Date/Time: Mon, 29 Apr 2024 14:23:27 +0000
What are these numbers and how can I configure them?
View Count: 689
[2017-01-19 15:43:13] |
User252419 - Posts: 235 |
I have some numbers in the footprints chart I don't even know how I put them there. What are them? How can I configure them? The circle in the attached picture. Thank you |
what is.PNG / V - Attached On 2017-01-19 15:43:03 UTC - Size: 8.29 KB - 221 views |
[2017-01-19 18:17:17] |
This looks like it might be the Pullback Column: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#PullbackColumn It is impossible for us to tell because you did not post an image following our requirements here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-20 10:03:06] |
http://www.sierrachart.com/image.php?Image=1484906547259.png The numbers 41 and -150. I don't know what are them. Thank u |
[2017-01-20 10:10:25] |
Did you enable the Pullback Column?: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#PullbackColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
