Date/Time: Sat, 11 May 2024 23:12:40 +0000
use two data feeds
View Count: 592
[2016-12-28 16:33:59] |
AKR - Posts: 523 |
Is it possible to use two data feeds at the same time? I would eg like to use CQG for futures and TeleTrader for stocks? Or do I need two copies of SC then? Thx in advance! |
[2016-12-28 16:35:04] |
AKR - Posts: 523 |
is that still the valid answer? Running two feeds on one install? |
[2016-12-28 18:10:08] |
Yes you do need to install two copies of Sierra Chart. Refer to: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
