Date/Time: Tue, 21 May 2024 23:18:44 +0000
murray math study
View Count: 989
[2017-02-01 22:59:22] |
User157806 - Posts: 71 |
Hello had a question is it possible to reduce the colors in the following screenshot? For example the yellow box is a bit to bold and clutters the candles up I would like to make it more transparent or for better explanation instead of it showing at 100% visibility it is possible to reduce the visibility of it so its more in the background of the candles versus overshadowing as currently shown.
Murray Math indicator.jpg / V - Attached On 2017-02-01 22:59:15 UTC - Size: 177.31 KB - 307 views |
[2017-02-02 03:35:59] |
The colors can be changed and it is possible to use Transparent Draw Styles. All of this is controlled through the Subgraphs tab for that study. Refer to: Chart Studies: Subgraphs Tab Refer to this particular transparent Draw Style: Chart Studies: Transparent Fill Top (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_TOP) and Transparent Fill Bottom (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_BOTTOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
