Date/Time: Mon, 13 May 2024 20:53:25 +0000
VbP Bars Weekly
View Count: 588
[2017-03-24 08:00:52] |
User645473 - Posts: 9 |
Hello, I'd like to see a new VbP study for every week of my chart. In attach you can find VbP and chart settings of my hourly chart. Thank you for helping me |
Private File Private File Private File Private File Private File Private File Private File Attachment Deleted. |
[2017-03-24 17:09:11] |
Set the following Volume by Price study Input settings: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_VolumeGraphPeriodType to Multiple Profiles Based on Fixed Time http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TimePeriodTypeForFixedTime to Weeks http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TimePeriodLengthForFixedTime to 1 You should probably also increase this percentage: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_MaximumVolumeBarWidthPercentage We also strongly advise not to load so much data into an Intraday chart. You have it set for 10 years. You are only going to create support problems with such a high setting. It should be more reasonable like 90 days. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
