLH10 | 2017-03-29 08:22:08 CLJ10 | 2017-03-29 08:22:08 CLK10 | 2017-03-29 08:22:08 CLM10 | 2017-03-29 08:22:08 CLN10 | 2017-03-29 08:22:08 CLQ10 | 2017-03-29 08:22:08 CLU10 | 2017-03-29 08:22:08 CLV10 | 2017-03-29 08:22:08 CLX10 | 2017-03-29 08:22:08 CLZ10 | 2017-03-29 08:22:08 CLF11 | 2017-03-29 08:22:08 CLG11 | 2017-03-29 08:22:08 CLH11 | 2017-03-29 08:22:08 CLJ11 | 2017-03-29 08:22:08 CLK11 | 2017-03-29 08:22:08 CLM11 | 2017-03-29 08:22:08 CLN11 | 2017-03-29 08:22:08 CLQ11 | 2017-03-29 08:22:08 CLU11 | 2017-03-29 08:22:08 CLV11 | 2017-03-29 08:22:08 CLX11 | 2017-03-29 08:22:08 CLZ11 | 2017-03-29 08:22:08 CLF12 | 2017-03-29 08:22:08 CLG12 | 2017-03-29 08:22:08 CLH12 | 2017-03-29 08:22:08 CLJ12 | 2017-03-29 08:22:08 CLK12 | 2017-03-29 08:22:08 CLM12 | 2017-03-29 08:22:08 CLN12 | 2017-03-29 08:22:08 CLQ12 | 2017-03-29 08:22:08 CLU12 | 2017-03-29 08:22:08 CLV12 | 2017-03-29 08:22:08 CLX12 | 2017-03-29 08:22:08 CLZ12 | 2017-03-29 08:22:08 CLF13 | 2017-03-29 08:22:08 CLG13 | 2017-03-29 08:22:08 CLH13 | 2017-03-29 08:22:08 CLJ13 | 2017-03-29 08:22:08 CLK13 | 2017-03-29 08:22:08 CLM13 | 2017-03-29 08:22:08 CLN13 | 2017-03-29 08:22:08 CLQ13 | 2017-03-29 08:22:08 CLU13 | 2017-03-29 08:22:08 CLV13 | 2017-03-29 08:22:08 CLX13 | 2017-03-29 08:22:08 CLZ13 | 2017-03-29 08:22:08 CLF14 | 2017-03-29 08:22:08 CLG14 | 2017-03-29 08:22:08 CLH14 | 2017-03-29 08:22:08 CLJ14 | 2017-03-29 08:22:08 CLK14 | 2017-03-29 08:22:08 CLM14 | 2017-03-29 08:22:08 CLN14 | 2017-03-29 08:22:08 CLQ14 | 2017-03-29 08:22:08 CLU14 | 2017-03-29 08:22:08 CLV14 | 2017-03-29 08:22:08 CLX14 | 2017-03-29 08:22:08 CLZ14 | 2017-03-29 08:22:08 CLF15 | 2017-03-29 08:22:08 CLG15 | 2017-03-29 08:22:08 CLH15 | 2017-03-29 08:22:08 CLJ15 | 2017-03-29 08:22:08 CLK15 | 2017-03-29 08:22:08 CLM15 | 2017-03-29 08:22:08 CLN15 | 2017-03-29 08:22:08 CLQ15 | 2017-03-29 08:22:08 CLU15 | 2017-03-29 08:22:08 CLV15 | 2017-03-29 08:22:08 CLX15 | 2017-03-29 08:22:08 CLZ15 | 2017-03-29 08:22:08 CLF16 | 2017-03-29 08:22:08 CLG16 | 2017-03-29 08:22:08 CLH16 | 2017-03-29 08:22:08 CLJ16 | 2017-03-29 08:22:08 CLK16 | 2017-03-29 08:22:08 CLM16 | 2017-03-29 08:22:08 CLN16 | 2017-03-29 08:22:08 CLQ16 | 2017-03-29 08:22:08 CLU16 | 2017-03-29 08:22:08 CLV16 | 2017-03-29 08:22:08 CLX16 | 2017-03-29 08:22:08 CLZ16 | 2017-03-29 08:22:08 CLF17 | 2017-03-29 08:22:08 CLG17 | 2017-03-29 08:22:08 CLH17 | 2017-03-29 08:22:08 CLJ17 | 2017-03-29 08:22:08 CL.20170500.CME_NY | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Checking for volume based rollover dates. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19961100.CME_NY to CL.19961200.CME_NY occurs at 1996-10-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19961200.CME_NY to CL.19970100.CME_NY occurs at 1996-11-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970100.CME_NY to CL.19970200.CME_NY occurs at 1996-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970200.CME_NY to CL.19970300.CME_NY occurs at 1997-01-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970300.CME_NY to CL.19970400.CME_NY occurs at 1997-02-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970400.CME_NY to CL.19970500.CME_NY occurs at 1997-03-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970500.CME_NY to CL.19970600.CME_NY occurs at 1997-04-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970600.CME_NY to CL.19970700.CME_NY occurs at 1997-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970700.CME_NY to CL.19970800.CME_NY occurs at 1997-06-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970800.CME_NY to CL.19970900.CME_NY occurs at 1997-07-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19970900.CME_NY to CL.19971000.CME_NY occurs at 1997-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19971000.CME_NY to CL.19971100.CME_NY occurs at 1997-09-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19971100.CME_NY to CL.19971200.CME_NY occurs at 1997-10-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19971200.CME_NY to CL.19980100.CME_NY occurs at 1997-11-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980100.CME_NY to CL.19980200.CME_NY occurs at 1997-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980200.CME_NY to CL.19980300.CME_NY occurs at 1998-01-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980300.CME_NY to CL.19980400.CME_NY occurs at 1998-02-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980400.CME_NY to CL.19980500.CME_NY occurs at 1998-03-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980500.CME_NY to CL.19980600.CME_NY occurs at 1998-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980600.CME_NY to CL.19980700.CME_NY occurs at 1998-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980700.CME_NY to CL.19980800.CME_NY occurs at 1998-06-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980800.CME_NY to CL.19980900.CME_NY occurs at 1998-07-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19980900.CME_NY to CL.19981000.CME_NY occurs at 1998-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19981000.CME_NY to CL.19981100.CME_NY occurs at 1998-09-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19981100.CME_NY to CL.19981200.CME_NY occurs at 1998-10-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19981200.CME_NY to CL.19990100.CME_NY occurs at 1998-11-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990100.CME_NY to CL.19990200.CME_NY occurs at 1998-12-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990200.CME_NY to CL.19990300.CME_NY occurs at 1999-01-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990300.CME_NY to CL.19990400.CME_NY occurs at 1999-02-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990400.CME_NY to CL.19990500.CME_NY occurs at 1999-03-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990500.CME_NY to CL.19990600.CME_NY occurs at 1999-04-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990600.CME_NY to CL.19990700.CME_NY occurs at 1999-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990700.CME_NY to CL.19990800.CME_NY occurs at 1999-06-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990800.CME_NY to CL.19990900.CME_NY occurs at 1999-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19990900.CME_NY to CL.19991000.CME_NY occurs at 1999-08-23 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19991000.CME_NY to CL.19991100.CME_NY occurs at 1999-09-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19991100.CME_NY to CL.19991200.CME_NY occurs at 1999-10-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.19991200.CME_NY to CL.20000100.CME_NY occurs at 1999-11-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000100.CME_NY to CL.20000200.CME_NY occurs at 1999-12-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000200.CME_NY to CL.20000300.CME_NY occurs at 2000-01-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000300.CME_NY to CL.20000400.CME_NY occurs at 2000-02-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000400.CME_NY to CL.20000500.CME_NY occurs at 2000-03-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000500.CME_NY to CL.20000600.CME_NY occurs at 2000-04-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000600.CME_NY to CL.20000700.CME_NY occurs at 2000-05-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000700.CME_NY to CL.20000800.CME_NY occurs at 2000-06-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000800.CME_NY to CL.20000900.CME_NY occurs at 2000-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20000900.CME_NY to CL.20001000.CME_NY occurs at 2000-08-22 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20001000.CME_NY to CL.20001100.CME_NY occurs at 2000-09-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20001100.CME_NY to CL.20001200.CME_NY occurs at 2000-10-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20001200.CME_NY to CL.20010100.CME_NY occurs at 2000-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010100.CME_NY to CL.20010200.CME_NY occurs at 2000-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010200.CME_NY to CL.20010300.CME_NY occurs at 2001-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010300.CME_NY to CL.20010400.CME_NY occurs at 2001-02-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010400.CME_NY to CL.20010500.CME_NY occurs at 2001-03-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010500.CME_NY to CL.20010600.CME_NY occurs at 2001-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010600.CME_NY to CL.20010700.CME_NY occurs at 2001-05-08 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010700.CME_NY to CL.20010800.CME_NY occurs at 2001-06-12 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010800.CME_NY to CL.20010900.CME_NY occurs at 2001-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20010900.CME_NY to CL.20011000.CME_NY occurs at 2001-08-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20011000.CME_NY to CL.20011100.CME_NY occurs at 2001-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20011100.CME_NY to CL.20011200.CME_NY occurs at 2001-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20011200.CME_NY to CL.20020100.CME_NY occurs at 2001-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020100.CME_NY to CL.20020200.CME_NY occurs at 2001-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020200.CME_NY to CL.20020300.CME_NY occurs at 2002-01-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020300.CME_NY to CL.20020400.CME_NY occurs at 2002-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020400.CME_NY to CL.20020500.CME_NY occurs at 2002-03-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020500.CME_NY to CL.20020600.CME_NY occurs at 2002-04-10 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020600.CME_NY to CL.20020700.CME_NY occurs at 2002-05-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020700.CME_NY to CL.20020800.CME_NY occurs at 2002-06-06 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020800.CME_NY to CL.20020900.CME_NY occurs at 2002-07-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20020900.CME_NY to CL.20021000.CME_NY occurs at 2002-08-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20021000.CME_NY to CL.20021100.CME_NY occurs at 2002-09-04 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20021100.CME_NY to CL.20021200.CME_NY occurs at 2002-10-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20021200.CME_NY to CL.20030100.CME_NY occurs at 2002-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030100.CME_NY to CL.20030200.CME_NY occurs at 2002-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030200.CME_NY to CL.20030300.CME_NY occurs at 2003-01-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030300.CME_NY to CL.20030400.CME_NY occurs at 2003-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030400.CME_NY to CL.20030500.CME_NY occurs at 2003-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030500.CME_NY to CL.20030600.CME_NY occurs at 2003-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030600.CME_NY to CL.20030700.CME_NY occurs at 2003-05-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030700.CME_NY to CL.20030800.CME_NY occurs at 2003-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030800.CME_NY to CL.20030900.CME_NY occurs at 2003-07-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20030900.CME_NY to CL.20031000.CME_NY occurs at 2003-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20031000.CME_NY to CL.20031100.CME_NY occurs at 2003-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20031100.CME_NY to CL.20031200.CME_NY occurs at 2003-10-10 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20031200.CME_NY to CL.20040100.CME_NY occurs at 2003-11-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040100.CME_NY to CL.20040200.CME_NY occurs at 2003-12-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040200.CME_NY to CL.20040300.CME_NY occurs at 2004-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040300.CME_NY to CL.20040400.CME_NY occurs at 2004-02-12 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040400.CME_NY to CL.20040500.CME_NY occurs at 2004-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040500.CME_NY to CL.20040600.CME_NY occurs at 2004-04-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040600.CME_NY to CL.20040700.CME_NY occurs at 2004-05-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040700.CME_NY to CL.20040800.CME_NY occurs at 2004-06-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040800.CME_NY to CL.20040900.CME_NY occurs at 2004-07-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20040900.CME_NY to CL.20041000.CME_NY occurs at 2004-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20041000.CME_NY to CL.20041100.CME_NY occurs at 2004-09-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20041100.CME_NY to CL.20041200.CME_NY occurs at 2004-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20041200.CME_NY to CL.20050100.CME_NY occurs at 2004-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050100.CME_NY to CL.20050200.CME_NY occurs at 2004-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050200.CME_NY to CL.20050300.CME_NY occurs at 2005-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050300.CME_NY to CL.20050400.CME_NY occurs at 2005-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050400.CME_NY to CL.20050500.CME_NY occurs at 2005-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050500.CME_NY to CL.20050600.CME_NY occurs at 2005-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050600.CME_NY to CL.20050700.CME_NY occurs at 2005-05-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050700.CME_NY to CL.20050800.CME_NY occurs at 2005-06-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050800.CME_NY to CL.20050900.CME_NY occurs at 2005-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20050900.CME_NY to CL.20051000.CME_NY occurs at 2005-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20051000.CME_NY to CL.20051100.CME_NY occurs at 2005-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20051100.CME_NY to CL.20051200.CME_NY occurs at 2005-10-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20051200.CME_NY to CL.20060100.CME_NY occurs at 2005-11-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060100.CME_NY to CL.20060200.CME_NY occurs at 2005-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060200.CME_NY to CL.20060300.CME_NY occurs at 2006-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060300.CME_NY to CL.20060400.CME_NY occurs at 2006-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060400.CME_NY to CL.20060500.CME_NY occurs at 2006-03-14 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060500.CME_NY to CL.20060600.CME_NY occurs at 2006-04-12 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060600.CME_NY to CL.20060700.CME_NY occurs at 2006-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060700.CME_NY to CL.20060800.CME_NY occurs at 2006-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060800.CME_NY to CL.20060900.CME_NY occurs at 2006-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20060900.CME_NY to CL.20061000.CME_NY occurs at 2006-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20061000.CME_NY to CL.20061100.CME_NY occurs at 2006-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20061100.CME_NY to CL.20061200.CME_NY occurs at 2006-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20061200.CME_NY to CL.20070100.CME_NY occurs at 2006-11-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070100.CME_NY to CL.20070200.CME_NY occurs at 2006-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070200.CME_NY to CL.20070300.CME_NY occurs at 2007-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070300.CME_NY to CL.20070400.CME_NY occurs at 2007-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070400.CME_NY to CL.20070500.CME_NY occurs at 2007-03-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070500.CME_NY to CL.20070600.CME_NY occurs at 2007-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070600.CME_NY to CL.20070700.CME_NY occurs at 2007-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070700.CME_NY to CL.20070800.CME_NY occurs at 2007-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070800.CME_NY to CL.20070900.CME_NY occurs at 2007-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20070900.CME_NY to CL.20071000.CME_NY occurs at 2007-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20071000.CME_NY to CL.20071100.CME_NY occurs at 2007-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20071100.CME_NY to CL.20071200.CME_NY occurs at 2007-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20071200.CME_NY to CL.20080100.CME_NY occurs at 2007-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080100.CME_NY to CL.20080200.CME_NY occurs at 2007-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080200.CME_NY to CL.20080300.CME_NY occurs at 2008-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080300.CME_NY to CL.20080400.CME_NY occurs at 2008-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080400.CME_NY to CL.20080500.CME_NY occurs at 2008-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080500.CME_NY to CL.20080600.CME_NY occurs at 2008-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080600.CME_NY to CL.20080700.CME_NY occurs at 2008-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080700.CME_NY to CL.20080800.CME_NY occurs at 2008-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080800.CME_NY to CL.20080900.CME_NY occurs at 2008-07-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20080900.CME_NY to CL.20081000.CME_NY occurs at 2008-08-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20081000.CME_NY to CL.20081100.CME_NY occurs at 2008-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20081100.CME_NY to CL.20081200.CME_NY occurs at 2008-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20081200.CME_NY to CL.20090100.CME_NY occurs at 2008-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090100.CME_NY to CL.20090200.CME_NY occurs at 2008-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090200.CME_NY to CL.20090300.CME_NY occurs at 2009-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090300.CME_NY to CL.20090400.CME_NY occurs at 2009-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090400.CME_NY to CL.20090500.CME_NY occurs at 2009-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090500.CME_NY to CL.20090600.CME_NY occurs at 2009-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090600.CME_NY to CL.20090700.CME_NY occurs at 2009-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090700.CME_NY to CL.20090800.CME_NY occurs at 2009-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090800.CME_NY to CL.20090900.CME_NY occurs at 2009-07-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20090900.CME_NY to CL.20091000.CME_NY occurs at 2009-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20091000.CME_NY to CL.20091100.CME_NY occurs at 2009-09-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20091100.CME_NY to CL.20091200.CME_NY occurs at 2009-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20091200.CME_NY to CL.20100100.CME_NY occurs at 2009-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100100.CME_NY to CL.20100200.CME_NY occurs at 2009-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100200.CME_NY to CL.20100300.CME_NY occurs at 2010-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100300.CME_NY to CL.20100400.CME_NY occurs at 2010-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100400.CME_NY to CL.20100500.CME_NY occurs at 2010-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100500.CME_NY to CL.20100600.CME_NY occurs at 2010-04-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100600.CME_NY to CL.20100700.CME_NY occurs at 2010-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100700.CME_NY to CL.20100800.CME_NY occurs at 2010-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100800.CME_NY to CL.20100900.CME_NY occurs at 2010-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20100900.CME_NY to CL.20101000.CME_NY occurs at 2010-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20101000.CME_NY to CL.20101100.CME_NY occurs at 2010-09-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20101100.CME_NY to CL.20101200.CME_NY occurs at 2010-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20101200.CME_NY to CL.20110100.CME_NY occurs at 2010-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110100.CME_NY to CL.20110200.CME_NY occurs at 2010-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110200.CME_NY to CL.20110300.CME_NY occurs at 2011-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110300.CME_NY to CL.20110400.CME_NY occurs at 2011-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110400.CME_NY to CL.20110500.CME_NY occurs at 2011-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110500.CME_NY to CL.20110600.CME_NY occurs at 2011-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110600.CME_NY to CL.20110700.CME_NY occurs at 2011-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110700.CME_NY to CL.20110800.CME_NY occurs at 2011-06-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110800.CME_NY to CL.20110900.CME_NY occurs at 2011-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20110900.CME_NY to CL.20111000.CME_NY occurs at 2011-08-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20111000.CME_NY to CL.20111100.CME_NY occurs at 2011-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20111100.CME_NY to CL.20111200.CME_NY occurs at 2011-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20111200.CME_NY to CL.20120100.CME_NY occurs at 2011-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120100.CME_NY to CL.20120200.CME_NY occurs at 2011-12-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120200.CME_NY to CL.20120300.CME_NY occurs at 2012-01-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120300.CME_NY to CL.20120400.CME_NY occurs at 2012-02-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120400.CME_NY to CL.20120500.CME_NY occurs at 2012-03-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120500.CME_NY to CL.20120600.CME_NY occurs at 2012-04-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120600.CME_NY to CL.20120700.CME_NY occurs at 2012-05-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120700.CME_NY to CL.20120800.CME_NY occurs at 2012-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120800.CME_NY to CL.20120900.CME_NY occurs at 2012-07-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20120900.CME_NY to CL.20121000.CME_NY occurs at 2012-08-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20121000.CME_NY to CL.20121100.CME_NY occurs at 2012-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20121100.CME_NY to CL.20121200.CME_NY occurs at 2012-10-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20121200.CME_NY to CL.20130100.CME_NY occurs at 2012-11-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130100.CME_NY to CL.20130200.CME_NY occurs at 2012-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130200.CME_NY to CL.20130300.CME_NY occurs at 2013-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130300.CME_NY to CL.20130400.CME_NY occurs at 2013-02-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130400.CME_NY to CL.20130500.CME_NY occurs at 2013-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130500.CME_NY to CL.20130600.CME_NY occurs at 2013-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130600.CME_NY to CL.20130700.CME_NY occurs at 2013-05-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130700.CME_NY to CL.20130800.CME_NY occurs at 2013-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130800.CME_NY to CL.20130900.CME_NY occurs at 2013-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20130900.CME_NY to CL.20131000.CME_NY occurs at 2013-08-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20131000.CME_NY to CL.20131100.CME_NY occurs at 2013-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20131100.CME_NY to CL.20131200.CME_NY occurs at 2013-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20131200.CME_NY to CL.20140100.CME_NY occurs at 2013-11-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140100.CME_NY to CL.20140200.CME_NY occurs at 2013-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140200.CME_NY to CL.20140300.CME_NY occurs at 2014-01-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140300.CME_NY to CL.20140400.CME_NY occurs at 2014-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140400.CME_NY to CL.20140500.CME_NY occurs at 2014-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140500.CME_NY to CL.20140600.CME_NY occurs at 2014-04-21 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140600.CME_NY to CL.20140700.CME_NY occurs at 2014-05-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150600.CME_NY to CL.20150700.CME_NY occurs at 2015-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150700.CME_NY to CL.20150800.CME_NY occurs at 2015-06-19 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150800.CME_NY to CL.20150900.CME_NY occurs at 2015-07-20 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20150900.CME_NY to CL.20151000.CME_NY occurs at 2015-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20151000.CME_NY to CL.20151100.CME_NY occurs at 2015-09-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20151100.CME_NY to CL.20151200.CME_NY occurs at 2015-10-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20151200.CME_NY to CL.20160100.CME_NY occurs at 2015-11-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160100.CME_NY to CL.20160200.CME_NY occurs at 2015-12-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160200.CME_NY to CL.20160300.CME_NY occurs at 2016-01-15 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160300.CME_NY to CL.20160400.CME_NY occurs at 2016-02-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160400.CME_NY to CL.20160500.CME_NY occurs at 2016-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160500.CME_NY to CL.20160600.CME_NY occurs at 2016-04-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160600.CME_NY to CL.20160700.CME_NY occurs at 2016-05-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160700.CME_NY to CL.20160800.CME_NY occurs at 2016-06-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160800.CME_NY to CL.20160900.CME_NY occurs at 2016-07-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20160900.CME_NY to CL.20161000.CME_NY occurs at 2016-08-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20161000.CME_NY to CL.20161100.CME_NY occurs at 2016-09-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20161100.CME_NY to CL.20161200.CME_NY occurs at 2016-10-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20161200.CME_NY to CL.20170100.CME_NY occurs at 2016-11-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20170100.CME_NY to CL.20170200.CME_NY occurs at 2016-12-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20170200.CME_NY to CL.20170300.CME_NY occurs at 2017-01-18 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20170300.CME_NY to CL.20170400.CME_NY occurs at 2017-02-16 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Volume based rollover from CL.20170400.CME_NY to CL.20170500.CME_NY occurs at 2017-03-17 | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Performing continuous futures contract back adjustment calculations. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19961100.CME_NY Open price on 1996-10-22 is 2590. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19961200.CME_NY Open price on 1996-10-22 is 2544. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19961100.CME_NY price difference to CL.19961200.CME_NY is -46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19961200.CME_NY Open price on 1996-11-20 is 2444. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970100.CME_NY Open price on 1996-11-20 is 2415. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19961200.CME_NY price difference to CL.19970100.CME_NY is -29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970100.CME_NY Open price on 1996-12-19 is 2615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970200.CME_NY Open price on 1996-12-19 is 2521. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970100.CME_NY price difference to CL.19970200.CME_NY is -94. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970200.CME_NY Open price on 1997-01-21 is 2505. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970300.CME_NY Open price on 1997-01-21 is 2425. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970200.CME_NY price difference to CL.19970300.CME_NY is -80. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970300.CME_NY Open price on 1997-02-20 is 2258. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970400.CME_NY Open price on 1997-02-20 is 2213. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970300.CME_NY price difference to CL.19970400.CME_NY is -45. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970400.CME_NY Open price on 1997-03-20 is 2190. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970500.CME_NY Open price on 1997-03-20 is 2170. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970400.CME_NY price difference to CL.19970500.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970500.CME_NY Open price on 1997-04-22 is 2047. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970600.CME_NY Open price on 1997-04-22 is 2009. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970500.CME_NY price difference to CL.19970600.CME_NY is -38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970600.CME_NY Open price on 1997-05-20 is 2130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970700.CME_NY Open price on 1997-05-20 is 2170. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970600.CME_NY price difference to CL.19970700.CME_NY is 40. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970700.CME_NY Open price on 1997-06-20 is 1865. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970800.CME_NY Open price on 1997-06-20 is 1894. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970700.CME_NY price difference to CL.19970800.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970800.CME_NY Open price on 1997-07-22 is 1920. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970900.CME_NY Open price on 1997-07-22 is 1944. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970800.CME_NY price difference to CL.19970900.CME_NY is 24. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970900.CME_NY Open price on 1997-08-20 is 2018. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971000.CME_NY Open price on 1997-08-20 is 2040. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19970900.CME_NY price difference to CL.19971000.CME_NY is 22. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971000.CME_NY Open price on 1997-09-22 is 1938. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971100.CME_NY Open price on 1997-09-22 is 1958. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971000.CME_NY price difference to CL.19971100.CME_NY is 20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971100.CME_NY Open price on 1997-10-21 is 2073. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971200.CME_NY Open price on 1997-10-21 is 2088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971100.CME_NY price difference to CL.19971200.CME_NY is 15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971200.CME_NY Open price on 1997-11-20 is 1984. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980100.CME_NY Open price on 1997-11-20 is 2016. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19971200.CME_NY price difference to CL.19980100.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980100.CME_NY Open price on 1997-12-19 is 1862. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980200.CME_NY Open price on 1997-12-19 is 1883. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980100.CME_NY price difference to CL.19980200.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980200.CME_NY Open price on 1998-01-20 is 1682. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980300.CME_NY Open price on 1998-01-20 is 1702. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980200.CME_NY price difference to CL.19980300.CME_NY is 20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980300.CME_NY Open price on 1998-02-20 is 1615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980400.CME_NY Open price on 1998-02-20 is 1635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980300.CME_NY price difference to CL.19980400.CME_NY is 20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980400.CME_NY Open price on 1998-03-20 is 1433. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980500.CME_NY Open price on 1998-03-20 is 1451. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980400.CME_NY price difference to CL.19980500.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980500.CME_NY Open price on 1998-04-21 is 1543. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980600.CME_NY Open price on 1998-04-21 is 1591. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980500.CME_NY price difference to CL.19980600.CME_NY is 48. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980600.CME_NY Open price on 1998-05-19 is 1380. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980700.CME_NY Open price on 1998-05-19 is 1512. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980600.CME_NY price difference to CL.19980700.CME_NY is 132. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980700.CME_NY Open price on 1998-06-22 is 1202. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980800.CME_NY Open price on 1998-06-22 is 1328. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980700.CME_NY price difference to CL.19980800.CME_NY is 126. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980800.CME_NY Open price on 1998-07-21 is 1344. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980900.CME_NY Open price on 1998-07-21 is 1374. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980800.CME_NY price difference to CL.19980900.CME_NY is 30. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980900.CME_NY Open price on 1998-08-20 is 1316. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981000.CME_NY Open price on 1998-08-20 is 1330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19980900.CME_NY price difference to CL.19981000.CME_NY is 14. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981000.CME_NY Open price on 1998-09-22 is 1545. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981100.CME_NY Open price on 1998-09-22 is 1550. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981000.CME_NY price difference to CL.19981100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981100.CME_NY Open price on 1998-10-20 is 1330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981200.CME_NY Open price on 1998-10-20 is 1351. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981100.CME_NY price difference to CL.19981200.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981200.CME_NY Open price on 1998-11-20 is 1210. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990100.CME_NY Open price on 1998-11-20 is 1275. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19981200.CME_NY price difference to CL.19990100.CME_NY is 65. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990100.CME_NY Open price on 1998-12-21 is 1090. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990200.CME_NY Open price on 1998-12-21 is 1107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990100.CME_NY price difference to CL.19990200.CME_NY is 17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990200.CME_NY Open price on 1999-01-20 is 1192. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990300.CME_NY Open price on 1999-01-20 is 1207. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990200.CME_NY price difference to CL.19990300.CME_NY is 15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990300.CME_NY Open price on 1999-02-22 is 1170. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990400.CME_NY Open price on 1999-02-22 is 1186. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990300.CME_NY price difference to CL.19990400.CME_NY is 16. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990400.CME_NY Open price on 1999-03-22 is 1523. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990500.CME_NY Open price on 1999-03-22 is 1530. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990400.CME_NY price difference to CL.19990500.CME_NY is 7. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990500.CME_NY Open price on 1999-04-20 is 1780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990600.CME_NY Open price on 1999-04-20 is 1758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990500.CME_NY price difference to CL.19990600.CME_NY is -22. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990600.CME_NY Open price on 1999-05-20 is 1680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990700.CME_NY Open price on 1999-05-20 is 1685. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990600.CME_NY price difference to CL.19990700.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990700.CME_NY Open price on 1999-06-22 is 1773. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990800.CME_NY Open price on 1999-06-22 is 1790. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990700.CME_NY price difference to CL.19990800.CME_NY is 17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990800.CME_NY Open price on 1999-07-20 is 2040. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990900.CME_NY Open price on 1999-07-20 is 2061. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990800.CME_NY price difference to CL.19990900.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990900.CME_NY Open price on 1999-08-23 is 2174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991000.CME_NY Open price on 1999-08-23 is 2188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19990900.CME_NY price difference to CL.19991000.CME_NY is 14. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991000.CME_NY Open price on 1999-09-21 is 2450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991100.CME_NY Open price on 1999-09-21 is 2382. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991000.CME_NY price difference to CL.19991100.CME_NY is -68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991100.CME_NY Open price on 1999-10-20 is 2230. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991200.CME_NY Open price on 1999-10-20 is 2248. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991100.CME_NY price difference to CL.19991200.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991200.CME_NY Open price on 1999-11-22 is 2580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000100.CME_NY Open price on 1999-11-22 is 2614. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.19991200.CME_NY price difference to CL.20000100.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000100.CME_NY Open price on 1999-12-21 is 2654. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000200.CME_NY Open price on 1999-12-21 is 2632. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000100.CME_NY price difference to CL.20000200.CME_NY is -22. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000200.CME_NY Open price on 2000-01-20 is 2940. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000300.CME_NY Open price on 2000-01-20 is 2779. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000200.CME_NY price difference to CL.20000300.CME_NY is -161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000300.CME_NY Open price on 2000-02-22 is 2920. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000400.CME_NY Open price on 2000-02-22 is 2830. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000300.CME_NY price difference to CL.20000400.CME_NY is -90. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000400.CME_NY Open price on 2000-03-21 is 2960. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000500.CME_NY Open price on 2000-03-21 is 2763. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000400.CME_NY price difference to CL.20000500.CME_NY is -197. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000500.CME_NY Open price on 2000-04-19 is 2630. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000600.CME_NY Open price on 2000-04-19 is 2500. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000500.CME_NY price difference to CL.20000600.CME_NY is -130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000600.CME_NY Open price on 2000-05-22 is 2976. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000700.CME_NY Open price on 2000-05-22 is 2975. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000600.CME_NY price difference to CL.20000700.CME_NY is -1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000700.CME_NY Open price on 2000-06-20 is 3161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000800.CME_NY Open price on 2000-06-20 is 2953. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000700.CME_NY price difference to CL.20000800.CME_NY is -208. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000800.CME_NY Open price on 2000-07-20 is 3130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000900.CME_NY Open price on 2000-07-20 is 3028. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000800.CME_NY price difference to CL.20000900.CME_NY is -102. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000900.CME_NY Open price on 2000-08-22 is 3242. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001000.CME_NY Open price on 2000-08-22 is 3195. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20000900.CME_NY price difference to CL.20001000.CME_NY is -47. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001000.CME_NY Open price on 2000-09-20 is 3645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001100.CME_NY Open price on 2000-09-20 is 3490. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001000.CME_NY price difference to CL.20001100.CME_NY is -155. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001100.CME_NY Open price on 2000-10-20 is 3290. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001200.CME_NY Open price on 2000-10-20 is 3200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001100.CME_NY price difference to CL.20001200.CME_NY is -90. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001200.CME_NY Open price on 2000-11-17 is 3508. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010100.CME_NY Open price on 2000-11-17 is 3440. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20001200.CME_NY price difference to CL.20010100.CME_NY is -68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010100.CME_NY Open price on 2000-12-19 is 2930. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010200.CME_NY Open price on 2000-12-19 is 2840. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010100.CME_NY price difference to CL.20010200.CME_NY is -90. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010200.CME_NY Open price on 2001-01-18 is 2959. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010300.CME_NY Open price on 2001-01-18 is 2779. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010200.CME_NY price difference to CL.20010300.CME_NY is -180. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010300.CME_NY Open price on 2001-02-15 is 2968. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010400.CME_NY Open price on 2001-02-15 is 2950. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010300.CME_NY price difference to CL.20010400.CME_NY is -18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010400.CME_NY Open price on 2001-03-15 is 2652. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010500.CME_NY Open price on 2001-03-15 is 2670. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010400.CME_NY price difference to CL.20010500.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010500.CME_NY Open price on 2001-04-17 is 2900. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010600.CME_NY Open price on 2001-04-17 is 2926. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010500.CME_NY price difference to CL.20010600.CME_NY is 26. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010600.CME_NY Open price on 2001-05-08 is 2778. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010700.CME_NY Open price on 2001-05-08 is 2856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010600.CME_NY price difference to CL.20010700.CME_NY is 78. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010700.CME_NY Open price on 2001-06-12 is 2894. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010800.CME_NY Open price on 2001-06-12 is 2917. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010700.CME_NY price difference to CL.20010800.CME_NY is 23. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010800.CME_NY Open price on 2001-07-18 is 2556. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010900.CME_NY Open price on 2001-07-18 is 2555. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010800.CME_NY price difference to CL.20010900.CME_NY is -1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010900.CME_NY Open price on 2001-08-17 is 2740. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011000.CME_NY Open price on 2001-08-17 is 2650. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20010900.CME_NY price difference to CL.20011000.CME_NY is -90. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011000.CME_NY Open price on 2001-09-18 is 2880. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011100.CME_NY Open price on 2001-09-18 is 2912. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011000.CME_NY price difference to CL.20011100.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011100.CME_NY Open price on 2001-10-17 is 2204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011200.CME_NY Open price on 2001-10-17 is 2225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011100.CME_NY price difference to CL.20011200.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011200.CME_NY Open price on 2001-11-15 is 1980. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020100.CME_NY Open price on 2001-11-15 is 2005. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20011200.CME_NY price difference to CL.20020100.CME_NY is 25. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020100.CME_NY Open price on 2001-12-18 is 1915. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020200.CME_NY Open price on 2001-12-18 is 1946. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020100.CME_NY price difference to CL.20020200.CME_NY is 31. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020200.CME_NY Open price on 2002-01-17 is 1890. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020300.CME_NY Open price on 2002-01-17 is 1950. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020200.CME_NY price difference to CL.20020300.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020300.CME_NY Open price on 2002-02-19 is 2122. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020400.CME_NY Open price on 2002-02-19 is 2140. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020300.CME_NY price difference to CL.20020400.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020400.CME_NY Open price on 2002-03-14 is 2410. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020500.CME_NY Open price on 2002-03-14 is 2452. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020400.CME_NY price difference to CL.20020500.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020500.CME_NY Open price on 2002-04-10 is 2581. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020600.CME_NY Open price on 2002-04-10 is 2594. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020500.CME_NY price difference to CL.20020600.CME_NY is 13. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020600.CME_NY Open price on 2002-05-16 is 2826. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020700.CME_NY Open price on 2002-05-16 is 2740. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020600.CME_NY price difference to CL.20020700.CME_NY is -86. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020700.CME_NY Open price on 2002-06-06 is 2492. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020800.CME_NY Open price on 2002-06-06 is 2512. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020700.CME_NY price difference to CL.20020800.CME_NY is 20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020800.CME_NY Open price on 2002-07-17 is 2772. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020900.CME_NY Open price on 2002-07-17 is 2775. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020800.CME_NY price difference to CL.20020900.CME_NY is 3. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020900.CME_NY Open price on 2002-08-14 is 2793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021000.CME_NY Open price on 2002-08-14 is 2719. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20020900.CME_NY price difference to CL.20021000.CME_NY is -74. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021000.CME_NY Open price on 2002-09-04 is 2779. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021100.CME_NY Open price on 2002-09-04 is 2780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021000.CME_NY price difference to CL.20021100.CME_NY is 1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021100.CME_NY Open price on 2002-10-14 is 2945. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021200.CME_NY Open price on 2002-10-14 is 2944. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021100.CME_NY price difference to CL.20021200.CME_NY is -1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021200.CME_NY Open price on 2002-11-15 is 2535. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030100.CME_NY Open price on 2002-11-15 is 2452. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20021200.CME_NY price difference to CL.20030100.CME_NY is -83. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030100.CME_NY Open price on 2002-12-16 is 2862. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030200.CME_NY Open price on 2002-12-16 is 2856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030100.CME_NY price difference to CL.20030200.CME_NY is -6. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030200.CME_NY Open price on 2003-01-16 is 3315. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030300.CME_NY Open price on 2003-01-16 is 3245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030200.CME_NY price difference to CL.20030300.CME_NY is -70. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030300.CME_NY Open price on 2003-02-18 is 3638. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030400.CME_NY Open price on 2003-02-18 is 3499. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030300.CME_NY price difference to CL.20030400.CME_NY is -139. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030400.CME_NY Open price on 2003-03-17 is 3598. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030500.CME_NY Open price on 2003-03-17 is 3352. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030400.CME_NY price difference to CL.20030500.CME_NY is -246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030500.CME_NY Open price on 2003-04-17 is 2910. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030600.CME_NY Open price on 2003-04-17 is 2753. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030500.CME_NY price difference to CL.20030600.CME_NY is -157. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030600.CME_NY Open price on 2003-05-16 is 2860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030700.CME_NY Open price on 2003-05-16 is 2830. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030600.CME_NY price difference to CL.20030700.CME_NY is -30. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030700.CME_NY Open price on 2003-06-18 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030800.CME_NY Open price on 2003-06-18 is 2949. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030700.CME_NY price difference to CL.20030800.CME_NY is -156. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030800.CME_NY Open price on 2003-07-15 is 3134. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030900.CME_NY Open price on 2003-07-15 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030800.CME_NY price difference to CL.20030900.CME_NY is -29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030900.CME_NY Open price on 2003-08-18 is 3131. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031000.CME_NY Open price on 2003-08-18 is 3130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20030900.CME_NY price difference to CL.20031000.CME_NY is -1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031000.CME_NY Open price on 2003-09-16 is 2814. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031100.CME_NY Open price on 2003-09-16 is 2817. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031000.CME_NY price difference to CL.20031100.CME_NY is 3. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031100.CME_NY Open price on 2003-10-10 is 3105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031200.CME_NY Open price on 2003-10-10 is 3108. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031100.CME_NY price difference to CL.20031200.CME_NY is 3. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031200.CME_NY Open price on 2003-11-14 is 3190. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040100.CME_NY Open price on 2003-11-14 is 3149. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20031200.CME_NY price difference to CL.20040100.CME_NY is -41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040100.CME_NY Open price on 2003-12-15 is 3204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040200.CME_NY Open price on 2003-12-15 is 3215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040100.CME_NY price difference to CL.20040200.CME_NY is 11. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040200.CME_NY Open price on 2004-01-15 is 3457. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040300.CME_NY Open price on 2004-01-15 is 3385. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040200.CME_NY price difference to CL.20040300.CME_NY is -72. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040300.CME_NY Open price on 2004-02-12 is 3400. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040400.CME_NY Open price on 2004-02-12 is 3315. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040300.CME_NY price difference to CL.20040400.CME_NY is -85. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040400.CME_NY Open price on 2004-03-17 is 3744. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040500.CME_NY Open price on 2004-03-17 is 3663. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040400.CME_NY price difference to CL.20040500.CME_NY is -81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040500.CME_NY Open price on 2004-04-15 is 3670. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040600.CME_NY Open price on 2004-04-15 is 3642. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040500.CME_NY price difference to CL.20040600.CME_NY is -28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040600.CME_NY Open price on 2004-05-14 is 4108. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040700.CME_NY Open price on 2004-05-14 is 4070. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040600.CME_NY price difference to CL.20040700.CME_NY is -38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040700.CME_NY Open price on 2004-06-15 is 3759. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040800.CME_NY Open price on 2004-06-15 is 3788. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040700.CME_NY price difference to CL.20040800.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040800.CME_NY Open price on 2004-07-15 is 4097. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040900.CME_NY Open price on 2004-07-15 is 4115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040800.CME_NY price difference to CL.20040900.CME_NY is 18. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040900.CME_NY Open price on 2004-08-18 is 4675. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041000.CME_NY Open price on 2004-08-18 is 4619. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20040900.CME_NY price difference to CL.20041000.CME_NY is -56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041000.CME_NY Open price on 2004-09-17 is 4401. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041100.CME_NY Open price on 2004-09-17 is 4392. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041000.CME_NY price difference to CL.20041100.CME_NY is -9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041100.CME_NY Open price on 2004-10-18 is 5480. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041200.CME_NY Open price on 2004-10-18 is 5397. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041100.CME_NY price difference to CL.20041200.CME_NY is -83. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041200.CME_NY Open price on 2004-11-17 is 4616. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050100.CME_NY Open price on 2004-11-17 is 4620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20041200.CME_NY price difference to CL.20050100.CME_NY is 4. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050100.CME_NY Open price on 2004-12-16 is 4430. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050200.CME_NY Open price on 2004-12-16 is 4470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050100.CME_NY price difference to CL.20050200.CME_NY is 40. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050200.CME_NY Open price on 2005-01-18 is 4860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050300.CME_NY Open price on 2005-01-18 is 4860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050200.CME_NY price difference to CL.20050300.CME_NY is 0. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050300.CME_NY Open price on 2005-02-16 is 4728. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050400.CME_NY Open price on 2005-02-16 is 4780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050300.CME_NY price difference to CL.20050400.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050400.CME_NY Open price on 2005-03-17 is 5645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050500.CME_NY Open price on 2005-03-17 is 5705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050400.CME_NY price difference to CL.20050500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050500.CME_NY Open price on 2005-04-18 is 5043. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050600.CME_NY Open price on 2005-04-18 is 5200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050500.CME_NY price difference to CL.20050600.CME_NY is 157. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050600.CME_NY Open price on 2005-05-17 is 4864. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050700.CME_NY Open price on 2005-05-17 is 5025. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050600.CME_NY price difference to CL.20050700.CME_NY is 161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050700.CME_NY Open price on 2005-06-16 is 5551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050800.CME_NY Open price on 2005-06-16 is 5635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050700.CME_NY price difference to CL.20050800.CME_NY is 84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050800.CME_NY Open price on 2005-07-18 is 5800. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050900.CME_NY Open price on 2005-07-18 is 5904. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050800.CME_NY price difference to CL.20050900.CME_NY is 104. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050900.CME_NY Open price on 2005-08-18 is 6333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051000.CME_NY Open price on 2005-08-18 is 6440. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20050900.CME_NY price difference to CL.20051000.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051000.CME_NY Open price on 2005-09-16 is 6470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051100.CME_NY Open price on 2005-09-16 is 6512. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051000.CME_NY price difference to CL.20051100.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051100.CME_NY Open price on 2005-10-14 is 6305. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051200.CME_NY Open price on 2005-10-14 is 6265. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051100.CME_NY price difference to CL.20051200.CME_NY is -40. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051200.CME_NY Open price on 2005-11-16 is 5698. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060100.CME_NY Open price on 2005-11-16 is 5771. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20051200.CME_NY price difference to CL.20060100.CME_NY is 73. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060100.CME_NY Open price on 2005-12-16 is 5990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060200.CME_NY Open price on 2005-12-16 is 6105. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060100.CME_NY price difference to CL.20060200.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060200.CME_NY Open price on 2006-01-18 is 6635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060300.CME_NY Open price on 2006-01-18 is 6700. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060200.CME_NY price difference to CL.20060300.CME_NY is 65. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060300.CME_NY Open price on 2006-02-16 is 5770. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060400.CME_NY Open price on 2006-02-16 is 5960. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060300.CME_NY price difference to CL.20060400.CME_NY is 190. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060400.CME_NY Open price on 2006-03-14 is 6175. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060500.CME_NY Open price on 2006-03-14 is 6370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060400.CME_NY price difference to CL.20060500.CME_NY is 195. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060500.CME_NY Open price on 2006-04-12 is 6895. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060600.CME_NY Open price on 2006-04-12 is 7037. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060500.CME_NY price difference to CL.20060600.CME_NY is 142. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060600.CME_NY Open price on 2006-05-18 is 6865. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060700.CME_NY Open price on 2006-05-18 is 6965. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060600.CME_NY price difference to CL.20060700.CME_NY is 100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060700.CME_NY Open price on 2006-06-19 is 6987. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060800.CME_NY Open price on 2006-06-19 is 7022. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060700.CME_NY price difference to CL.20060800.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060800.CME_NY Open price on 2006-07-18 is 7520. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060900.CME_NY Open price on 2006-07-18 is 7681. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060800.CME_NY price difference to CL.20060900.CME_NY is 161. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060900.CME_NY Open price on 2006-08-18 is 7048. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061000.CME_NY Open price on 2006-08-18 is 7196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20060900.CME_NY price difference to CL.20061000.CME_NY is 148. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061000.CME_NY Open price on 2006-09-19 is 6385. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061100.CME_NY Open price on 2006-09-19 is 6450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061000.CME_NY price difference to CL.20061100.CME_NY is 65. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061100.CME_NY Open price on 2006-10-18 is 5910. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061200.CME_NY Open price on 2006-10-18 is 6096. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061100.CME_NY price difference to CL.20061200.CME_NY is 186. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061200.CME_NY Open price on 2006-11-16 is 5877. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070100.CME_NY Open price on 2006-11-16 is 6072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20061200.CME_NY price difference to CL.20070100.CME_NY is 195. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070100.CME_NY Open price on 2006-12-18 is 6320. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070200.CME_NY Open price on 2006-12-18 is 6362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070100.CME_NY price difference to CL.20070200.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070200.CME_NY Open price on 2007-01-18 is 5240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070300.CME_NY Open price on 2007-01-18 is 5315. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070200.CME_NY price difference to CL.20070300.CME_NY is 75. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070300.CME_NY Open price on 2007-02-16 is 5804. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070400.CME_NY Open price on 2007-02-16 is 5857. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070300.CME_NY price difference to CL.20070400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070400.CME_NY Open price on 2007-03-16 is 5753. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070500.CME_NY Open price on 2007-03-16 is 5996. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070400.CME_NY price difference to CL.20070500.CME_NY is 243. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070500.CME_NY Open price on 2007-04-18 is 6325. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070600.CME_NY Open price on 2007-04-18 is 6464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070500.CME_NY price difference to CL.20070600.CME_NY is 139. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070600.CME_NY Open price on 2007-05-21 is 6495. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070700.CME_NY Open price on 2007-05-21 is 6594. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070600.CME_NY price difference to CL.20070700.CME_NY is 99. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070700.CME_NY Open price on 2007-06-18 is 6813. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070800.CME_NY Open price on 2007-06-18 is 6871. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070700.CME_NY price difference to CL.20070800.CME_NY is 58. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070800.CME_NY Open price on 2007-07-18 is 7421. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070900.CME_NY Open price on 2007-07-18 is 7428. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070800.CME_NY price difference to CL.20070900.CME_NY is 7. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070900.CME_NY Open price on 2007-08-20 is 7177. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071000.CME_NY Open price on 2007-08-20 is 7151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20070900.CME_NY price difference to CL.20071000.CME_NY is -26. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071000.CME_NY Open price on 2007-09-19 is 8217. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071100.CME_NY Open price on 2007-09-19 is 8098. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071000.CME_NY price difference to CL.20071100.CME_NY is -119. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071100.CME_NY Open price on 2007-10-18 is 8710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071200.CME_NY Open price on 2007-10-18 is 8590. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071100.CME_NY price difference to CL.20071200.CME_NY is -120. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071200.CME_NY Open price on 2007-11-15 is 9395. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080100.CME_NY Open price on 2007-11-15 is 9270. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20071200.CME_NY price difference to CL.20080100.CME_NY is -125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080100.CME_NY Open price on 2007-12-17 is 9143. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080200.CME_NY Open price on 2007-12-17 is 9155. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080100.CME_NY price difference to CL.20080200.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080200.CME_NY Open price on 2008-01-18 is 8990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080300.CME_NY Open price on 2008-01-18 is 8938. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080200.CME_NY price difference to CL.20080300.CME_NY is -52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080300.CME_NY Open price on 2008-02-19 is 9537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080400.CME_NY Open price on 2008-02-19 is 9546. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080300.CME_NY price difference to CL.20080400.CME_NY is 9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080400.CME_NY Open price on 2008-03-18 is 10615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080500.CME_NY Open price on 2008-03-18 is 10464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080400.CME_NY price difference to CL.20080500.CME_NY is -151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080500.CME_NY Open price on 2008-04-21 is 11693. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080600.CME_NY Open price on 2008-04-21 is 11654. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080500.CME_NY price difference to CL.20080600.CME_NY is -39. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080600.CME_NY Open price on 2008-05-19 is 12635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080700.CME_NY Open price on 2008-05-19 is 12615. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080600.CME_NY price difference to CL.20080700.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080700.CME_NY Open price on 2008-06-19 is 13609. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080800.CME_NY Open price on 2008-06-19 is 13800. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080700.CME_NY price difference to CL.20080800.CME_NY is 191. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080800.CME_NY Open price on 2008-07-21 is 12888. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080900.CME_NY Open price on 2008-07-21 is 12950. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080800.CME_NY price difference to CL.20080900.CME_NY is 62. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080900.CME_NY Open price on 2008-08-19 is 11311. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081000.CME_NY Open price on 2008-08-19 is 11320. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20080900.CME_NY price difference to CL.20081000.CME_NY is 9. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081000.CME_NY Open price on 2008-09-19 is 9795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081100.CME_NY Open price on 2008-09-19 is 9758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081000.CME_NY price difference to CL.20081100.CME_NY is -37. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081100.CME_NY Open price on 2008-10-17 is 7230. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081200.CME_NY Open price on 2008-10-17 is 7268. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081100.CME_NY price difference to CL.20081200.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081200.CME_NY Open price on 2008-11-19 is 5470. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090100.CME_NY Open price on 2008-11-19 is 5508. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20081200.CME_NY price difference to CL.20090100.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090100.CME_NY Open price on 2008-12-17 is 4375. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090200.CME_NY Open price on 2008-12-17 is 4682. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090100.CME_NY price difference to CL.20090200.CME_NY is 307. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090200.CME_NY Open price on 2009-01-15 is 3734. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090300.CME_NY Open price on 2009-01-15 is 4445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090200.CME_NY price difference to CL.20090300.CME_NY is 711. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090300.CME_NY Open price on 2009-02-17 is 3781. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090400.CME_NY Open price on 2009-02-17 is 4208. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090300.CME_NY price difference to CL.20090400.CME_NY is 427. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090400.CME_NY Open price on 2009-03-18 is 4867. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090500.CME_NY Open price on 2009-03-18 is 4941. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090400.CME_NY price difference to CL.20090500.CME_NY is 74. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090500.CME_NY Open price on 2009-04-17 is 4993. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090600.CME_NY Open price on 2009-04-17 is 5200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090500.CME_NY price difference to CL.20090600.CME_NY is 207. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090600.CME_NY Open price on 2009-05-18 is 5647. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090700.CME_NY Open price on 2009-05-18 is 5722. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090600.CME_NY price difference to CL.20090700.CME_NY is 75. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090700.CME_NY Open price on 2009-06-19 is 7135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090800.CME_NY Open price on 2009-06-19 is 7188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090700.CME_NY price difference to CL.20090800.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090800.CME_NY Open price on 2009-07-17 is 6224. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090900.CME_NY Open price on 2009-07-17 is 6310. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090800.CME_NY price difference to CL.20090900.CME_NY is 86. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090900.CME_NY Open price on 2009-08-18 is 6680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091000.CME_NY Open price on 2009-08-18 is 6881. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20090900.CME_NY price difference to CL.20091000.CME_NY is 201. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091000.CME_NY Open price on 2009-09-21 is 7178. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091100.CME_NY Open price on 2009-09-21 is 7221. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091000.CME_NY price difference to CL.20091100.CME_NY is 43. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091100.CME_NY Open price on 2009-10-19 is 7856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091200.CME_NY Open price on 2009-10-19 is 7912. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091100.CME_NY price difference to CL.20091200.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091200.CME_NY Open price on 2009-11-19 is 7963. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100100.CME_NY Open price on 2009-11-19 is 8016. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20091200.CME_NY price difference to CL.20100100.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100100.CME_NY Open price on 2009-12-17 is 7274. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100200.CME_NY Open price on 2009-12-17 is 7451. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100100.CME_NY price difference to CL.20100200.CME_NY is 177. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100200.CME_NY Open price on 2010-01-19 is 7785. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100300.CME_NY Open price on 2010-01-19 is 7821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100200.CME_NY price difference to CL.20100300.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100300.CME_NY Open price on 2010-02-19 is 7837. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100400.CME_NY Open price on 2010-02-19 is 7883. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100300.CME_NY price difference to CL.20100400.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100400.CME_NY Open price on 2010-03-19 is 8217. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100500.CME_NY Open price on 2010-03-19 is 8246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100400.CME_NY price difference to CL.20100500.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100500.CME_NY Open price on 2010-04-16 is 8535. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100600.CME_NY Open price on 2010-04-16 is 8656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100500.CME_NY price difference to CL.20100600.CME_NY is 121. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100600.CME_NY Open price on 2010-05-18 is 7050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100700.CME_NY Open price on 2010-05-18 is 7387. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100600.CME_NY price difference to CL.20100700.CME_NY is 337. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100700.CME_NY Open price on 2010-06-18 is 7655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100800.CME_NY Open price on 2010-06-18 is 7789. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100700.CME_NY price difference to CL.20100800.CME_NY is 134. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100800.CME_NY Open price on 2010-07-19 is 7572. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100900.CME_NY Open price on 2010-07-19 is 7607. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100800.CME_NY price difference to CL.20100900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100900.CME_NY Open price on 2010-08-18 is 7545. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101000.CME_NY Open price on 2010-08-18 is 7580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20100900.CME_NY price difference to CL.20101000.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101000.CME_NY Open price on 2010-09-17 is 7447. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101100.CME_NY Open price on 2010-09-17 is 7563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101000.CME_NY price difference to CL.20101100.CME_NY is 116. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101100.CME_NY Open price on 2010-10-18 is 8138. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101200.CME_NY Open price on 2010-10-18 is 8220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101100.CME_NY price difference to CL.20101200.CME_NY is 82. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101200.CME_NY Open price on 2010-11-17 is 8244. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110100.CME_NY Open price on 2010-11-17 is 8286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20101200.CME_NY price difference to CL.20110100.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110100.CME_NY Open price on 2010-12-17 is 8787. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110200.CME_NY Open price on 2010-12-17 is 8850. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110100.CME_NY price difference to CL.20110200.CME_NY is 63. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110200.CME_NY Open price on 2011-01-18 is 9151. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110300.CME_NY Open price on 2011-01-18 is 9255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110200.CME_NY price difference to CL.20110300.CME_NY is 104. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110300.CME_NY Open price on 2011-02-17 is 8525. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110400.CME_NY Open price on 2011-02-17 is 8812. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110300.CME_NY price difference to CL.20110400.CME_NY is 287. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110400.CME_NY Open price on 2011-03-18 is 10178. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110500.CME_NY Open price on 2011-03-18 is 10280. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110400.CME_NY price difference to CL.20110500.CME_NY is 102. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110500.CME_NY Open price on 2011-04-18 is 10943. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110600.CME_NY Open price on 2011-04-18 is 11005. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110500.CME_NY price difference to CL.20110600.CME_NY is 62. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110600.CME_NY Open price on 2011-05-18 is 9757. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110700.CME_NY Open price on 2011-05-18 is 9818. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110600.CME_NY price difference to CL.20110700.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110700.CME_NY Open price on 2011-06-20 is 9280. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110800.CME_NY Open price on 2011-06-20 is 9317. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110700.CME_NY price difference to CL.20110800.CME_NY is 37. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110800.CME_NY Open price on 2011-07-19 is 9616. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110900.CME_NY Open price on 2011-07-19 is 9645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110800.CME_NY price difference to CL.20110900.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110900.CME_NY Open price on 2011-08-19 is 8130. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111000.CME_NY Open price on 2011-08-19 is 8145. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20110900.CME_NY price difference to CL.20111000.CME_NY is 15. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111000.CME_NY Open price on 2011-09-19 is 8775. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111100.CME_NY Open price on 2011-09-19 is 8780. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111000.CME_NY price difference to CL.20111100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111100.CME_NY Open price on 2011-10-18 is 8620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111200.CME_NY Open price on 2011-10-18 is 8630. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111100.CME_NY price difference to CL.20111200.CME_NY is 10. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111200.CME_NY Open price on 2011-11-17 is 10176. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120100.CME_NY Open price on 2011-11-17 is 10174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20111200.CME_NY price difference to CL.20120100.CME_NY is -2. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120100.CME_NY Open price on 2011-12-19 is 9376. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120200.CME_NY Open price on 2011-12-19 is 9377. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120100.CME_NY price difference to CL.20120200.CME_NY is 1. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120200.CME_NY Open price on 2012-01-19 is 10114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120300.CME_NY Open price on 2012-01-19 is 10135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120200.CME_NY price difference to CL.20120300.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120300.CME_NY Open price on 2012-02-17 is 10235. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120400.CME_NY Open price on 2012-02-17 is 10264. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120300.CME_NY price difference to CL.20120400.CME_NY is 29. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120400.CME_NY Open price on 2012-03-19 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120500.CME_NY Open price on 2012-03-19 is 10778. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120400.CME_NY price difference to CL.20120500.CME_NY is 60. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120500.CME_NY Open price on 2012-04-19 is 10273. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120600.CME_NY Open price on 2012-04-19 is 10321. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120500.CME_NY price difference to CL.20120600.CME_NY is 48. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120600.CME_NY Open price on 2012-05-21 is 9127. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120700.CME_NY Open price on 2012-05-21 is 9171. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120600.CME_NY price difference to CL.20120700.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120700.CME_NY Open price on 2012-06-19 is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120800.CME_NY Open price on 2012-06-19 is 8344. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120700.CME_NY price difference to CL.20120800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120800.CME_NY Open price on 2012-07-19 is 9008. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120900.CME_NY Open price on 2012-07-19 is 9035. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120800.CME_NY price difference to CL.20120900.CME_NY is 27. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120900.CME_NY Open price on 2012-08-20 is 9636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121000.CME_NY Open price on 2012-08-20 is 9664. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20120900.CME_NY price difference to CL.20121000.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121000.CME_NY Open price on 2012-09-19 is 9549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121100.CME_NY Open price on 2012-09-19 is 9583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121000.CME_NY price difference to CL.20121100.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121100.CME_NY Open price on 2012-10-19 is 9204. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121200.CME_NY Open price on 2012-10-19 is 9248. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121100.CME_NY price difference to CL.20121200.CME_NY is 44. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121200.CME_NY Open price on 2012-11-15 is 8636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130100.CME_NY Open price on 2012-11-15 is 8677. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20121200.CME_NY price difference to CL.20130100.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130100.CME_NY Open price on 2012-12-18 is 8745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130200.CME_NY Open price on 2012-12-18 is 8794. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130100.CME_NY price difference to CL.20130200.CME_NY is 49. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130200.CME_NY Open price on 2013-01-18 is 9519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130300.CME_NY Open price on 2013-01-18 is 9565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130200.CME_NY price difference to CL.20130300.CME_NY is 46. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130300.CME_NY Open price on 2013-02-19 is 9597. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130400.CME_NY Open price on 2013-02-19 is 9639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130300.CME_NY price difference to CL.20130400.CME_NY is 42. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130400.CME_NY Open price on 2013-03-18 is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130500.CME_NY Open price on 2013-03-18 is 9362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130400.CME_NY price difference to CL.20130500.CME_NY is 36. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130500.CME_NY Open price on 2013-04-18 is 8639. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130600.CME_NY Open price on 2013-04-18 is 8660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130500.CME_NY price difference to CL.20130600.CME_NY is 21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130600.CME_NY Open price on 2013-05-20 is 9593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130700.CME_NY Open price on 2013-05-20 is 9625. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130600.CME_NY price difference to CL.20130700.CME_NY is 32. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130700.CME_NY Open price on 2013-06-18 is 9793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130800.CME_NY Open price on 2013-06-18 is 9816. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130700.CME_NY price difference to CL.20130800.CME_NY is 23. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130800.CME_NY Open price on 2013-07-18 is 10656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130900.CME_NY Open price on 2013-07-18 is 10635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130800.CME_NY price difference to CL.20130900.CME_NY is -21. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130900.CME_NY Open price on 2013-08-16 is 10718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131000.CME_NY Open price on 2013-08-16 is 10701. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20130900.CME_NY price difference to CL.20131000.CME_NY is -17. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131000.CME_NY Open price on 2013-09-18 is 10553. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131100.CME_NY Open price on 2013-09-18 is 10477. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131000.CME_NY price difference to CL.20131100.CME_NY is -76. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131100.CME_NY Open price on 2013-10-18 is 10072. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131200.CME_NY Open price on 2013-10-18 is 10100. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131100.CME_NY price difference to CL.20131200.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131200.CME_NY Open price on 2013-11-19 is 9300. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140100.CME_NY Open price on 2013-11-19 is 9364. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20131200.CME_NY price difference to CL.20140100.CME_NY is 64. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140100.CME_NY Open price on 2013-12-17 is 9730. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140200.CME_NY Open price on 2013-12-17 is 9754. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140100.CME_NY price difference to CL.20140200.CME_NY is 24. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140200.CME_NY Open price on 2014-01-17 is 9417. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140300.CME_NY Open price on 2014-01-17 is 9429. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140200.CME_NY price difference to CL.20140300.CME_NY is 12. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140300.CME_NY Open price on 2014-02-18 is 10032. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140400.CME_NY Open price on 2014-02-18 is 10012. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140300.CME_NY price difference to CL.20140400.CME_NY is -20. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140400.CME_NY Open price on 2014-03-18 is 9797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140500.CME_NY Open price on 2014-03-18 is 9746. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140400.CME_NY price difference to CL.20140500.CME_NY is -51. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140500.CME_NY Open price on 2014-04-21 is 10454. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140600.CME_NY Open price on 2014-04-21 is 10370. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140500.CME_NY price difference to CL.20140600.CME_NY is -84. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140600.CME_NY Open price on 2014-05-19 is 10213. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140700.CME_NY Open price on 2014-05-19 is 10168. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140600.CME_NY price difference to CL.20140700.CME_NY is -45. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140700.CME_NY Open price on 2014-06-18 is 10660. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140800.CME_NY Open price on 2014-06-18 is 10606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -54. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140800.CME_NY Open price on 2014-07-18 is 10372. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140900.CME_NY Open price on 2014-07-18 is 10277. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -95. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140900.CME_NY Open price on 2014-08-18 is 9710. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141000.CME_NY Open price on 2014-08-18 is 9514. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141000.CME_NY Open price on 2014-09-19 is 9297. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141100.CME_NY Open price on 2014-09-19 is 9196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -101. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141100.CME_NY Open price on 2014-10-17 is 8318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141200.CME_NY Open price on 2014-10-17 is 8240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -78. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141200.CME_NY Open price on 2014-11-18 is 7549. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150100.CME_NY Open price on 2014-11-18 is 7554. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 5. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150100.CME_NY Open price on 2014-12-18 is 5583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150200.CME_NY Open price on 2014-12-18 is 5617. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 34. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150200.CME_NY Open price on 2015-01-16 is 4635. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150300.CME_NY Open price on 2015-01-16 is 4673. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150300.CME_NY Open price on 2015-02-18 is 5324. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150400.CME_NY Open price on 2015-02-18 is 5405. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150400.CME_NY Open price on 2015-03-18 is 4251. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150500.CME_NY Open price on 2015-03-18 is 4450. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150500.CME_NY Open price on 2015-04-17 is 5656. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150600.CME_NY Open price on 2015-04-17 is 5797. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 141. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150600.CME_NY Open price on 2015-05-18 is 5985. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150700.CME_NY Open price on 2015-05-18 is 6062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150600.CME_NY price difference to CL.20150700.CME_NY is 77. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150700.CME_NY Open price on 2015-06-19 is 6050. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150800.CME_NY Open price on 2015-06-19 is 6088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150700.CME_NY price difference to CL.20150800.CME_NY is 38. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150800.CME_NY Open price on 2015-07-20 is 5076. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150900.CME_NY Open price on 2015-07-20 is 5111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150800.CME_NY price difference to CL.20150900.CME_NY is 35. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150900.CME_NY Open price on 2015-08-18 is 4188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151000.CME_NY Open price on 2015-08-18 is 4240. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20150900.CME_NY price difference to CL.20151000.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151000.CME_NY Open price on 2015-09-18 is 4689. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151100.CME_NY Open price on 2015-09-18 is 4717. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151000.CME_NY price difference to CL.20151100.CME_NY is 28. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151100.CME_NY Open price on 2015-10-16 is 4687. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151200.CME_NY Open price on 2015-10-16 is 4739. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151100.CME_NY price difference to CL.20151200.CME_NY is 52. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151200.CME_NY Open price on 2015-11-18 is 4111. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160100.CME_NY Open price on 2015-11-18 is 4218. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20151200.CME_NY price difference to CL.20160100.CME_NY is 107. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160100.CME_NY Open price on 2015-12-17 is 3580. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160200.CME_NY Open price on 2015-12-17 is 3705. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160100.CME_NY price difference to CL.20160200.CME_NY is 125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160200.CME_NY Open price on 2016-01-15 is 3118. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160300.CME_NY Open price on 2016-01-15 is 3211. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160200.CME_NY price difference to CL.20160300.CME_NY is 93. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160300.CME_NY Open price on 2016-02-18 is 3135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160400.CME_NY Open price on 2016-02-18 is 3355. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160300.CME_NY price difference to CL.20160400.CME_NY is 220. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160400.CME_NY Open price on 2016-03-17 is 3859. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160500.CME_NY Open price on 2016-03-17 is 4006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160400.CME_NY price difference to CL.20160500.CME_NY is 147. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160500.CME_NY Open price on 2016-04-18 is 3875. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160600.CME_NY Open price on 2016-04-18 is 3990. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160500.CME_NY price difference to CL.20160600.CME_NY is 115. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160600.CME_NY Open price on 2016-05-18 is 4853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160700.CME_NY Open price on 2016-05-18 is 4919. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160600.CME_NY price difference to CL.20160700.CME_NY is 66. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160700.CME_NY Open price on 2016-06-17 is 4599. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160800.CME_NY Open price on 2016-06-17 is 4655. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160700.CME_NY price difference to CL.20160800.CME_NY is 56. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160800.CME_NY Open price on 2016-07-18 is 4612. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160900.CME_NY Open price on 2016-07-18 is 4683. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160800.CME_NY price difference to CL.20160900.CME_NY is 71. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160900.CME_NY Open price on 2016-08-18 is 4690. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161000.CME_NY Open price on 2016-08-18 is 4758. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20160900.CME_NY price difference to CL.20161000.CME_NY is 68. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161000.CME_NY Open price on 2016-09-16 is 4371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161100.CME_NY Open price on 2016-09-16 is 4432. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161000.CME_NY price difference to CL.20161100.CME_NY is 61. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161100.CME_NY Open price on 2016-10-18 is 5004. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161200.CME_NY Open price on 2016-10-18 is 5045. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161100.CME_NY price difference to CL.20161200.CME_NY is 41. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161200.CME_NY Open price on 2016-11-17 is 4537. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170100.CME_NY Open price on 2016-11-17 is 4587. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20161200.CME_NY price difference to CL.20170100.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170100.CME_NY Open price on 2016-12-16 is 5110. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170200.CME_NY Open price on 2016-12-16 is 5219. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170100.CME_NY price difference to CL.20170200.CME_NY is 109. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170200.CME_NY Open price on 2017-01-18 is 5252. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170300.CME_NY Open price on 2017-01-18 is 5333. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170200.CME_NY price difference to CL.20170300.CME_NY is 81. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170300.CME_NY Open price on 2017-02-16 is 5301. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170400.CME_NY Open price on 2017-02-16 is 5354. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170300.CME_NY price difference to CL.20170400.CME_NY is 53. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170400.CME_NY Open price on 2017-03-17 is 4879. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170500.CME_NY Open price on 2017-03-17 is 4929. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | CL.20170400.CME_NY price difference to CL.20170500.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19961100.CME_NY is 7008. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19961200.CME_NY is 7054. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970100.CME_NY is 7083. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970200.CME_NY is 7177. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970300.CME_NY is 7257. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970400.CME_NY is 7302. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970500.CME_NY is 7322. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970600.CME_NY is 7360. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970700.CME_NY is 7320. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970800.CME_NY is 7291. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19970900.CME_NY is 7267. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19971000.CME_NY is 7245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19971100.CME_NY is 7225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19971200.CME_NY is 7210. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980100.CME_NY is 7178. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980200.CME_NY is 7157. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980300.CME_NY is 7137. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980400.CME_NY is 7117. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980500.CME_NY is 7099. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980600.CME_NY is 7051. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980700.CME_NY is 6919. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980800.CME_NY is 6793. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19980900.CME_NY is 6763. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19981000.CME_NY is 6749. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19981100.CME_NY is 6744. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19981200.CME_NY is 6723. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990100.CME_NY is 6658. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990200.CME_NY is 6641. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990300.CME_NY is 6626. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990400.CME_NY is 6610. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990500.CME_NY is 6603. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990600.CME_NY is 6625. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990700.CME_NY is 6620. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990800.CME_NY is 6603. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19990900.CME_NY is 6582. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19991000.CME_NY is 6568. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19991100.CME_NY is 6636. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.19991200.CME_NY is 6618. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000100.CME_NY is 6584. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000200.CME_NY is 6606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000300.CME_NY is 6767. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000400.CME_NY is 6857. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000500.CME_NY is 7054. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000600.CME_NY is 7184. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000700.CME_NY is 7185. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000800.CME_NY is 7393. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20000900.CME_NY is 7495. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20001000.CME_NY is 7542. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20001100.CME_NY is 7697. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20001200.CME_NY is 7787. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010100.CME_NY is 7855. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010200.CME_NY is 7945. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010300.CME_NY is 8125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010400.CME_NY is 8143. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010500.CME_NY is 8125. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010600.CME_NY is 8099. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010700.CME_NY is 8021. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010800.CME_NY is 7998. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20010900.CME_NY is 7999. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20011000.CME_NY is 8089. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20011100.CME_NY is 8057. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20011200.CME_NY is 8036. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020100.CME_NY is 8011. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020200.CME_NY is 7980. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020300.CME_NY is 7920. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020400.CME_NY is 7902. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020500.CME_NY is 7860. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020600.CME_NY is 7847. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020700.CME_NY is 7933. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020800.CME_NY is 7913. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20020900.CME_NY is 7910. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20021000.CME_NY is 7984. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20021100.CME_NY is 7983. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20021200.CME_NY is 7984. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030100.CME_NY is 8067. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030200.CME_NY is 8073. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030300.CME_NY is 8143. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030400.CME_NY is 8282. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030500.CME_NY is 8528. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030600.CME_NY is 8685. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030700.CME_NY is 8715. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030800.CME_NY is 8871. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20030900.CME_NY is 8900. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20031000.CME_NY is 8901. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20031100.CME_NY is 8898. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20031200.CME_NY is 8895. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040100.CME_NY is 8936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040200.CME_NY is 8925. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040300.CME_NY is 8997. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040400.CME_NY is 9082. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040500.CME_NY is 9163. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040600.CME_NY is 9191. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040700.CME_NY is 9229. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040800.CME_NY is 9200. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20040900.CME_NY is 9182. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20041000.CME_NY is 9238. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20041100.CME_NY is 9247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20041200.CME_NY is 9330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050100.CME_NY is 9326. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050200.CME_NY is 9286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050300.CME_NY is 9286. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050400.CME_NY is 9234. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050500.CME_NY is 9174. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050600.CME_NY is 9017. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050700.CME_NY is 8856. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050800.CME_NY is 8772. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20050900.CME_NY is 8668. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20051000.CME_NY is 8561. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20051100.CME_NY is 8519. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20051200.CME_NY is 8559. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060100.CME_NY is 8486. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060200.CME_NY is 8371. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060300.CME_NY is 8306. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060400.CME_NY is 8116. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060500.CME_NY is 7921. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060600.CME_NY is 7779. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060700.CME_NY is 7679. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060800.CME_NY is 7644. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20060900.CME_NY is 7483. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20061000.CME_NY is 7335. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20061100.CME_NY is 7270. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20061200.CME_NY is 7084. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070100.CME_NY is 6889. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070200.CME_NY is 6847. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070300.CME_NY is 6772. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070400.CME_NY is 6719. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070500.CME_NY is 6476. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070600.CME_NY is 6337. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070700.CME_NY is 6238. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070800.CME_NY is 6180. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20070900.CME_NY is 6173. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20071000.CME_NY is 6199. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20071100.CME_NY is 6318. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20071200.CME_NY is 6438. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080100.CME_NY is 6563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080200.CME_NY is 6551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080300.CME_NY is 6603. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080400.CME_NY is 6594. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080500.CME_NY is 6745. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080600.CME_NY is 6784. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080700.CME_NY is 6804. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080800.CME_NY is 6613. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20080900.CME_NY is 6551. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20081000.CME_NY is 6542. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20081100.CME_NY is 6579. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20081200.CME_NY is 6541. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090100.CME_NY is 6503. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090200.CME_NY is 6196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090300.CME_NY is 5485. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090400.CME_NY is 5058. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090500.CME_NY is 4984. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090600.CME_NY is 4777. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090700.CME_NY is 4702. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090800.CME_NY is 4649. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20090900.CME_NY is 4563. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20091000.CME_NY is 4362. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20091100.CME_NY is 4319. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20091200.CME_NY is 4263. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100100.CME_NY is 4210. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100200.CME_NY is 4033. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100300.CME_NY is 3997. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100400.CME_NY is 3951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100500.CME_NY is 3922. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100600.CME_NY is 3801. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100700.CME_NY is 3464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100800.CME_NY is 3330. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20100900.CME_NY is 3295. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20101000.CME_NY is 3260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20101100.CME_NY is 3144. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20101200.CME_NY is 3062. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110100.CME_NY is 3020. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110200.CME_NY is 2957. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110300.CME_NY is 2853. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110400.CME_NY is 2566. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110500.CME_NY is 2464. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110600.CME_NY is 2402. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110700.CME_NY is 2341. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110800.CME_NY is 2304. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20110900.CME_NY is 2275. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20111000.CME_NY is 2260. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20111100.CME_NY is 2255. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20111200.CME_NY is 2245. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120100.CME_NY is 2247. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120200.CME_NY is 2246. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120300.CME_NY is 2225. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120400.CME_NY is 2196. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120500.CME_NY is 2136. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120600.CME_NY is 2088. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120700.CME_NY is 2044. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120800.CME_NY is 2006. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20120900.CME_NY is 1979. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20121000.CME_NY is 1951. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20121100.CME_NY is 1917. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20121200.CME_NY is 1873. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130100.CME_NY is 1832. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130200.CME_NY is 1783. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130300.CME_NY is 1737. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130400.CME_NY is 1695. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130500.CME_NY is 1659. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130600.CME_NY is 1638. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130700.CME_NY is 1606. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130800.CME_NY is 1583. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20130900.CME_NY is 1604. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20131000.CME_NY is 1621. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20131100.CME_NY is 1697. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20131200.CME_NY is 1669. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140100.CME_NY is 1605. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140200.CME_NY is 1581. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140300.CME_NY is 1569. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140400.CME_NY is 1589. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140500.CME_NY is 1640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140600.CME_NY is 1724. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140700.CME_NY is 1769. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140800.CME_NY is 1823. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20140900.CME_NY is 1918. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20141000.CME_NY is 2114. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20141100.CME_NY is 2215. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20141200.CME_NY is 2293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150100.CME_NY is 2288. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150200.CME_NY is 2254. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150300.CME_NY is 2216. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150400.CME_NY is 2135. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150500.CME_NY is 1936. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150600.CME_NY is 1795. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150700.CME_NY is 1718. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150800.CME_NY is 1680. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20150900.CME_NY is 1645. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20151000.CME_NY is 1593. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20151100.CME_NY is 1565. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20151200.CME_NY is 1513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160100.CME_NY is 1406. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160200.CME_NY is 1281. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160300.CME_NY is 1188. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160400.CME_NY is 968. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160500.CME_NY is 821. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160600.CME_NY is 706. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160700.CME_NY is 640. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160800.CME_NY is 584. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20160900.CME_NY is 513. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20161000.CME_NY is 445. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20161100.CME_NY is 384. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20161200.CME_NY is 343. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20170100.CME_NY is 293. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20170200.CME_NY is 184. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20170300.CME_NY is 103. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] Monthly #1 | Back adjust amount for symbol CL.20170400.CME_NY is 50. | 2017-03-29 08:22:08 CL.20170500.CME_NY [CBV] 10000 Volume #7 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 CL.20170500.CME_NY [CBV] 50000 Volume #10 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 CL.20170500.CME_NY [CBV] 50000 Volume #10 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:23 HTTP connection to ds01.ddfplus.com:80 (628) | Socket gracefully closed by remote side. | 2017-03-29 08:23:12 HTTP connection to ds01.ddfplus.com:80 (628) | Initiating close of socket by core. | 2017-03-29 08:23:12 HTTP connection to ds01.ddfplus.com:80 (628) | Received socket Close event | 2017-03-29 08:23:12 HTTP connection to ds01.ddfplus.com:80 (628) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-29 08:23:12 HTTP connection to ds01.ddfplus.com:80 (628) | Closed. | 2017-03-29 08:23:12 |
[2017-03-29 17:36:03] |
You need to disable Global Settings >> General Settings >> General 2 >> Detailed Continuous Futures Contract Chart Logging. That is part of the problem. Also part of the problem is related to the references between charts: CL.20170500.CME_NY [CBV] 10000 Volume #7 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 CL.20170500.CME_NY [CBV] 50000 Volume #10 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 Chart #1 has tagged chart #10 for full recalculation. Chartbook: July CL.cht | 2017-03-29 08:22:22 CL.20170500.CME_NY [CBV] 50000 Volume #10 | Performing a full recalculation because it has been tagged. Chartbook: July CL.cht | 2017-03-29 08:22:23 For information about this, refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#ReferencesOtherChartsTagging And you should reduce the amount of data in the chart if you can. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
