Date/Time: Thu, 16 May 2024 03:01:24 +0000
renaming color based on background alert
View Count: 875
[2017-01-09 23:23:47] |
ripsdips - Posts: 143 |
Can I rename "Color based on background alert" so that when it appears on a SMS it says other then "color based on background alert"?
[2017-01-10 04:01:48] |
Yes. You can change the study name through the Short Name setting: Chart Studies: Settings and Inputs Tab >> Short Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-10 08:32:39] |
i did that and the name changed on the subchart failed to do so on the SMS
[2017-01-10 08:42:28] |
We will check on this.
[2017-01-10 08:50:17] |
We do not see how this possibly can be the case if you have actually set the Short Name on the study containing the alert condition formula. We set the Short Name for the study containing the alert formula to Dog and this is the message received by email/SMS: Alert - Chart: GCG17 [M] 1 Min #16 | Study: Dog | Formula: =SG1>10 is TRUE. | Last Price: 1184.4 | Bar start date-time: 2017-01-10 03:47:00 | Alert: AlertSound (72) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-10 08:53:23
[2017-01-10 09:33:12] |
Never mind. I was using SHORT NAME on Subgraphs tab only not Setting and Inputs. It works. Sorry. Thanks.
