Date/Time: Tue, 14 May 2024 18:04:32 +0000
Market Depth - Drawings
View Count: 668
[2016-12-05 00:07:09] |
User104854 - Posts: 441 |
Hi. I use the market depth tool on one of my charts. I am having trouble drawing an extending rectangle over it. I can draw lines, volume profiles, no problem. I tried making the transparency of the rectangle at 100% but it still didn't work. Is there a way to do this?
[2016-12-05 00:25:36] |
You just need to set the rectangles to draw above the price bars. This is explained here: https://www.sierrachart.com/index.php?page=doc/Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-05 00:25:49
[2016-12-05 00:33:22] |
Perfect. Thank you.
