Date/Time: Tue, 21 May 2024 10:47:11 +0000
bar delta below bar
View Count: 1019
[2017-02-02 06:19:39] |
DevTrader79 - Posts: 44 |
The "bar delta below bar" displays delta values with decimals. I don't see any use of the .00 which is taking extra spacing. Is there any settings or way I can turn off the decimals and just have the numbers. Thanks |
[2017-02-02 08:19:57] |
You need to adjust the Value Format with the Study to 1: Chart Studies: Settings and Inputs Tab >> Value Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
