Date/Time: Sun, 12 May 2024 22:49:41 +0000
Custom Chart
View Count: 720
[2017-02-15 19:44:03] |
crossiman - Posts: 29 |
If I open a new chart in SC I want to get it opened with Graph Type Candlestick and a vertical grid line at each 10 bars. This should be my custom chart. How can this be done ? |
[2017-02-16 05:36:48] |
This is explained here: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-16 21:42:52] |
Yes, thanks. But the vertical grid line at each 10 bars I have to set manually ? That would be a pity... |
[2017-02-16 22:23:58] |
No. Once this is set, then when you duplicate the chart, the new chart will also have the same settings.
