Date/Time: Fri, 17 May 2024 23:53:40 +0000
Delete Months At A Time From Intraday Data File
View Count: 598
[2016-12-15 00:21:10] |
User760942 - Posts: 120 |
Hi, I downloaded an intraday data file for the symbol ESM16. The file contains data from 2015/04/16-2016/06/17. What is the simplest way to delete the first 10 months of data from this file (so that it only contains data from 2016/02/16-2016/06/17)? I was only able to figure out how to delete the data 1 tick at a time. Hopefully there is a faster way? thanks |
[2016-12-15 04:53:45] |
One way to accomplish this is to export the data and then delete the data from the exported text file and then import it. Refer to this page for instructions: Exporting and Importing Intraday Data Files Also if this data came from the Sierra Chart Historical Data Service, then you just need to reduce this setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload And then re-download the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
