Date/Time: Wed, 22 May 2024 02:28:08 +0000
Renko Bar with Studies
View Count: 1540
[2017-01-15 06:36:55] |
Icychemist - Posts: 8 |
Hi there, I am using Renko Bars (without wicks) with Donchian Channel as the studies. However, I noticed that the studies seems to be plotted based on Renko with wicks. How do I make the study plot against the Renko Bar (without wicks) instead ? I tried meddling around with the settings available but could not find any solution. |
[2017-01-15 07:50:22] |
Not sure how this can be done because the bar Open and Close can be reversed in relation to each other. Anyway, this would be the study that might potentially work because you can specify the Input data for high and low: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s54 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-15 08:01:11] |
Hi, Thank you for the reply. I added the study of HighestHighLowestLow as you suggested. I realized that the study still plot based on Renko with wicks. Is there any other way that I can get around with this ? Thank you in advance ! :) |
[2017-01-15 08:03:15] |
We do not see how this can be done.
[2017-01-15 08:18:09] |
OMG thank you !! I missed out the input data you were talking about. I got what I want now. Thank you so much for your help ! Wishing you a fantastic day ahead ! |
[2017-01-15 08:23:08] |
Okay one more thing I would like to ask, does sierra chart accumulates it's tick data ? Meaning....I am now seeing 30 days of TICK data on futures. Say tomorrow will be Day 31, the next day will be Day 32 and so on... Will I be able to see the tick data in a accumulative manner ? Meaning I see Day 0 to Day 31, Day 0 to Day 32, Day 0 to Day 33, Day 0 to Day 34 ? (ThinkOrSwim only shows the last 30 days of data. I do not want the historical data to be purged out of the chart) |
[2017-01-15 09:14:37] |
OK this is good you got the result you are looking for. Yes, the tick by tick data does accumulate but you can access more historical tick data by following the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-15 09:15:23
[2017-01-16 12:30:56] |
Hi, Can I check, do I get real time futures data on a trial account ? Do I need to pay money ? |
[2017-01-16 18:33:47] |
For information about futures data, refer to: http://www.sierrachart.com/index.php?page=doc/FuturesData.php To check the historical data use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-16 18:34:21
