Date/Time: Tue, 14 May 2024 02:44:14 +0000
DOM issues
View Count: 667
[2017-03-23 20:36:19] |
User535182 - Posts: 5 |
Under the DLYLP on the DOM... It is stuck on points. I have changed it in the Chart Settings to Currency, (C) and it will not change the DOM. I have added the P&L column to my DOM. I have saved it everywhere, yet when I close the DOM window and reopen, it is not there and I have to create it again. I've also created Target strategies on the DOM and saved and they do not save either. They are gone when I re-open. I've read the HELP manual on these subjects and followed instructions. It is not making a difference. Thanks for your help. |
[2017-03-23 20:43:03] |
What do you mean by DLYLP ? To save your charts and any open Trade DOMs, you need to save these as a Chartbook and reopen the Chartbook to restore them. Follow the instructions here: Chartbooks (Workspaces) Otherwise, you are going to get default settings if you just simply open a new Trade DOM. Here is the documentation for Trade Window configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-24 13:07:51] |
Daily P&L as seen in attachment. I want it to change to currency and following the instructions does not make the change |
Daily PL in points.PNG / V - Attached On 2017-03-24 13:07:06 UTC - Size: 4.28 KB - 231 views |
[2017-03-24 17:10:33] |
You can change this by changing this setting: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ProfitLossDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
