Date/Time: Wed, 15 May 2024 16:59:59 +0000
ShowHistoricalPullback
View Count: 710
[2016-11-29 12:56:35] |
isa74 - Posts: 54 |
Sir, could you precise me the signification of these numbers placed at the top and bottom of each candles ? These are called by the parameter ShowHistoricalPullback in Numbers bars. They can be positive or negative. https://gyazo.com/cd6e5140b98332ab41143f0a01b226e4 https://gyazo.com/706ce48cfc9b202b9c6a651e147a81c3 A positiv number at the top means that buyers are growing ? A negativ number at the top means that buyers are now less strong ? Thanks for precisions. |
sc_Sierracharts_DAX_M30_ShowHistoricalPullback.jpg / V - Attached On 2016-11-29 12:54:15 UTC - Size: 348.12 KB - 217 views |
[2016-11-29 18:17:45] |
We can only refer you to the relevant documentation here: Chart Settings: Historical Pullback Data (Chart >> Chart Settings >> Chart Data >> Chart Data menu) https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#ShowHistoricalPullbackABVolumeDiff We have nothing further to say about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
