Date/Time: Wed, 15 May 2024 01:42:04 +0000
bid ask volume
View Count: 873
[2017-01-08 07:55:32] |
User358040 - Posts: 21 |
question: why sometimes the daily volume of a stock is not equal to ur bid ask volume? What happends with volume that is traded between bid and ask? Ur data on bid ask volume is trustworthy, isn't it? At the start I compared with marketdelta and it kind a was. Now I am a little bid unsure. Thanks for answering. |
[2017-01-08 19:41:25] |
Give us a very specific example and explain precisely how you are determining this.What happends with volume that is traded between bid and ask?
This is explained in the Definitions section here:Numbers Bars: Definitions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 06:53:59] |
o.k. - so check out gild. for ast friday. Volume in yahoo finance is: Volume 8,238,890 in sierrachcart hole day is: 7 559 473. Why is there this big difference? |
[2017-01-09 07:23:01] |
Tell us precisely how you are determining the volume of 7 559 473? It if it is from an Intraday chart, what are the Session Times and what is the time zone? And explain precisely how you are determining this volume. We need a very very precise information. For a question like you are asking there is absolutely no room for any uncertainty. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 08:20:54] |
This is the volume data that we see in the Intraday Chart covering the full 24 hours on this date: 2017-01-06 00:00:00.000 Bar Begin Time GILD [M] 1 Day #43 () Volume: 8267662 # of Trades: 41971 Bid Vol: 3926525 Ask Vol: 4341137 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 18:32:49] |
I open a daily chart of gild. There I see 7 559 473 volume for last friday. What I am doing wrong??? Am I not covering pre and post market data?
Attachment Deleted. time zone.PNG / V - Attached On 2017-01-09 18:26:09 UTC - Size: 4.13 KB - 192 views |
[2017-01-09 18:37:02] |
is here something wrong in settings??? see attached file...
session time.PNG / V - Attached On 2017-01-09 18:36:47 UTC - Size: 38.35 KB - 206 views |
[2017-01-09 18:58:17] |
I did change start time and end time. Volume now comes closer... but now there is an additional bar on the chart. What am I doing wrong?
daily chart gild.PNG / V - Attached On 2017-01-09 18:57:21 UTC - Size: 81.28 KB - 206 views |
[2017-01-09 19:29:51] |
The Session Times shown in post #8 are now correct. So we do not see anything wrong. You should now see this volume: 2017-01-06 00:00:00.000 Bar Begin Time GILD [M] 1 Day #43 () Volume: 8267662 If not, re-download the data: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart What additional bar are you asking about? In any case, the bars that you see are based upon the data in the chart and the Chart Settings. You need to be clear to us about specifically what you are seeing and why it should be different based upon the data for the symbol and based upon the Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 19:32:39
[2017-01-09 19:32:52] |
its o.k. all good. thanks. Problem is that if I change symbol, all the settings get kicked back again... I then tried to to this... "Preventing the Changing of Intraday Chart Session Times To prevent the Session Times from being changed when the symbol of an Intraday chart is changed, do the following: Make sure Global Settings >> Symbol Settings >> Apply Intraday Session Times to Intraday Chart is unchecked. Make sure Chart >> Chart Settings >> Advanced Settings >> Apply Intraday Session Times to Intraday Chart is unchecked. " Didnt work. Still changing everytime I change a symbol... And fwiw, in chart settings I did not find what was written in ur explanation... So I am so far not able to make sure that time settings are not changed when I change the symbol. |
[2017-01-09 20:01:23] |
We have verified that those instructions are correct and the Session Times do not change when the symbol is changed. This setting actually exists: Chart >> Chart Settings >> Advanced Settings >> Apply Intraday Session Times to Intraday Chart Check again. It is there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 20:02:08
[2017-01-10 07:17:30] |
o.k. saw it. Still, its changing every time I change symbol...
