Date/Time: Sun, 26 May 2024 02:26:57 +0000
hello ,why your chart is wrong ,it is difference with exchange chart .what is the reason?
View Count: 549
[2017-01-18 02:59:19] |
User166767 - Posts: 32 |
please see the screenshot ,the chart is wrong ,and delayed ,why?the chart is unnormal ,it is useless.please see the document in the annex.can you tell me the reason and solve the question?
QQ截图20170117092431.png / V - Attached On 2017-01-18 02:57:37 UTC - Size: 65.01 KB - 188 views |
[2017-01-18 04:41:29] |
One difference we see is that Sierra Chart is not connected to the data feed. Connect with File >> Connect to Data Feed: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#Connect This is why there is missing data at the end of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
