Date/Time: Mon, 29 Apr 2024 01:09:03 +0000
YMH7
View Count: 782
[2017-01-19 14:25:08] |
User743109 - Posts: 3 |
Hi, I use level 3 of Sierra. NQH7, ESH7 is ok, but YMH7 doesnt work online, just download historical data. I use YM for intermarket analyses. What is wrong? Thank you. |
[2017-01-19 17:51:00] |
You are running an older version of Sierra Chart. You must update to the current version. Refer to: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate If you need further help, contact your broker about not receiving real-time data for that particular symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-19 17:51:27
