Date/Time: Mon, 29 Apr 2024 08:12:56 +0000
User Email
View Count: 941
[2017-01-19 16:59:16] |
Sierra Chart - Max - Posts: 5597 |
A client imported old sierra to new machine and one of the studies he was using, MACDzero cross over system is not available on the studies on the new machine. He has it on one chart that was imported, how can he “export” the study so he can use it as available studies menu? Sierra Chart Support |
[2017-01-19 18:02:20] |
There is the MACD Crossover System which is found in Analysis >> Studies. If they do not see it they must update to the current version. If they are running an older version they will not have this. Here are the instructions to update: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-20 15:10:28] |
Thanks but the guy is referencing to the cross over instead of the zero cross over as you asked about.
Regards, Sierra Chart Support |
[2017-01-20 18:58:52] |
The MACD Crossover System study does determine the crossover between the MACDLine and the MACDMovingAverageLine. Also these questions must be posted directly on the Support Board here please. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-20 18:59:10
