Date/Time: Fri, 10 May 2024 01:12:41 +0000
footprint (number bars)
View Count: 651
[2017-02-16 11:57:21] |
User713850 - Posts: 33 |
I am trying to understand what another trader is referring to when discussing the "diagonal" footprint imbalance settings are set 100,125,150. Where in the settings and input tab would this be located?
[2017-02-16 17:39:29] |
I have figured this out as well. thanks. |
[2017-02-16 17:46:51] |
These are the Column # Compare Thresholds: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_ColumnNumberCompareThresholds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
