Date/Time: Fri, 03 May 2024 00:29:09 +0000
synchronize
View Count: 3799
[2016-11-24 06:46:12] |
User844406 - Posts: 18 |
Hi, I am using five windows charts and I would like to synchronize all of them. I mean - when I am scrolling in one chart I want to see synchronized move in other ones too. How can I adjust it? Thanks for your help. Daniel |
[2016-11-24 09:49:03] |
ticinotrader - Posts: 378 |
Enable: Tools -> Global Cursor On & Tools -> Synchronize Charts
[2016-11-24 10:37:03] |
In response to post #2, that is not the best way. The proper method is to use Chart Linking: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChartLinking And link the Scroll Position. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-19 23:05:44] |
nus1 - Posts: 39 |
Hi, "Synchronize Linked Charts Only" option is not lit / available. Want to sync specific couple of charts(big and small time frame) to the precision in relation to candle. Scroll position doesn't do same job as Synchronize charts does. None of the above instructions help. Version: 1809 Date Time Of Last Edit: 2018-09-19 23:06:41
[2018-09-20 00:03:41] |
We need to understand what you are looking for when using the Scroll Position linking option, which is different from Tools >> Synchronize Charts when using the Chart Values tool.
[2018-09-20 10:47:39] |
nus1 - Posts: 39 |
Example: two charts selected to be visible on the screen chart1 @ time frame - 1h / visible period 7 days on the screen chart2 @ time frame - 10s / visible period 2 hours on the screen On chart1 I NAVIGATE with chart value tool to day 3, candle 1 Synchronized charts option - In response chart2 SCROLLS to that position. Scroll position linking option - In response chart2 does nothing. And only responds if last candle(on the right) on chart1 is scrolled out of the screen.[EDITED AS PREVIOUSLY INNACURATE] So to reach day 3, candle 1 I'd need to scroll 4 days worth of candles out of the screen on chart1. Therefore "Synchronize Linked Charts Only" option not only would save time, but provide better visual management on chart1(being all last 7 days worth of candles are visible). Date Time Of Last Edit: 2018-09-20 15:15:49
[2018-09-20 19:04:11] |
Okay linking the Scroll Position is not used with the Chart Values tool. You do want to use Synchronize Linked Charts Only and here is the updated documentation for that: https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeLinkedChartsOnly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-20 19:04:26
[2018-09-20 23:04:42] |
nus1 - Posts: 39 |
Technically it's not working properly, but personally I can get away with it for what I need it. Experimented with it for half an hour. In my case I had two charts linked and on-display whilst other charts off-display(on the main monitor that is). Seemed to work like a charm, till you start touching other charts either on same or on different monitor. And then whichever chart goes on syncing with with whatever chart. The only ones left uncompromised were the biggest biggest charts(100m volume chart & 60min). I have 11 charts in chart book compiled of various timeframes & volume bars(all thoughtfully planned to be that way for price/study overlay reasons) Tested on another chartbook with 3 charts, all being W/D/240 timeframes and its no problem. |
[2018-10-02 17:49:10] |
This is not clear enough for us to understand.
