Date/Time: Wed, 15 May 2024 14:42:10 +0000
Problem on : Trading Session time Setting
View Count: 816
[2017-03-16 05:13:24] |
FH87 - Posts: 43 |
XAUUSD / Gold - 1 hr chart Time zone I set GMT +8 Hongkong time If Trading Session time Setting I set 6am to 5am, I get wrong price on candles error apear near ending to opening session 5 to 7am time 6am to 5am ------wrong---------bar with gap https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=11306 7 - 6am ---------- Candles is correct, without gap https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=11307 But actual trading time Is 6 - 5am. Am I right There is a change on trading hrs on 13th march sicne timestamp are base on hourly, why i got problem How to solve this problem ? what the time session to set Date Time Of Last Edit: 2017-03-16 12:10:32
7_-_6_am.png / V - Attached On 2017-03-16 05:07:10 UTC - Size: 55.74 KB - 281 views |
[2017-03-16 05:47:04] |
We have no idea what you are referring to. What is the problem exactly?
[2017-03-16 06:19:25] |
FH87 - Posts: 43 |
the time session to set , got problem chart date : 10/3, time 5 - 7am..........notice the price.........near to ending and opening session for time session i set 6am to 5am i get wrong price with gap if 7am to 6am price , price is correct https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=11308 Date Time Of Last Edit: 2017-03-16 06:28:29
Attachment Deleted. 2017-03-16_1427.png / V - Attached On 2017-03-16 06:28:20 UTC - Size: 41.99 KB - 289 views |
[2017-03-16 14:27:02] |
FH87 - Posts: 43 |
pls update on this 6 to 5.59am is correct https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=11310 Date Time Of Last Edit: 2017-03-16 14:28:13
2017-03-16_2215.png / V - Attached On 2017-03-16 14:26:11 UTC - Size: 93.89 KB - 278 views |
[2017-03-16 17:46:58] |
The problem is we do not know what you are trying to accomplish. As you change the Session Times in the chart, you can change the starting times of the bars, and you can also filter data out of the chart. How this works is documented and should be well understood. Refer to: Chart Session Times When you use the Session Times as shown here: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=11308 This will filter out from 5:00:01 through 5:00:59 of data from the chart. So once again, we are not understanding what you are wanting to accomplish and what is your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
