Date/Time: Mon, 29 Apr 2024 17:15:35 +0000
Volume By Price study request
View Count: 1486
[2013-08-04 13:49:48] |
andrewijaya - Posts: 6 |
Hello there, I just want to give you feedback for future enhancement in Sierra chart, especially for Volume by Price study (related to TPO and volume profile). I am hoping that SC would build an enhancement where it shows separate volume developing for the latest 30-min TPO letter as the market progress. And in addition, shows the cumulative volume at the same time. Please have a look at my attached picture. I am taking this picture from Window Trader, which has this capability for quite some time. The picture attached explain my wording better. Thank you. |
VbP study.jpg / V - Attached On 2013-08-04 13:49:25 UTC - Size: 42.6 KB - 523 views |
[2013-08-06 10:40:12] |
This is already supported. You just need create another chart and set it to 30 minutes per bar and follow the instructions here for single bar volume profiles: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#SingleBarVolumeProfiles You can add a 2nd Volume by Price study to the same chart and set it to display a more narrow profile that covers 1 Day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-06 10:40:31
[2013-08-06 14:03:55] |
Can you please help me. I do not know what I did with my setting, I follow your guide here. The vbp is so hard to read. Tiny tiny fonts. I hold ctrl and scroll but it didnt help at all. can you help to make it more viewable? |
vol prof _SC.png / V - Attached On 2013-08-06 14:03:52 UTC - Size: 68.74 KB - 454 views |
[2013-08-06 15:05:04] |
is it possible to make the size of the box and font of the Volume bar to be more proportional, and keep it that way (lock it). This is quite difficult to setup as default, as the price drops or goes up, the volume bar looks more tiny. if I hold Ctrl + scroll, it would be even worse if I hold shift + scroll, it would just drag to previous time in the past. please advice. I have seen other software (IRT + Market delta), they have consistent box size and when I scroll and shift, it will just drag to past timeframe instead of being resized. |
vol prof _SC2.png / V - Attached On 2013-08-06 15:04:57 UTC - Size: 95.12 KB - 453 views |
[2013-08-06 18:28:29] |
1. We recommend expanding the price scale to reduce the range of prices displayed. Refer to Interactive Scale Range: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling 2. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-06 18:28:41
