Date/Time: Sat, 04 May 2024 11:05:52 +0000
Stop Limit order to enter
View Count: 1945
[2016-12-03 23:35:29] |
User14683 - Posts: 34 |
I am currently entering my trades using the DOM, where I right click on the Bid price ladder above the last to put in a Buy Stop order Buy Stop Order to be triggered at a specific price. How do I change this to rather be a Stop Limit order by right clicking on Bid price ladder above the last. If I want to enter on exactly the same price where I clicked on the ladder (trigger price=limit price), where do I set that? Under "Set" on my DOM, what should I set the Primary Order to and what should the Attached Order be (see attachment where it shows 4 and 4). I do not understand what Primary order is and what Attached Order is in the Stop-Limit Order Limit Offset box context - see attachment |
Attachment Deleted. |
[2016-12-03 23:56:02] |
This is explained in detail at step 6 here: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM You will want to set Set >> Stop-Limit Order Limit Offset >> Primary Orders to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-22 16:03:27] |
patrader - Posts: 92 |
I understand that the stop limit offset can be changed in the "Set" tab of trade window. It defaults to 4 ticks. I would like to change the default to 0 at the global level, to avoid changing it manually on every trade window. Is this possible?
[2018-01-22 19:07:53] |
There is no global setting for this. However, you can duplicate a chart which also includes the Trade Window for the chart, to use the existing settings. Refer to: Using Chart Templates There is also Trade Window linking: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
