Date/Time: Sat, 18 May 2024 23:42:49 +0000
SMA's
View Count: 635
[2016-12-15 23:10:16] |
User153928 - Posts: 35 |
Hi, how can I move the read out of my moving simple average I have 4 with different colors on top in my chart to the side with the price scale and the would show up with the colors I selected in there it is not enough room on top to read them all TOSwim has it I'm sure you must have it to Thanks Walter |
[2016-12-16 05:06:34] |
You can change the study display order: Chart Studies: Study Display Order You can also use the Chart Values Window to see the moving average values: Window and CW Menus: Chart Values Window (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-16 05:07:02
[2016-12-16 17:51:30] |
Thanks great Walter |
