Date/Time: Thu, 16 May 2024 00:20:16 +0000
Trade Activity Log for FGBL
View Count: 569
[2017-03-24 16:03:52] |
nicktrader - Posts: 665 |
Please find attached the log for FGBL - SIM2 From my point of view the data for Runup/ Drawdown are totally wrong. I start a replay and ordered during the replay. Maybe this is the problem. |
Private File |
[2017-03-24 17:28:35] |
This is too vague for us to help with. You need to be much more specific and detailed. Do not provide any log file unless we ask for it. There is nothing we can do with that log file you gave us. Refer to the documentation here for those fields: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php You need to read the documentation first. That is absolutely essential. We also do not know which particular tab in the Trade Activity Log you are even referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-24 17:29:12
[2017-03-25 03:31:09] |
I am talking about the yellow highlighted figures
Private File |
[2017-03-26 00:57:43] |
We will need to get the Trade Activity Log file. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile We will need to know the time zone you have Sierra Chart set to. We will need to know the exact settings you have at the top of the Trade Activity Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-26 00:58:34
[2017-03-26 04:12:03] |
Please find attached the files/ information you are asking for
Private File Private File |
[2017-03-26 05:08:19] |
We need the TradeActivityLog.DAT file in the main Sierra Chart folder.
[2017-03-26 06:57:35] |
Please find attached... As I told before. I made a research in connection with replay. I used a M5 Chart and most of the time the speed was 30 - 60. Meanwhile I placed the orders without stopping the replay. |
Private File |
[2017-03-26 09:32:38] |
This will be fixed in the next release. The only way we can see that this problem would arise if you have exported the order fill activity, and imported it. Otherwise, we cannot see a scenario where this happens. But anyway the necessary changes to prevent the inaccurate values has been implemented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
