Date/Time: Mon, 06 May 2024 13:48:58 +0000
TRANSPARENT_CIRCLE draw style
View Count: 1804
[2017-02-15 14:55:18] |
User132748 - Posts: 159 |
Hi, How can I use Transparent Circle draw style in other studies than LargeVol? Doesn't seem to work. Is there any other setting I should set/check to have that working? I tried to select it in MovingAverageSimple and nothing is plotted. BR |
[2017-02-15 17:57:47] |
This is not yet available. It will be next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-15 20:59:32] |
[2017-02-15 21:02:09] |
So maybe you can also add Circle as new draw style (without any fill)? That would be a logical combo. Thanks in advance...
[2017-02-15 21:02:22] |
User20450 - Posts: 330 |
is there anyway to make them circles and not points , so the price can be distinguished?
[2017-02-16 05:04:32] |
Not sure what is described in post #5. Do you want a hollow/unfilled circle? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-16 12:44:06] |
correct , with maybe a center dot on price .
[2017-02-16 13:12:17] |
zippyzip - Posts: 293 |
something like these to represent size
Private File |
[2017-02-16 17:55:54] |
We will see about this.
[2017-02-18 22:07:25] |
sampater - Posts: 243 |
Can you also add to the Transparent Circle draw style a possibility to set by ACSIL a different size of circles on respective bar? This option along with setting transparency would provide a full spectrum of configuration of circles. Thanks in advance |
[2017-02-19 00:13:33] |
You will need to use a different Subgraph for each size you want.
[2017-02-19 14:56:47] |
That would be 26 Subgraphs... I have my study that already has 40 Subgraphs, that among other things, draw large volume trades that exceed an average of the largest trades of the last several bars. It uses the MARKER_POINT, size from 5 to 17, independently for bid and ask trades. (13 sizes x 2). The larger trade the bigger the size of the marker. But if there is a very large trade on a bid price and there is a large ask trade at a price near price of that bid trade, then one covers the other. That's why I need transparent circles of different sizes on respective bar. This can be by DRAWING_MARKER or Subgraph draw style. Would it be the possibility implement that? Date Time Of Last Edit: 2017-02-19 15:11:38
[2017-02-20 19:24:24] |
We would have to develop a new Draw Style that would use a Study Subgraph extra array to control its size. We will see about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-19 08:53:14
[2017-03-14 19:33:55] |
User64410 - Posts: 14 |
Hi, im curious about transparent circle. is possible to change transparency level? Now, I can change trans circle diameter for sc.Index using: sc.SubGraph[0].Arrays[0][sc.Index] = DataArray[1]; Iam missing information about contours settings like color and width, except transparency level. It also looks like two transparent circles are still overlapped with no transparency between them. Now a have to use all available sc.Subraphs to achieve my goals. I would like to use trans circle in future but i see two problems: 1. I will lose range of colors shade because of fixed transparency. 2. problem is that huge circle with sc.index 100 will hide smaller circle at sc.index 99 and it does not make sense. Is now (am i missing some information?) or it will be possible to solve this in future ? |
trans-circle-example.png / V - Attached On 2017-03-14 19:20:42 UTC - Size: 169.95 KB - 418 views drawstyle-point-all-subgraphs.png / V - Attached On 2017-03-14 19:33:09 UTC - Size: 254.51 KB - 367 views |
[2017-03-14 20:18:02] |
I also need different transparency of circles on respective bar, something like Subgraph extra array that control its size.2. problem is that huge circle with sc.index 100 will hide smaller circle at sc.index 99 and it does not make sense.
It is also significant problem for me.
[2017-03-19 08:57:44] |
There is only one transparency level setting and how that is controlled is explained here: Chart Studies: Transparent Circle Variable Size (ACSIL: DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE) We could use another Extra Array to support the transparency level for the circles at each chart bar. It is not clear what you are looking for when you say this: Iam missing information about contours settings like color and width, except transparency level.
We assume you know how to control the color and width of the circles? The color can be controlled through: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-20 02:32:08] |
think hes looking for something like this with inside and sizing color , outside circle with dot in middle to pin point the price , and shade inside for sizing
Private File |
