Date/Time: Sun, 28 Apr 2024 17:55:08 +0000
[User Discussion] - TPO Profile Chart study
View Count: 2175
[2013-04-02 05:58:00] |
User39128 - Posts: 20 |
i have changed my package (from 1 to 5) and now i can see TPO Profile Chart study on my charts USOil and UKOil timeframe 1 min. But if i want to change the current timeframe from 1 min to 5 or 10 or 30 min or 1 hour it is always 1 min chart. Pl explain me now, how can i set another timeframe (more then 1 min) with this study. Thank you |
[2013-04-04 10:08:23] |
You need to change this through the TPO Profile Chart study Input settings. Did you want to change the time period of the entire TPO profile? Or of a single letter/block.
[2013-04-04 10:14:24] |
as i understand now, the time period of the entire TPO profile is 30 minutes. Is it correct? what is the time period as default of a single letter/block? Thank you
[2013-04-04 10:20:39] |
The default time period of the entire TPO Profile is 1 Day and each single letter/block it is 30 minutes. Both of these can be changed through the Input Settings: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TPOProfileSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-04 10:21:04
[2013-04-04 11:00:16] |
okey, thank you, the question is now how to use it for the trading. I see TPO charts during 3 days und i should say, they fix only facts (now trading singals at all). how is can be used for trading decisions is for me a mystery. that is not a question, just my opinion now.
