Date/Time: Mon, 20 May 2024 17:32:36 +0000
Study for Longer Term Levels
View Count: 594
[2017-03-22 19:53:02] |
BenjaminR - Posts: 168 |
I was happy to see recently the Weekly OHLC Study added, as I was just about to ask how to do it after having difficulty figuring out settings using the Daily OHLC Study to accomplish this. Intraday, I work primarily off of one chart, on which I set levels after doing a longer to shorter time-frame analysis. I keep a monthly and weekly chart open, so I can set levels from them, and the levels are copied to my main work charts; however, I'd like to minimize the number of charts that are active while I'm trading. In addition to also needing the Prior Month's OHLC, I need automatically set a developing 30 Day Value Area High/ Value Area Low, TPO Point of Control & Volume Point of Control , and also the Prior Week's Value Area High/Value Area Low, with TPOC and VPOC. Please help. Thank you, Ben |
[2017-03-22 20:08:48] |
You need to use these studies: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s158 http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=209#Volume_Value_Area_Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
