Date/Time: Sun, 19 May 2024 06:24:42 +0000
Number Bars: split profile bar width
View Count: 1005
[2016-12-08 01:41:16] |
User19165 - Posts: 346 |
Hi there, I've been using the ask/bid volume split profile recently and have just noticed that the width of each bar at price is scaled to proportion separately of their ask/bid volumes rather than scaled as per both the ask and bid volume for the current bar. I'll attach a screenshot what I mean. It would be far more useful to me, if this instead scaled the bar width for the entire bar being created. I would like to make the chart less busy by not needing to have the bid/ask volume text on the chart and instead I could interpret the volume data quicker if it was evenly scaled across the whole bar. Do you know what I mean? |
MK-2016-12-08_143946.png / V - Attached On 2016-12-08 01:41:02 UTC - Size: 5.79 KB - 296 views |
[2016-12-09 06:03:34] |
Refer to: Numbers Bars: Numbers Bars Background Types You need to use: Ask/Bid Volume Split Profile Across Bid & Ask So what you want is supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
