Date/Time: Sun, 19 May 2024 15:52:09 +0000
Draw Style: Subgraph Name and Value Labels Only
View Count: 1004
[2016-11-22 10:02:34] |
User34947 - Posts: 42 |
Hello, when Subgraph Name and Value Labels Only is selected as Draw Style of a Study, some Xs are still plotted on the chart. Here's an example with the study Volume Value Area Lines. Thank you |
FESX1216-EUREX 1 Range #1 2016-11-22 10_56_37.120.png / V - Attached On 2016-11-22 10:00:28 UTC - Size: 22.88 KB - 253 views |
[2016-11-22 10:40:30] |
Where do those Xs come from? This is not clear for us. We have very little perspective on this. What is drawing those? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-22 10:40:59
[2016-11-22 17:54:56] |
Thinking about this some more, there must be another Study Subgraph drawing those X characters that you are not recognizing.
[2016-11-22 19:03:54] |
There is not. Are you able to reproduce the issue?
[2016-11-22 19:05:46] |
OK we realize what the problem actually is in your case. Update Sierra Chart to the latest release. This was fixed. Refer to: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
