Date/Time: Wed, 15 May 2024 13:38:03 +0000
Import Custom Study Indicator
View Count: 2608
[2013-08-06 23:04:40] |
User75564 - Posts: 42 |
How do you import a Custom Study (Indicator). Which folder does it go in. (Data, ACS_Source?) I couldn't find. Thanks |
[2013-08-07 00:36:45] |
Refer to this page for instructions: http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-19 18:06:24] |
User673902 - Posts: 4 |
http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html shows Error 404. Not helpful. |
[2017-06-19 18:38:16] |
The name of the page has changed. You are looking at an old posting. Here is the new link: http://www.sierrachart.com/index.php?page=doc/UsingAdvancedCustomStudies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
