Date/Time: Wed, 15 May 2024 22:28:19 +0000
minute bar
View Count: 689
[2017-01-07 18:42:26] |
Kinobe - Posts: 86 |
hi I am using 1 minute chart. I noticed that some bars are missing in the 1 min chart, like HTBX on friday. I suppose for these minutes, there were not trade. what should I do to get these not-traded minutes on the chart or at leat be notified that a minute is not traded? thank you |
[2017-01-07 22:59:50] |
You can do that with this setting: Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 02:41:12] |
great! is it possible to exclude after market and pre-market? |
[2017-01-09 04:50:23] |
Yes through the Session Times settings: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 15:13:53] |
I mean: display the not traded bar during the regular session and no display the not traded bar during afterhour/premarket session is it possible? |
[2017-01-09 19:11:46] |
No not at all. And this will not be added.
