Date/Time: Mon, 29 Apr 2024 02:58:30 +0000
Rithmic vs CQG
View Count: 5517
[2017-02-13 12:27:11] |
User61993 - Posts: 9 |
Which datafeed has more accurate AskxBid Volume for numbers bar using, Rithmic or CQG?
[2017-02-13 17:25:19] |
Rithmic: http://www.sierrachart.com/index.php?page=doc/Rithmic.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-06 23:32:37] |
User20450 - Posts: 330 |
can you explain why ?
[2017-06-06 23:33:17] |
Adam - Posts: 141 |
Please define why. That's a huge statement to make
[2017-06-07 00:14:05] |
This is because Rithmic provides an indication of whether a trade occurred at the Bid or Ask.
[2017-12-23 19:29:35] |
User132748 - Posts: 159 |
Is this still true? Or CQG has also this info now? If I understand correctly - Rithmic has native Bid/Ask info for every trade in the feed and for CQG it is being resolved on platform level? Thanks |
[2017-12-23 23:56:39] |
No, CQG does not have this data. For accurate Bid Volume and Ask Volume use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-23 23:56:47
[2018-08-07 19:47:02] |
User542334 - Posts: 1 |
Is that still the case, that CGQ does not have this data? Does it leads to big differents when I use cumulative delta? In the description from Sierra Chart about rithmic, there's recommended to use instead cqg, because there's no bridge and less issues. So I'm confused which would be the better choice for me. |
[2018-11-08 19:54:12] |
nonojnet - Posts: 8 |
+1 Support please |
[2018-11-08 22:07:48] |
Not sure what post #9 is about, but we recommend using the Sierra Chart Exchange Data Feed for the most accurate data Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-09 01:23:08] |
User622163 - Posts: 17 |
CQG has accurate bid/ask volume data. I have no idea what Sierra Chart support is talking about.
[2018-11-09 01:39:20] |
CQG has accurate bid/ask volume data. I have no idea what Sierra Chart support is talking about. We are sure this is generally true, but when we are asked a question, we will only recommend either the Sierra Chart Exchange Data Feed or Rithmic because in each of those cases the determination of the Bid Volume and Ask Volume is 100% accurate, at least for CME data. This cannot be done perfectly with CQG.
