Date/Time: Sun, 19 May 2024 17:11:10 +0000
numbers bar indicator
View Count: 1072
[2016-11-21 22:51:02] |
User326163 - Posts: 18 |
I utilize the "numbers bar" indicator with the bid/ask separated for viewing. Is there a way for each candle, whether it ends up being green or red, to show the total volume it traded for that candle? For example, if the candle is red, show the total market bid orders for that bar? If a green candle, the total buy market order volume for the candlestick? Thank you in advance for your help! |
[2016-11-22 10:10:18] |
Not exactly this but you can use the Numbers Bars Calculated Values study for this data: Numbers Bars: Displaying Numeric Information Below Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-22 15:43:41] |
Thank you for the information. Are the numbers from this new study for actual trades or just current bid/ask volume? I'm looking for actual trades that went through on the bid/ask.
[2016-11-22 18:01:13] |
Yes they are from the actual trades.
