Date/Time: Fri, 03 May 2024 10:12:51 +0000
CQG Nyse TICK Symbol
View Count: 1966
[2017-01-05 11:53:58] |
User985778 - Posts: 16 |
Can someone please tell me the name of the symbol for the Nyse TICK from the CQG datafeed? I cannot find it for any reason... Thank you very much! |
[2017-01-05 15:25:53] |
There is not one. You need to use the Sierra Chart Market Statistics: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-05 17:52:40] |
Is there no way to get it into SC since I use AMP and I see I can subscribe to those indexes? http://www.ampclearing.com/cqg_indexes.html Date Time Of Last Edit: 2017-01-06 08:45:26
[2017-01-05 18:20:21] |
No, there is not. Neither ourselves or users ever have been able to receive the cash indices from CQG and we have given up trying. Our official position is they are just simply unsupported and we will provide no further help on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-05 18:21:34
[2017-01-05 18:32:43] |
Ok thanks for your help!
[2020-06-29 16:34:41] |
Fox Kestrel - Posts: 11 |
So am I correct that Market statistics are at no extra cost if you have the Sierra 5 package even if it through AMP
[2020-06-29 18:25:25] |
Market statistics are included with all Sierra Chart packages: https://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#top Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
