Date/Time: Mon, 29 Apr 2024 05:56:36 +0000
tick data and bid/ask volume through rithmic or zen fire
View Count: 1464
[2013-08-12 17:57:50] |
User51517 - Posts: 58 |
Hello, I noticed on SC website that generally neither tick data nor bid/ask volume is available through rithmic/zen fire. The only exception is when using Optimus Futures. Can you please clarify why is this? why Optimus Futures? Thank you |
[2013-08-12 18:11:14] |
With Sierra Chart you will get Bid Volume and Ask Volume from the real-time data received from Rithmic. Just not historical data. So if you are connected as much as possible to Rithmic, you will get this data. Rithmic has very limited historical tick data and it does not have bid volume or ask volume. Sierra Chart does not support that limited data. In the case of Optimus Futures, there is an arrangement to provide alternative historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-12 18:11:59
