Date/Time: Sun, 19 May 2024 02:57:54 +0000
Move to BE or trailing stop
View Count: 1304
[2016-12-10 07:05:24] |
aydex - Posts: 110 |
Hi, I think I can use offsets in a Move to BE for an attached order I have in mind, but not sure. I have read the move to BE doc section, but not having any luck. Initial bracket order is target 15, stop 20. After price has triggered an entry, when price reaches a profit of 7 ticks, I'd like my stop moved (from the 20 value) to where 5 ticks profit is (a trail, but it moves no further). I realize these stops are managed by SC, SC has to be running, and data connected etc. |
[2016-12-10 16:57:00] |
Yes this is supported. In the Move to Breakeven for Stops section: Attached Orders: Move to Breakeven for Stop You need to set this to 5: Attached Orders: Breakeven (BE) Level Offset (Breakeven (BE) Level Offset) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-12 01:01:20] |
Thanks I'm working on that solution Meanwhile, how does one change the time/date format that shows at the bottom of the chart when moving the vertical line of the crosshair, please |
[2016-12-12 03:10:49] |
Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-16 00:07:50] |
Hi, Is there away to move the price values next to the chart and not have the fill space separate values and chart? http://www.sierrachart.com/images/RightSideFillSpace.png |
[2016-12-16 05:04:53] |
Refer to the documentation for this here: Working With Charts: Removing Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-16 05:13:42] |
Hi, Sorry, what i wish to do is have the fill space to the right of the prices. A rough diagram is attached. fill space is the blackened out column at furthest right. I still wish to preserve the fill space |
[2016-12-16 05:15:23] |
please be aware the diagram shows 2 fill spaces, i wish to have only the one at furthest right chart|prices|fill space |
[2016-12-16 05:44:40] |
No, this is not supported.
