Date/Time: Mon, 20 May 2024 14:53:52 +0000
CREATE A CHART RENKO WITH NUMBER OF TRADER PER BAR
View Count: 632
[2017-03-22 22:11:52] |
User221545 - Posts: 1 |
Dear Sir/Madam, I would like to develop a strategy with Sierra charting and I would like for your advice. I use number of trader per bar as chart type and then add the Renko chart from the available studies to M1 timeframe. The problem is that still the chart behaves as a simple Renko chart without taking into account the number per bars traded as a parameter. Could you please let me know how I can combine them and test also different chart timeframes? In addition I would like to know if I can add the number bars study. Thank you in advance for your time and interest. I look forward to hearing from you. |
[2017-03-23 05:14:23] |
This does not make any logical sense: I use number of trader per bar as chart type and then add the Renko chart from the available studies to M1 timeframe.
In that you are describing an impossibility. You cannot have a chart bar based upon a certain number of trades and also be 1 minute. Also we do not recommend using the Renko studies but instead the Renko Bar Period Type: Renko Bar Charts Please do not try to do what you are thinking about above. It is just simply not supported whatsoever and we will provide no help with it because we cannot. Here is the documentation for Numbers Bars: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-23 05:15:27
