Date/Time: Thu, 09 May 2024 14:45:22 +0000
How many instances
View Count: 724
[2016-12-29 15:40:48] |
User69055 - Posts: 23 |
Hello, I was wondering about the following ... I have a standard desktop computer with sierra charts loaded and was wondering if I could also in addition to this have a copy of sierra on my portable lap top. If so, how do I go about uploading the sierra charts to my portable laptop ... while also having it on my standard desktop computer. Is this allowable? Any assistance would be welcomed. Thanks! |
[2016-12-29 16:26:17] |
Sierra Chart - Max - Posts: 5608 |
Yes, you can just install Sierra Chart on the laptop. You can download the installer from here: https://www.sierrachart.com/index.php?page=doc/download.php#SoftwareDownload We see that you are using Transact, so if you want to use Transact on the laptop, then you will also need to follow the Transact setup instructions here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions If you would like to transfer Sierra Chart settings and data from the existing installation to the new installation, refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support |
