Date/Time: Tue, 21 May 2024 12:45:39 +0000
Volume filtering at price levels for Numbers Bars
View Count: 1066
[2017-01-13 12:12:56] |
User498044 - Posts: 2 |
Hello, I'm using the Numbers Bars charts on my SC platform. I want to filter the volume on each price level of those bars to be only visible if greater than a set number so I can see only for example volume above 100. All other volume, which is lower than the set value, on different price levels within a bar I want to set to either 0 or to be hidden. I've looked into the Volume Filtering option, but it's either not for this or I am doing something wrong. Looking forward for some assistance setting up the options. Thank you in advance ! Kind Regards, Nikolay |
[2017-01-13 18:24:18] |
You need to use this Input setting with the Numbers Bars study: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_BidAskVolumeTextThreshold Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-13 18:24:35
[2017-01-15 06:50:40] |
Hello, Thank you for your quick response. I have tried the setting, however it is not what I am looking for. It alters the way the chart bars look. I'm attaching a screenshot. I'm looking for a setting, which will make all volume sizes on the price levels within a bar that are over 100 highlighted (the background color of all >100 to be different than gray while all other volumes below 100 remain gray). |
Untitled 1.jpg / V - Attached On 2017-01-15 06:49:28 UTC - Size: 170.96 KB - 293 views Attachment Deleted. |
[2017-01-16 18:47:45] |
This is not exactly supported. You can color code the text or the background. But not both. Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextColoringMethods You want to use Volume Percentage Coloring but you can set the Column 1 Compare Threshold Input to be greater than 1 to compare to actual volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
