Date/Time: Sun, 19 May 2024 05:24:07 +0000
Forex Trading
View Count: 691
[2016-12-16 13:59:19] |
gmorgan111 - Posts: 121 |
I currently trade the Futures on my computer with Rithmic data and my broker. I also have a forex account thru FXCM. My question is if I can trade from this same computer both the forex with my fxcm account and the futures es,nq,gc,cl, with my other broker account. They would be set up in different cartbooks Thanks |
[2016-12-16 17:59:04] |
Yes you can do this. You need to install another copy of Sierra Chart to use with FXCM. Here are the instructions: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html And you need to follow through the FXCM setup instructions here: http://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
