Date/Time: Tue, 21 May 2024 15:28:06 +0000
Numbers too small
View Count: 800
[2017-01-16 17:07:52] |
User898612 - Posts: 4 |
Hi, I have been using the foodprint indicator for my graph but unfortunately the numbers displayed are too small to read (see attached). Any tips? Thanks in advance, GJ. |
USDX [M] 10 Min #2 2017-01-16 17_06_38.957.png / V - Attached On 2017-01-16 17:06:54 UTC - Size: 96.63 KB - 221 views |
[2017-01-16 19:53:09] |
It does not make sense to use the Numbers Bars study on that symbol. There is not going to be any logical information provided. Nevertheless, you need to follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#AdjustingTickSizeForLargerIncrement And here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-16 20:51:35] |
Thanks for your quick response. I am still rather new so thanks for your advice (much appreciated). Best, GJ |
