Date/Time: Sun, 19 May 2024 07:45:11 +0000
Logon Problem
View Count: 902
[2017-01-22 20:20:59] |
User209218 - Posts: 34 |
I am having trouble logging on to Rithmic. Package payment is good until 3/1/17. Reading Internal Order ID file. | 2017-01-22 13:07:08 Reading Trade Orders file. | 2017-01-22 13:07:08 Reading Trade Positions file. | 2017-01-22 13:07:08 Software version: 1507 | 2017-01-22 13:07:08 Uses New Spreadsheets | 2017-01-22 13:07:08 Usage end date: 2017-03-01 | 2017-01-22 13:07:08 Enabled for: Advanced Features. | 2017-01-22 13:07:08 Enabled for: Advanced Features 2. | 2017-01-22 13:07:08 Enabled for: Sierra Chart Historical Data Service. | 2017-01-22 13:07:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-01-22 13:07:08 Current selected Data/Trading service: Rithmic Trading | 2017-01-22 13:07:08 Chart Update Interval: 500 | 2017-01-22 13:07:08 Data/Trade Service Settings automatically set. | 2017-01-22 13:07:08 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-01-22 13:07:08 2017-01-22 13:07:11 Local computer time | 2017-01-22 13:07:08 2017-01-22 20:07:11 Local computer time in UTC | 2017-01-22 13:07:08 2017-01-22 13:07:11 Local computer time in SC Time Zone | 2017-01-22 13:07:08 2017-01-22 20:07:11 Server time in UTC | 2017-01-22 13:07:08 Local computer UTC time and Server UTC time difference: 0 seconds. | 2017-01-22 13:07:08 Program path: C:\SierraChart\ | 2017-01-22 13:07:08 Data Files path: C:\SierraChart\Data\ | 2017-01-22 13:07:08 OS Version Number: 6.2 | 2017-01-22 13:07:08 Locale Setting: C | 2017-01-22 13:07:08 Checking for new symbol settings for rim | 2017-01-22 13:07:08 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2017-01-22 13:07:08 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2017-01-22 13:07:08 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2017-01-22 13:07:08 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2017-01-22 13:07:12 Symbol settings are up-to-date for rim | 2017-01-22 13:07:13 Files to Open on Start up | File does not exist: C:\SierraChart\Data\CL 5_30.cht | 2017-01-22 13:07:14 Rithmic Trading | Port for executable: 49876 | 2017-01-22 13:07:16 Listening socket (896), port 49876 | Closed. | 2017-01-22 13:07:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:16 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2017-01-22 13:07:17 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2017-01-22 13:07:17 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2017-01-22 13:07:17 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2017-01-22 13:07:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49876 | 2017-01-22 13:07:18 DTC Client (4) | Connected. | 2017-01-22 13:07:18 Rithmic Trading | Connected to server. | 2017-01-22 13:07:18 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:07:18 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:07:18 Rithmic Trading | Sending logon request message. | 2017-01-22 13:07:18 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:07:18 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:07:18 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:07:18 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:07:20 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:07:20 Rithmic Trading | Received logon response. | 2017-01-22 13:07:20 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:07:20 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:07:20 Rithmic Trading | Logon error received from server | 2017-01-22 13:07:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:20 DTC Client (4) | Shutdown and closed. | 2017-01-22 13:07:20 Rithmic Trading | Disconnected. | 2017-01-22 13:07:20 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:20 Rithmic Trading | Port for executable: 49887 | 2017-01-22 13:07:22 Listening socket (844), port 49887 | Closed. | 2017-01-22 13:07:22 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:22 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49887 | 2017-01-22 13:07:24 DTC Client (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:25 DTC Client (5) | Shutdown and closed. | 2017-01-22 13:07:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:25 Rithmic Trading | Disconnected. | 2017-01-22 13:07:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:25 Rithmic Trading | Port for executable: 49889 | 2017-01-22 13:07:27 Listening socket (892), port 49889 | Closed. | 2017-01-22 13:07:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:27 CLH7-NYMEX #3 | Reloading chart. | 2017-01-22 13:07:28 HOH7-NYMEX [CV] Daily #7 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX 2584 Trades #1 | Reloading chart. | 2017-01-22 13:07:28 ESH7-CME 5 Min #12 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX 240 Min #9 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX 1 Min #11 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX 0.10 Range #2 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX Daily #4 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX 60 Min #5 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX #8 | Reloading chart. | 2017-01-22 13:07:28 CLH7-NYMEX Renko 5t #10 | Reloading chart. | 2017-01-22 13:07:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49889 | 2017-01-22 13:07:32 HD Request # 2 | Downloading Historical Daily chart data for HOH7-NYMEX. Starting date: 2017-01-19. Service: rim | 2017-01-22 13:07:32 HD Request # 2 | Requesting historical Daily data for HOH17 starting at 2017-01-18 | 2017-01-22 13:07:32 DTC Client (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:33 DTC Client (6) | Shutdown and closed. | 2017-01-22 13:07:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:33 Rithmic Trading | Disconnected. | 2017-01-22 13:07:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:33 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2017-01-22 13:07:33 HTTP connection to ds01.ddfplus.com:80 (7) | Connected. | 2017-01-22 13:07:33 HD Request # 2 | Receiving historical Daily data for HOH7-NYMEX starting at 2017-01-19 | 2017-01-22 13:07:33 HD Request # 2 | Writing historical Daily data to the file HOH7-NYMEX.dly | 2017-01-22 13:07:33 HD Request # 2 | Received 3 records from 2017-01-19 00:00:00 to 2017-01-20 00:00:00 (2.0 days) and wrote 2 records for HOH7-NYMEX | 2017-01-22 13:07:33 HD Request # 2 | Daily download COMPLETE for HOH7-NYMEX. Completion time: 2s. Unique request ID: 1 | 2017-01-22 13:07:33 Removed historical data download ID 1 | 2017-01-22 13:07:33 HD Request # 3 | Downloading Historical Daily chart data for CLH7-NYMEX. Starting date: 2017-01-19. Service: rim | 2017-01-22 13:07:33 HD Request # 3 | Requesting historical Daily data for CLH17 starting at 2017-01-18 | 2017-01-22 13:07:33 HD Request # 3 | Receiving historical Daily data for CLH7-NYMEX starting at 2017-01-19 | 2017-01-22 13:07:33 HD Request # 3 | Writing historical Daily data to the file CLH7-NYMEX.dly | 2017-01-22 13:07:33 HD Request # 3 | Received 3 records from 2017-01-19 00:00:00 to 2017-01-20 00:00:00 (2.0 days) and wrote 2 records for CLH7-NYMEX | 2017-01-22 13:07:33 HD Request # 3 | Daily download COMPLETE for CLH7-NYMEX. Completion time: 0s. Unique request ID: 2 | 2017-01-22 13:07:33 Removed historical data download ID 2 | 2017-01-22 13:07:33 CLH7-NYMEX Daily #4 | Reloading chart. | 2017-01-22 13:07:34 HOH7-NYMEX [CV] Daily #7 | Reloading chart. | 2017-01-22 13:07:34 Rithmic Trading | Port for executable: 49892 | 2017-01-22 13:07:36 Listening socket (1284), port 49892 | Closed. | 2017-01-22 13:07:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49892 | 2017-01-22 13:07:37 DTC Client (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:38 DTC Client (8) | Shutdown and closed. | 2017-01-22 13:07:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:38 Rithmic Trading | Disconnected. | 2017-01-22 13:07:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:38 Rithmic Trading | Port for executable: 49894 | 2017-01-22 13:07:40 Listening socket (1288), port 49894 | Closed. | 2017-01-22 13:07:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49894 | 2017-01-22 13:07:42 DTC Client (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:43 DTC Client (9) | Shutdown and closed. | 2017-01-22 13:07:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:43 Rithmic Trading | Disconnected. | 2017-01-22 13:07:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:43 Rithmic Trading | Port for executable: 49896 | 2017-01-22 13:07:45 Listening socket (1312), port 49896 | Closed. | 2017-01-22 13:07:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49896 | 2017-01-22 13:07:47 DTC Client (10) | Connected. | 2017-01-22 13:07:47 Rithmic Trading | Connected to server. | 2017-01-22 13:07:47 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:07:47 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:07:47 Rithmic Trading | Sending logon request message. | 2017-01-22 13:07:47 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:07:47 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:07:47 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:07:47 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:07:48 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:07:48 Rithmic Trading | Received logon response. | 2017-01-22 13:07:48 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:07:48 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:07:48 Rithmic Trading | Logon error received from server | 2017-01-22 13:07:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:48 DTC Client (10) | Shutdown and closed. | 2017-01-22 13:07:48 Rithmic Trading | Disconnected. | 2017-01-22 13:07:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:48 Rithmic Trading | Port for executable: 49907 | 2017-01-22 13:07:50 Listening socket (1288), port 49907 | Closed. | 2017-01-22 13:07:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49907 | 2017-01-22 13:07:52 DTC Client (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:53 DTC Client (11) | Shutdown and closed. | 2017-01-22 13:07:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:53 Rithmic Trading | Disconnected. | 2017-01-22 13:07:53 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:53 Rithmic Trading | Port for executable: 49909 | 2017-01-22 13:07:55 Listening socket (1312), port 49909 | Closed. | 2017-01-22 13:07:55 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:07:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49909 | 2017-01-22 13:07:57 DTC Client (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:07:58 DTC Client (12) | Shutdown and closed. | 2017-01-22 13:07:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:07:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:07:58 Rithmic Trading | Disconnected. | 2017-01-22 13:07:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:07:58 Rithmic Trading | Port for executable: 49911 | 2017-01-22 13:08:00 Listening socket (1312), port 49911 | Closed. | 2017-01-22 13:08:00 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49911 | 2017-01-22 13:08:02 DTC Client (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:03 DTC Client (13) | Shutdown and closed. | 2017-01-22 13:08:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:03 Rithmic Trading | Disconnected. | 2017-01-22 13:08:04 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:04 Rithmic Trading | Port for executable: 49913 | 2017-01-22 13:08:06 Listening socket (616), port 49913 | Closed. | 2017-01-22 13:08:06 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:06 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49913 | 2017-01-22 13:08:08 DTC Client (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:09 DTC Client (14) | Shutdown and closed. | 2017-01-22 13:08:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:09 Rithmic Trading | Disconnected. | 2017-01-22 13:08:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:09 Rithmic Trading | Port for executable: 49915 | 2017-01-22 13:08:11 Listening socket (1260), port 49915 | Closed. | 2017-01-22 13:08:11 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:11 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49915 | 2017-01-22 13:08:13 DTC Client (15) | Connected. | 2017-01-22 13:08:13 Rithmic Trading | Connected to server. | 2017-01-22 13:08:13 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:08:13 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:08:13 Rithmic Trading | Sending logon request message. | 2017-01-22 13:08:13 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:08:13 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:08:13 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:08:13 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:08:14 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:08:14 Rithmic Trading | Received logon response. | 2017-01-22 13:08:14 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:08:14 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:08:14 Rithmic Trading | Logon error received from server | 2017-01-22 13:08:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:14 DTC Client (15) | Shutdown and closed. | 2017-01-22 13:08:14 Rithmic Trading | Disconnected. | 2017-01-22 13:08:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:14 Rithmic Trading | Port for executable: 49926 | 2017-01-22 13:08:16 Listening socket (1128), port 49926 | Closed. | 2017-01-22 13:08:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49926 | 2017-01-22 13:08:18 DTC Client (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:19 DTC Client (16) | Shutdown and closed. | 2017-01-22 13:08:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:19 Rithmic Trading | Disconnected. | 2017-01-22 13:08:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:19 Rithmic Trading | Port for executable: 49928 | 2017-01-22 13:08:21 Listening socket (1032), port 49928 | Closed. | 2017-01-22 13:08:21 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49928 | 2017-01-22 13:08:23 DTC Client (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:24 DTC Client (17) | Shutdown and closed. | 2017-01-22 13:08:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:24 Rithmic Trading | Disconnected. | 2017-01-22 13:08:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:24 Rithmic Trading | Port for executable: 49930 | 2017-01-22 13:08:26 Listening socket (1344), port 49930 | Closed. | 2017-01-22 13:08:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49930 | 2017-01-22 13:08:28 DTC Client (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:29 DTC Client (18) | Shutdown and closed. | 2017-01-22 13:08:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:29 Rithmic Trading | Disconnected. | 2017-01-22 13:08:29 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:29 Rithmic Trading | Port for executable: 49963 | 2017-01-22 13:08:31 Listening socket (928), port 49963 | Closed. | 2017-01-22 13:08:31 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49963 | 2017-01-22 13:08:33 DTC Client (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:34 DTC Client (19) | Shutdown and closed. | 2017-01-22 13:08:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:34 Rithmic Trading | Disconnected. | 2017-01-22 13:08:34 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:34 Rithmic Trading | Port for executable: 49966 | 2017-01-22 13:08:36 Listening socket (928), port 49966 | Closed. | 2017-01-22 13:08:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49966 | 2017-01-22 13:08:38 DTC Client (20) | Connected. | 2017-01-22 13:08:38 Rithmic Trading | Connected to server. | 2017-01-22 13:08:38 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:08:38 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:08:38 Rithmic Trading | Sending logon request message. | 2017-01-22 13:08:38 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:08:38 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:08:38 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:08:38 HTTP connection to ds01.ddfplus.com:80 (7) | Closed. No error. | 2017-01-22 13:08:38 HTTP connection to ds01.ddfplus.com:80 (7) | Shutdown and closed. | 2017-01-22 13:08:38 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:08:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:08:39 Rithmic Trading | Received logon response. | 2017-01-22 13:08:39 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:08:39 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:08:39 Rithmic Trading | Logon error received from server | 2017-01-22 13:08:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:39 DTC Client (20) | Shutdown and closed. | 2017-01-22 13:08:39 Rithmic Trading | Disconnected. | 2017-01-22 13:08:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:39 Rithmic Trading | Port for executable: 49977 | 2017-01-22 13:08:42 Listening socket (1288), port 49977 | Closed. | 2017-01-22 13:08:42 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:42 Service is currently connecting. | 2017-01-22 13:08:43 * Rithmic Trading | Connecting to the server 127.0.0.1. Port 49977 | 2017-01-22 13:08:43 DTC Client (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:44 DTC Client (21) | Shutdown and closed. | 2017-01-22 13:08:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:44 Rithmic Trading | Disconnected. | 2017-01-22 13:08:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:44 Rithmic Trading | Port for executable: 49979 | 2017-01-22 13:08:46 Listening socket (868), port 49979 | Closed. | 2017-01-22 13:08:46 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:46 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49979 | 2017-01-22 13:08:48 DTC Client (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:08:49 DTC Client (22) | Shutdown and closed. | 2017-01-22 13:08:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:08:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:08:49 Rithmic Trading | Disconnected. | 2017-01-22 13:08:49 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:08:49 Rithmic Trading | Port for executable: 49981 | 2017-01-22 13:08:51 Listening socket (1036), port 49981 | Closed. | 2017-01-22 13:08:51 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:08:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49981 | 2017-01-22 13:08:54 File >> Disconnect selected. | 2017-01-22 13:08:54 DTC Client (23) | Shutdown and closed. | 2017-01-22 13:08:54 Rithmic Trading | Disconnected. | 2017-01-22 13:08:54 Rithmic Trading | Port for executable: 49997 | 2017-01-22 13:09:58 Listening socket (928), port 49997 | Closed. | 2017-01-22 13:09:58 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:09:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49997 | 2017-01-22 13:10:00 DTC Client (25) | Connected. | 2017-01-22 13:10:00 Rithmic Trading | Connected to server. | 2017-01-22 13:10:00 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:10:00 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:10:00 Rithmic Trading | Sending logon request message. | 2017-01-22 13:10:00 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:10:00 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:10:00 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:10:00 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:10:01 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:10:01 Rithmic Trading | Received logon response. | 2017-01-22 13:10:01 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:10:01 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:10:01 Rithmic Trading | Logon error received from server | 2017-01-22 13:10:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:10:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:10:01 DTC Client (25) | Shutdown and closed. | 2017-01-22 13:10:01 Rithmic Trading | Disconnected. | 2017-01-22 13:10:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:10:01 Rithmic Trading | Port for executable: 50008 | 2017-01-22 13:10:03 Listening socket (1020), port 50008 | Closed. | 2017-01-22 13:10:03 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:10:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50008 | 2017-01-22 13:10:05 DTC Client (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-22 13:10:06 DTC Client (26) | Shutdown and closed. | 2017-01-22 13:10:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:10:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:10:06 Rithmic Trading | Disconnected. | 2017-01-22 13:10:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:10:06 Rithmic Trading | Port for executable: 50010 | 2017-01-22 13:10:08 Listening socket (1204), port 50010 | Closed. | 2017-01-22 13:10:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:10:08 File >> Disconnect selected. | 2017-01-22 13:10:09 Rithmic Trading | Disconnected. | 2017-01-22 13:10:09 Rithmic Trading | Port for executable: 50066 | 2017-01-22 13:14:26 Listening socket (1168), port 50066 | Closed. | 2017-01-22 13:14:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-22 13:14:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50066 | 2017-01-22 13:14:28 DTC Client (29) | Connected. | 2017-01-22 13:14:28 Rithmic Trading | Connected to server. | 2017-01-22 13:14:28 Rithmic Trading | Sending Encoding Request to server | 2017-01-22 13:14:28 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-22 13:14:28 Rithmic Trading | Sending logon request message. | 2017-01-22 13:14:28 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-22 13:14:28 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-22 13:14:28 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-22 13:14:28 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-22 13:14:29 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:14:29 Rithmic Trading | Received logon response. | 2017-01-22 13:14:29 Rithmic Trading | Server Name: DTC Bridge. | 2017-01-22 13:14:29 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-22 13:14:29 Rithmic Trading | Logon error received from server | 2017-01-22 13:14:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-22 13:14:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-22 13:14:29 DTC Client (29) | Shutdown and closed. | 2017-01-22 13:14:30 Rithmic Trading | Disconnected. | 2017-01-22 13:14:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-22 13:14:30 File >> Disconnect selected. | 2017-01-22 13:14:31 Rithmic Trading | Disconnected. | 2017-01-22 13:14:31 Date Time Of Last Edit: 2017-01-22 20:21:43
[2017-01-22 20:42:50] |
This is the reason for the problem: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-22 13:14:29 Refer to the instructions here for this: http://www.sierrachart.com/index.php?page=doc/Rithmic.php#PermissionDeniedResolution Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-22 20:43:10
