Date/Time: Sat, 18 May 2024 18:02:46 +0000
Trading spot FX via Sierra Chart
View Count: 2119
[2017-02-16 01:41:27] |
User113734 - Posts: 60 |
Hi Sierra Chart, I am studying the option to make a transition from trading spot FX in MT4 to trade it via Sierra Chart. I see you offer spot FX via connecting a trading account in SC platform via FXCM. However, that is not an option I am comfortable with given recent developments. I have read that I can also trade spot FX using a trading account with Gain Capital. Stage 5 appears to be an introducing broker to Gain Capital... however, when I contacted them, they said to me they offer futures.... my question is.... can I simply open an account with Forex.com (part of Gain Capital) and connect my account to SC? If that's not possible, what's my best option to trade spot FX via SC? What brokerage firm can offer me this service? Note, I am not interested in futures. Thanks! |
[2017-02-16 05:41:23] |
Really for spot Forex trading, for customers outside the United States we recommend LMAX and Interactive Brokers: LMAX Trading Service Interactive Brokers Trading Service We would not recommend using Gain Capital. We think there are going to be some technical issues you would encounter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-16 13:49:33] |
At the moment I am using FXCM data feed in SC to make my analysis, while executing with MT4. If I switch to LMAX or IB, will I be able to generate one of the critical studies as part if my trading, that is, the 'numbers bar' and VbP (Volume by Price) in each 5m candle? I suppose the quality of tick volume would be fairly the same, right? Could you confirm that?
[2017-02-16 17:25:52] |
Yes you can still do this. There will be no problem with LMAX data. And when using Interactive Brokers you can still use the FXCM symbols under the File >> Find Symbol >> Forex category and then use the Trade and Current Quote Symbol setting to trade the equivalent Interactive Brokers symbol. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeAndCurrentQuoteSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-16 17:26:27
[2017-04-05 13:43:21] |
CrunchFX - Posts: 13 |
I was interested in this too. i had a FXCM account here in United States and was transfered to Forex.com i was wondering how to connect Sierra charts to Forex.com (Gain Capital). I contacted them and they said i need to contact Sierra charts to find out if i can connect to there Servers.
[2017-04-05 17:01:46] |
You will need to use the Gain Capital futures connection which also supports Forex trading. Refer to: http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
