Date/Time: Sat, 18 May 2024 19:29:15 +0000
Additional option for Rectangle Config
View Count: 735
[2017-01-18 14:35:41] |
nicktrader - Posts: 665 |
I work quite often with rectangles. Is it possible to give the rectangle tool an extension option (see attached file)? The reason for that is very simple. In many cases I use an extented rectangle and I set an alert. If that rectangle is triggert the color and/ or draw style is changing. But unfortunatly there is no option to set the rectangle without any extension - or in all cases of the drawing tool alert in general - to erase the drawing. Maybe it is easy for you to add that option(s). |
Rectangle Config.png / V - Attached On 2017-01-18 14:32:35 UTC - Size: 20.96 KB - 196 views |
