Date/Time: Fri, 10 May 2024 21:37:59 +0000
dom graph overlap with label
View Count: 684
[2017-02-15 03:19:16] |
User177458 - Posts: 5 |
Hi, I just added dom graph into my chart and it overlaps with my labels as per attached. Is there a way to shift the dom graph further to the right perhaps after the right axis? Thanks. |
Private File |
[2017-02-15 05:22:01] |
You need to set the Horizontal Alignment of the labels to "Right". Refer to: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
