Date/Time: Thu, 16 May 2024 11:14:17 +0000
End of Day Historical Data Update
View Count: 456
[2017-03-16 16:44:50] |
KinsaleForex - Posts: 19 |
I'm using a daily chart from the London Stock Exchange. According to the link below the chart should update at the close (16:30 UTC). Is there any way to force the update? Sierra Chart Historical Data Service: End of Day Update Times Thanks |
[2017-03-16 18:01:59] |
The easiest thing to do is to use this command at that time: Edit Menu: Edit >> Download Data For All Historical Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-16 18:09:11
