Date/Time: Sat, 18 May 2024 22:45:38 +0000
Trader Dynamic Index
View Count: 2249
[2017-01-10 14:11:00] |
isa74 - Posts: 54 |
Sir, could you add this very intereting indicator: the Trader Dynamic Index Coupled with others, it is very effective. Thanks a lot ! |
[2017-01-11 10:16:15] |
Entropy - Posts: 36 |
It's included in the User Contributed Studies as TDI, which is nothing more than a 13 bar RSI. Cheers |
[2017-01-11 11:58:45] |
isa74 - Posts: 54 |
Sir, where do i find the User Contributed Studies please ? I do not find in the list of indicators. Thanks. |
[2017-01-11 12:33:50] |
Click on the SW tool bar button to open the Studies Window. Click on Add Custom Study down at the left bottom of the Studies Window. Click on User Contributed Studies. Scroll Down to TDI. Click Add. Cheers |
[2017-01-11 18:35:24] |
Here are detailed instructions: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-12 10:09:47] |
isa74 - Posts: 54 |
Thanks, I finally did it ! I create a RSI Study in which I implemented 3 Moving Average Simple. Then I ignore all the curves from the main study receiving the 3 others. Is that correct way to do ? Now...if I want that this package to be replicated as a collection and/or copy and paste in order chartbook, how do I do that please ? Thanks, I.B |
[2017-01-15 01:24:17] |
Refer to: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
